2001 Raptor 660 NO SPARK! - Yamaha ATV Forum
post #1 of 7 Old 07-03-2018, 11:32 PM Thread Starter
unhappy 2001 Raptor 660 NO SPARK!
Recently i picked up a pretty rough, raptor 660. I purchased it knowing there were electrical problems, thinking i could easily fix them. Boy was i wrong . So i went through the routine of checking for no spark. I tested the plug by placing it in my dirtbike, had spark. Checked the coil resistance, not reading great so i ordered one of those to be safe. I also ordered a new stator as ours read dead short on some of the terminals. these two problems i know will be resolved with the new parts. The thing im most concerned about is this black wire. its a black wire coming from the CDI that looks like its running to the spark plug coil. however, this wire was cut. upon giving the starter solenoid power, all of the lights work, as well as the ignition button, but when we try to connect the black wire back together, it gets very hot, sparks, and in our first extreme test, smoked . Any Help at all would be greatly appreciated.
(and yes, i did try unplugging the rectifier/regulator to no avail. )
Also forgot to mention, i have a new CDI and both yield the same result. im just mainly focused on finding out why that black wire is causing shorting somewhere.
Its_Chaynes is offline
post #2 of 7 Old 07-05-2018, 01:38 PM
Cut wires make diagnosis a real pain from the computer screen. I would trace the wires out using the manual and see where the black wire is supposed to be. The next problem will be possible damage to the CDI with what damage the shorting of that wire could cause.
There will be some troubleshooting charts in the manual that may help you trace down the root of the problem as well.
Look in here - https://www.bluetraxx.com/forums/yam...nt-topics.html
Welcome to the forums and keep asking and we will help!
post #3 of 7 Old 07-05-2018, 02:33 PM Thread Starter
Forbidden
You don't have permission to access /forums/vbseo.php on this server.
is what i get when i try to click on the wiring diagram section.
But, from what i can tell, that black wire coming from the cdi is supposed to go to ground. so i grounded it and no sparking or smoking of that wire anymore. if i get my new stator and it still wont spark, i know there is still a wiring problem.
post #4 of 7 Old 07-06-2018, 01:09 PM
try this
Raptor_660
post #5 of 7 Old 07-07-2018, 12:52 PM Thread Starter
Heres what i think that wire is. it comes from the cdi, and is the same color as this wire (circled in the wiring diagram ((top one))) but i cant connect them. they short out.
post #6 of 7 Old 07-13-2018, 06:09 PM Thread Starter
We replaced the stator, coil, cdi, and still nothing. we stripped the wiring harness completely off, and are going to try and locate the source of the problem. we dont want to resort to buying a new wiring harness, as they are really expensive and uncommon used, especially on a 2001 660.
post #7 of 7 Old 07-16-2018, 10:28 AM
check the crank sensor. did you use the cheap ebay knock off electronics? they have at least a 40% fail rate out of the box. chasing the wires out on the harness is a good first step
OE cdi box, no spark, aftermarket has spark but won't start with button. Bwoody Yamaha YFM350 Raptor/Warrior ('87-Present) 7 02-07-2017 08:23 PM
Please help!! 86 Moto 4 80cc NO SPARK Rnunnelly Other Models/Brands 20 08-23-2016 07:39 AM
97 Warrior no spark pwdcougar Yamaha YFM350 Raptor/Warrior ('87-Present) 6 06-27-2016 10:05 PM
Yamaha terrapro yfp350 spark plug issues rsmitty1000 Other Models/Brands 1 06-13-2016 10:15 AM
2009 Have Spark but not at Start BAMAJiPS Yamaha YFM350 Raptor/Warrior ('87-Present) 40 04-09-2016 07:17 PM
