cool head domes for a 4mm stroke - Yamaha ATV Forum
post #1 of 8 Old 09-13-2005, 01:12 PM Thread Starter
i bought a used cool head i want to install on my 4mm stoke banshee it does not have a spacer under the cylinders it has a extra thick head gasket which i cant use with the cool head so i need to mill the domes it has 22cc domes in it i think how much do i need to mill of it and in what location i also am not sure about the port timming with the stroker if its off or not how do i need to check the cylinders have been ported some before stoker was installed thanks for any help Mike 98 shee with 400cc bored and stoked t5 pipes stock carbs boysen reeds toomey 2into1 airfilter
chevyshop is offline
post #2 of 8 Old 05-20-2007, 10:33 PM
Call Mod quad they sell domes for the 4 mill that are already milled to fit. the owner of the company runs that setup
jester185 is offline
post #3 of 8 Old 05-20-2007, 11:25 PM
Check your compression and see what its at now. Make a decision on wether or not you want to run race gas. Then, you need to buy some small domes, then have them milled so you dont surpass your desired compression level.
Snopczynski is offline
post #4 of 8 Old 05-20-2007, 11:32 PM
Talk to Noss Machine. www.nossmachine.com He makes the noss head wich usese the same domes as the prodesigne head. He makes all kinds of custom domes. That is really what you need. Just tell him what your running and if you want to run race fuel. He will get you hooked up.
03LimitedEditionRaptor is offline
post #5 of 8 Old 05-21-2007, 11:46 AM
Dextreme's Avatar
Personally I think he might risk the pistons hitting the domes if he compression tests it with the domes he has now since they have not been cut out to allow for the 2mm higher stroke.
SandLakeDuners.com
Short video of me
Dextreme is offline
post #6 of 8 Old 05-21-2007, 12:39 PM
They will hit if they are regular domes
post #7 of 8 Old 05-21-2007, 10:05 PM
Oh, so he doesn't have it assembled and hasn't had his domes milled for his stroker crank yet then! You need to talk to a motor guy and have your domes cut then. I would recommend the guy who ported it myself, or try Dave Moore, or Patriot Racing.
post #8 of 8 Old 09-04-2018, 03:21 PM
Bikez's Avatar
4 Mill cub 38mm pwk
WhichNeedle should I use cel or dgh the carbs are 38mm pwk air strykers
Bikez is offline
Racing head with domes Vs stock shaved head Banshee 26x Yamaha YFZ350 Banshee (1987-Present) 5 02-18-2005 09:03 PM
Need help. How do I tell what domes I have in my cool head? rideblue05 Yamaha YFZ350 Banshee (1987-Present) 6 04-14-2004 02:18 PM
Cool head domes banshee440 Yamaha YFZ350 Banshee (1987-Present) 13 08-06-2003 05:36 AM
Cool Head Domes yamaha01us Yamaha YFZ350 Banshee (1987-Present) 3 09-05-2002 04:44 PM
cool heads changing domes bansheewarrior Yamaha YFZ350 Banshee (1987-Present) 3 02-09-2002 10:17 PM
