Im not sure what the problem is I have set the valves, cleaned the carb, looked for air leaks and still the same thing at idle. Its like it kind of back fires through the carb and some times it kills it. Any ideas?
Thanks
One commone problem with the kodiak is a sticking choke. That could cause the problem. May also want to check your gas and see if it has water or condensation in it.
