Raptor wont turn over - Yamaha ATV Forum
post #1 of 9 Old 04-05-2019, 10:32 PM Thread Starter
I have 2002 raptor that wont turn over has new battery starter relay starter motor just clicks from relay I can jump across relay and does nothing neutral light works temp light comes on when you try to start it all the wires look good no broken wires all the connections look good I have this thing wired up for 24 volt starting but that's been done for 5 years now no problems till now I think mabey my CDI unit could be bad I could use some help figuring this out thanks in advance
Rdobson is offline
post #2 of 9 Old 04-06-2019, 10:40 AM
what do you mean by turn over? spins and wont start or wont spin. if it wont spin when you jump the big posts on the solenoid it is not the cdi. it will be the wire to the starter, a ground, the starter, or the starter clutch. if you have been sending 24 volts to the starter for five years that would be my first guess, those little motors are not designed for that and i am surprised it has lasted this long. bench test the starter and if its good most likely the starter clutch. if it spins and wont start that is another story
post #3 of 9 Old 04-06-2019, 12:31 PM Thread Starter
It wont turn over the starter is good it wont do anything no power going to starter motor I checked the main grounds on engine and frame jumping the starter relay does nothing
Rdobson is offline
post #4 of 9 Old 04-06-2019, 03:15 PM
if you have power to the relay on the big red wire and jump to the big black wire that runs to the starter and you dont have voltage at the starter pin it can only be a broken wire from the starter to the solenoid. if you have voltage to the starter and you have bench tested the starter and it is good it is either the starter clutch (some people call it a one way bearing) is bad or the motor has seized i have had both happen. if you take a jump box and place the red lead on the pin on the starter and the black lead on the starter case and turn the jump box on it will tell you if you need to look upstream or down from the starter. jumping those 2 big pins on the solenoid bypasses all of the safety switches and the cdi. it may not start but it will spin
post #5 of 9 Old 04-06-2019, 03:49 PM Thread Starter
I will dig in to that and let you know what I find thanks for your help so far
Rdobson is offline
post #6 of 9 Old 04-06-2019, 05:41 PM Thread Starter
Thanks for your help making me think about my problem I had a bad ground connection thanks again
Rdobson is offline
post #7 of 9 Old 04-06-2019, 06:20 PM
your welcome
post #8 of 9 Old 04-10-2019, 09:34 PM
Good Job Cory!
post #9 of 9 Old 04-10-2019, 10:31 PM
thanks
Starter struggling to turn over engine - Polaris Babb101 Other Models/Brands 2 10-10-2018 09:10 AM
Starter struggling to turn over engine Babb101 New Members Introduction 0 10-09-2018 02:59 PM
Raptor wont turn on Carlos Beltran Yamaha YFM660R Raptor (2001-2005) 3 08-01-2018 09:29 AM
Turn signal and break light issue warriorcannon Yamaha YFM350 Raptor/Warrior ('87-Present) 1 11-22-2016 08:25 AM
88 warrior Won't turn over Wcutler87 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 03-30-2016 12:17 PM
