my warrior wouldn't run tested everything per service manual everything was good so replaced cdi . still wouldn't start so checked stator it was on the edge so replaced it . replaced both cdi and stator with ricks electric products and still nothing i pull the clutch in hit the start button and nothing if i jump the starter solenoid it will turn over but wont fire i even put a new starter solenoid on and still no change i also replaced both starter relay and safety relay and a new key switch and went wire by wire and toned them out to make sure none were bad
