Jetting question - Yamaha ATV Forum
post #1 of 2 Old 01-14-2019, 02:33 PM Thread Starter
Jetting question
I bought an 01 warrior that sat for almost 10 years, cleaned the carb and got her running. The air fuel screw was only backed out 1/2 turn as I received it but I backed it out to 2 turns based on some other forums. Bike runs good other than back firing sometimes while shifting as well as I inspected the plug and it had a slight white tip. From what I understand it seems lean, the previous owner did put a k&N filter in but the air box is factory could this cause my lean issue?
Also I bought a dg slip on but was curious what jets to get, I love at 1500ft and will do 50 percent of my riding there and the other 50 percent at the Oregon dunes roughly 50ft elevation. Is there a specific size that will perform well in both altitudes or will I just be messing with my air fuel mix?
CaseyR22 is offline
post #2 of 2 Old 01-15-2019, 10:26 AM
1] 2 to 2.5 turns is correct.
2] the k&n alone is not likely to cause a lean condition it was either lean from before, has a slightly clogged main jet or most likely has a small crack in the intake boot, is very common and they can be hard to spot. they will look fine unless you bend them or when they are bouncing on the trail.
3] other than more noise the dg will do you no good unless you open the air box and rejet
4] i had 3 warriors at one time and i dont remember the exact jetting numbers but this is what i ran. i live in southern oregon (klamath falls) so about 3900 feet. i ran the dg slip on, open air box with a k&n and outters sock, stage 2 dyno-jet kit using the sea level formula, and dropped one tooth off of the front sprocket. i never had any problems with being too rich at home so with half the elevation difference you will be fine running the sea level settings. before i dropped the front sprocket down i was having trouble running some of the bigger dunes and would even have to drop into first if banshee hill was rough and could not get a run at it. the lower gearing fixed that for the most part. the machine functioned perfectly i just wanted more. the lower gearing helped in the trails to. i was able to split 2 and 3 instead of 1 and 2 in the tight stuff and it helped with cooling. with those cheap mods the machine was better all around and very dependable. stay away from the big bore/strokers kits for these machines. you can do the jetting without the dyno jet kit but if you dont have a lot of experience with jetting it will tell you exactly what you need with your mods and elevations. they change the main needle out to give you a little better fuel curve as well. the only down side to the dyno-jet kit is they make there own jets and it uses and adapter to make it fit the individual carbs it works fine and i never had a problem with one but you can only use there jets if you need to make a change for an extreme temp or elevation change. i just bought a kit for each machine and labeled the box and kept them in my go box but honestly i never had to change. the data sheet was right on for me. those old school motors and not super picky and will really wake up with what i layed out for you. if you have any more questions or need help with an air box design let me know
Quick jetting question denverhensel21 Yamaha YFZ450/450R (2004-Present) 9 12-05-2018 04:19 PM
04 Blaster Jetting Question dvsxutact Yamaha YFS200 Blaster ('88-Present) 2 12-07-2017 04:10 PM
Jetting question 04 yfz 450 4yfz450 Yamaha YFZ450/450R (2004-Present) 1 09-08-2017 08:07 AM
Raptor Jetting 2005 660 tbrracer Yamaha YFM660R Raptor (2001-2005) 4 12-15-2016 02:59 PM
Jetting Question Raider89 Yamaha YFM660R Raptor (2001-2005) 7 02-29-2016 09:52 AM
