06 yfz, coolant in oil....HELP - Yamaha ATV Forum
This is a discussion on 06 yfz, coolant in oil....HELP within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; I have an 06 yfz quad i recently bought. I did the oil change and replaced the coolant with engine ice. I rode for about ...
Old 03-26-2012, 09:06 PM   #1
blue_rappy's Avatar
View blue_rappy's Photo Gallery(0)
Default 06 yfz, coolant in oil....HELP
I have an 06 yfz quad i recently bought. I did the oil change and replaced the coolant with engine ice. I rode for about 15 mins and it got hot and stalled. Got it started and smoked blue like crazy. looked in the oil resivior and it was really watery, not milky but watery. tore the top end apart and the two head bolt under the cams were hand tight....great! thought it was the head gasket, replaced and no such luck. started it again and no smoke but after it got hot and cooled the oil res was full again!!! got new water pump seals but have not replaced yet. the old ones didnt look too bad but i need a gasket first. head and jug look good, no cracks, and im gettin real frustrated with this damn quad. PLEASE if anyone has any idea let me know. Thanks The quad does run and start great just cant figure out why theres cooland it the oil, i did drain the coolant and it looked a lil dirty too. but nothing was milky
blue_rappy is offline   Reply With Quote
Old 03-26-2012, 10:29 PM   #2
carsonmx114's Avatar
View carsonmx114's Photo Gallery(0)
put a presure tester on the cooling system with the spark plug out. If it's the head gasket the coolant will come out of the spark plug hole. If the cylinder stays dry it's most likely the waterpump seals. I'd replace the bearing that the impeller shaft rides on while I was in there as well.
carsonmx114 is offline   Reply With Quote
Old 03-27-2012, 07:28 PM   #3
blue_rappy's Avatar
I did repalce the head gsaket and all the top end gaskets and still did the same. I have the clutch cover off and am ion the process of replacing the seals but the idiot who rebuilt this before i got it never put the washer inbetween the impeller and shaft so i have to order one. just lookin to see if there are any other possible places water can get in.
Old 03-27-2012, 09:10 PM   #4
Are the seals in the correct way? If I remember right they are positioned opposite of each other spring side away from each other. It's not an uncommon failure. I would suspect the waterpump seals before the head gasket for sure.
Old 03-29-2012, 03:04 PM   #5
View PSItech1's Photo Gallery(0)
dont use engine ice for coolant use half coolant and distilled water and check your water pump seals
PSItech1 is offline   Reply With Quote
Old 03-29-2012, 09:22 PM   #6
blue_rappy's Avatar
yeah the old oil seals were in the right way and the new ones are too. And whats wrong with engine ice??? I have had great luck in the past with it.
yfz 450 water in oil
yfz 450 coolant in oil
yfz450 water in oil
07 yamaha yfz 450 coolant in the oil
yfz450 milky oil
yfz 450 coolant change
2005 yfz 450 water in oil
yfz450 antifreeze in oil
yfz 450 oil in coolant
will milky oil make a stater not work on a 03 yzf450
coolant in engine yfz
05 yfz 450 antifreeze in oil
coolant? 97banshee350 Yamaha YFM660R Raptor (2001-2005) 3 06-12-2005 08:47 PM
Coolant fasterblasteryfz450 Yamaha YFM660R Raptor (2001-2005) 5 05-30-2004 09:18 PM
coolant bobby bo Yamaha YFZ350 Banshee (1987-Present) 7 08-26-2003 05:28 PM
Coolant TheGreenGrizzly Yamaha YFZ350 Banshee (1987-Present) 8 08-12-2003 09:45 PM
Coolant BADBRONC Yamaha YFM660R Raptor (2001-2005) 10 03-08-2003 10:43 AM
