Battery suggestion and batt blanket - Yamaha ATV Forum
post #1 of 6 Old 10-31-2018, 08:14 PM Thread Starter
Batt just went out on my 700 Griz and at this point I'm not familiar enough with batt brands to get what I'm after. Any suggestion for a specific batt or batt brand that's decent but not high priced?
Also, couple years ago I remember seeing a batt blanket made for small 4 wheeler sized batts but I lost track of who was selling it. Anyone know where I could find something like this?
bradleyheathhays is offline
post #2 of 6 Old 11-01-2018, 01:21 PM
i dont have a brand that is any better than any other they all are about the same. the agms as opposed the lead acid are significantly better. i get mine through baxter auto supply and have good luck. i have one yfz with a lithium battery and so far its been good going on 4 years old and still working. the lithium starts the machine every time but it hesitates when it is hot, it works it just seems funny but it has been like that since it was new and it will crank a little longer than the agm. as far as the blanket i just searched amazon and there were a few but i dont think they would fit in most battery boxes with out modification. unless you live in Alaska or Minnesota or some other equally frozen wasteland i would just wire in a battery tender.
this is the one i use but the battery tender brand is good as well
post #3 of 6 Old 11-03-2018, 04:27 PM Thread Starter
Thanks for the advice.
I've been told elsewhere to leave a trickle charger like a batt tender on all winter but I've also heard not to charge a batt when it's below freezing. Is it ok to leave a batt tender on when it's under 32?
post #4 of 6 Old 11-03-2018, 07:36 PM
you might not want to leave a constant type tender on if you were going to be well below freezing for a while but the smart chargers wont do anything to harm the battery. it is constantly getting feed back and adjusting the charge. i live in southern oregon and we have temp down to zero or a little below pretty regular basis during the winter and i have never had a problem.
Optimization
Stabilizes internal battery chemistry for
increased performance and longevity
Maintenance Plus
Keeps the battery fully charged without
overcharging allowing the charger to be
safely connected indefinitely
Energy Save
Minimizes energy consumption when full
power is not needed
Load Tracking
Charge LEDs dynamically track the
batteries state-of-charge when a load
outpaces the charge current
Diagnostics
Intuitive visual diagnostic tool for detecting
reverse polarity, low-voltage or damaged
batteries
CANBUS
Automatically enables the charging port to
charge CANBUS systems
Thermal Monitor
Internal temperature sensors adjust charge
based on ambient climate
this is page seven of the manual for the genius chargers. i have highlighted the section on temp for you. i have one of the tenders on my boat as well and it stays on there 9 straight months through the winter with no issues.
post #5 of 6 Old 11-04-2018, 02:42 PM Thread Starter
Alright good to know I can just leave it hooked up and forget out it.
post #6 of 6 Old 11-06-2018, 06:50 PM
Starting it once in a while is always good maintenance for the machine and the battery. A little discharge and recharge in the cold can create some heat that will warm things and stir the fluids.
