coolant in oil and engine seized - Yamaha ATV Forum
This is a discussion on coolant in oil and engine seized within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; so i just became a member here so im new at this .but I have been looking on here and you guys have been very ...
Old 03-23-2011, 08:43 PM   #1
View opie450's Photo Gallery(0)
Default coolant in oil and engine seized
so i just became a member here so im new at this .but I have been looking on here and you guys have been very helpful so far. the only thing is you have nothing about the problem im having. i bought a 04 yfz 450 about two years ago and ive been amazed by the quad and even though its been a complete money pit i havent let my faith down yet so neway, the valves were sounding a little tight and i figured they werent to bad so i would just get them looked at when i came back from my trip. well b4 i even went i ordered brakes and clutch cable installed them and headin to the farm for a test drive. after about 2 minutes into the ride i went from 5th gear and came to a corner so i down shifted into 3rd and it just seized and stopped dead in its tracks. i tried to start it back up but the starter just clicked. and when i went to move the back tires it was just locked up. nothing grinded or was tinging around the motor it just seized and thats it. so i took it home and drain the oil and coolant poured out with grey oil following. i know i possbly blew it up i was just trying to find out to what degree and if its worth rebuilding.
plz help
opie450 is offline   Reply With Quote
Old 03-24-2011, 05:36 AM   #2
redneckyfz450's Avatar
View redneckyfz450's Photo Gallery(0)
check the head cylinder on the camshaft area. remove all of camshaft and inspecting if there re any damaged on the cam area like feel if its rought. it mean ur head is fucked up. you might run it without the oil and engine got hungry for oil. then it would cause the rough feel on the camshaft . u can't see if its damaged u have to touch to see if its smooth or not. bec if its rough feel on camshaft it wouldn't be work with 7.2 pound torque to wrench it up on cams journal and won't start the engine.. u might to have buy new head cylinder and new camshaft , might need to replace the crank. bec once engine run dry you might have damage in somwhere in crank. thats what i m going to order the new head cylinders for my 04 yfz450. i m put the 2006 yfz head cylinder on my 04 yfz i heard 06 head cylinder re more reliable then the 04-05
redneckyfz450 is offline   Reply With Quote
Old 03-24-2011, 09:05 AM   #3
alright i have the bike somewhat tore down but i dont know how to take off the cam chain. i know there is a tensioner but is all i have to do is take that off. and unbolt the cams.
Old 03-24-2011, 11:05 AM   #4
RuffRyderNJ's Avatar
View RuffRyderNJ's Photo Gallery(0)
search for a service manual and dowload it. itll make it alot easier if your not 100% sure of what to do.
2008 Blue YFZ450- GYTR Alu slip on, air box lid removed,FCI, powermadd handguards, Sea level 45p 180m 2.5 turns, 4th clip NCVQ
RuffRyderNJ is offline   Reply With Quote
Old 03-28-2011, 03:56 AM   #5
the chain tensior is easy to take it off. just loose up on tensior and it will loose the chain.
Old 03-28-2011, 04:55 PM   #6
leveldrummer's Avatar
was there any metal in the oil as you drained it? have you removed the oil filter and inspected it for metal peices?
2 things could make water get in your oil, a busted head gasket, or a bad water pump seal, if enough coolant gets in the oil, you will lock the engine, which is what it sounds like happened. hopefully didnt rip anything apart (there would be metal all over the bottom of the engine)
the other possiblity is that you blew it up, and it shredded everything in the engine and busted the water jackets in the engine and basically just destroyed everything. it doesnt sound like thats what happened.
Old 03-30-2011, 06:42 PM   #7
thats a little bit more of the help i was looking for thanks. but neway there is no metal in the oil just coolant.
Old 03-31-2011, 05:32 PM   #8
sounds like you either blew a head gasket, or your water pumps seals went out. no way to tell really.
sounds like since nothing exploded, it should be a pretty straight forward rebuild, new bearings, new piston/rings/jug, etc. maybe a crank.
yfz 450 water in oil
ltr 450 coolant in oil
yfz450 getting water into engine
07 yamaha yfz 450 coolant in the oil
06 ltr 450 getting oil in radiator
oil gray in yfz 450
by mixing water with oil 450 ltr suzuki
yfz 450 grey oil clutch
yfz450 coolant in jug
ltr450 coolent leak
causes for having water in oil on yfz450
yfz 450 seized#gsc.tab
05 Grizzly COOLANT IN ENGINE, HELP wildraptor6601 Other Models/Brands 0 09-09-2010 12:18 AM
Coolant system bleeder on engine block? eman40000 Yamaha YFM660R Raptor (2001-2005) 2 01-18-2007 07:12 PM
engine seized(possibly) blue blaster99FMF Yamaha YFS200 Blaster ('88-Present) 8 12-06-2003 08:00 PM
