2002 Yamaha Raptor 660 starter removal - Yamaha ATV Forum
post #1 of 11 Old 01-25-2019, 09:31 PM Thread Starter
Can someone inform me or send a video on how to remove a starter off a 02 Raptor 660? I pulled the side case off but starter will not come out. It seems to be stuck to the small gears. I will upload a pic.
2008 Yamaha Raptor 350
tjdarling2002 is offline
post #2 of 11 Old 01-25-2019, 10:08 PM
post #3 of 11 Old 01-25-2019, 10:19 PM Thread Starter
I tried and it won't come out. I would hate to damage something. I've pulled and pryed nothing happens. It seems like its stuck in between those gears.
post #4 of 11 Old 01-25-2019, 10:53 PM
are you sure the problem was your starter. maybe your starter clutch. i can look in the book when i get home in the morning to be sure but unless its jammed into the starter clutch and you have the bolts out it should just pop out
post #5 of 11 Old 01-26-2019, 07:04 AM Thread Starter
I'm pretty sure it's the starter. I tried to jump start it from the solenoid and the starter only clicks and from the push start button it only clicks also. I bought a $10 solenoid to rule that out, should be here by Saturday or Monday.
post #6 of 11 Old 01-26-2019, 10:29 AM
if jumping across the big terminals of the starter solenoid did not make it spin it is not the solenoid, it still may be bad but not your current issue. i would not put the cheap one in for now you are better off with the old factory part. can you get the machine up on some jack stands or blocks.. put it in gear and rock it back and forth t see if it frees the bind. take the plug out and put it in gear and see if you can turn it over by spinning the rear wheels.
post #7 of 11 Old 01-26-2019, 10:37 AM Thread Starter
I'll try that now. I'll hold off on the cheap solenoid lol.
post #8 of 11 Old 01-26-2019, 01:40 PM Thread Starter
That didn't work. All I get now is a buzzing sound from the push start. Starter doesn't even click anymore.
post #9 of 11 Old 01-27-2019, 11:47 AM
make sure the battery is fully charged or put a jump pack on it. if that does not spin it you will need to get that starter out to bench test it. it just pulls strait out no tricks if it is jammed you will have to sort out why. send me some pictures of the problem of post a youtube and send me the link. that should help me get you on the right track. the more details the better.
post #10 of 11 Old 01-31-2019, 09:44 PM
There are two screws under the carbs, that should be all you need to pull. it will pop out.
post #11 of 11 Old 02-06-2019, 08:20 AM Thread Starter
Thanks for all the input. It was my starter motor and 1 way bearing. Starter was jammed and 1 way bearing was wore. Replaced them both.
