2007 yfz450 Wont Start and backfires - Yamaha ATV Forum
This is a discussion on 2007 yfz450 Wont Start and backfires within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; Hello i just got a yfz450 guy said he can get it started and was leaking gas out of overflow so i pulled carb and ...
Old 06-26-2010, 07:26 PM   #1
View rapjim's Photo Gallery(0)
Default 2007 yfz450 Wont Start and backfires
Hello i just got a yfz450 guy said he can get it started and was leaking gas out of overflow so i pulled carb and cleaned it float needle was stuck. now i cant get it to start and idle and is backfiring real bad i did have it started for a minute and all it did was backfire. any help would be great
rapjim
rapjim is offline   Reply With Quote
Old 06-26-2010, 10:36 PM   #2
leveldrummer's Avatar
did you take the slide out? it can be put in upside down, with the results like your describing.
or maybe you moved the TPS a little on the carb (little black round wire thingy on the left side of the carb)
Old 06-27-2010, 10:36 AM   #3
how would u adjust the tps?
Old 06-27-2010, 11:11 AM   #4
View mz9699's Photo Gallery(0)
leveldrummer said it. I had the same exact problem after I was messing with the carb. Turns out the throttle plate, aka slide, can go in two ways. This will cause it not to slide all the way down. It's worth a look. The tps is where the electrical connection goes into the top of the carb, and according to the book you turn it clockwise or counterclockwise to adjust your throttle position....
mz9699 is offline   Reply With Quote
Old 06-27-2010, 11:34 AM   #5
just adjusted tps still no fire gonna pull carb and double check slide will update with what i find thanks everyone for the responses
Old 06-27-2010, 01:43 PM   #6
Bowtie's Avatar
View Bowtie's Photo Gallery(8)
If you ever suspect that the TPS is bad, then just unplug it, the bike will fire and run with out it hooked up. Double check the timing and make sure that all the marks line up right. If you don't know how, get a shop manual from here.
YFZ450 Garage
09 YFZR SE
05' YFZ 450 - Gone
00' Banshee - Gone
07'/06' YFZ 450 - Gone
Bowtie is offline   Reply With Quote
Old 06-27-2010, 01:50 PM   #7
tps is good according to manual checked it and adjusted with a volt meter how could you tell if the throttle slide is in upside down?
Old 06-27-2010, 04:34 PM   #8
thumbs up
ok got it fired up ended up being the spark plug had no gap adjusted the gap and fired right up still a little boggy on throttle unplugged tps and tors up in throttle housing seemed to help a little could i run the bike without these?
Old 06-28-2010, 02:45 PM   #9
Bowtie's Avatar
You can run the bike with out the TORS, that's not an issue. But if you unplug or jumper the TPS, you turn the 3d timing map in the CDI into a 2d map. There are those that will argue that it makes a difference. I honestly didn't feel a difference between the three settings.
09 YFZR SE
05' YFZ 450 - Gone
00' Banshee - Gone
Old 06-28-2010, 06:51 PM   #10
ok took it for a test ride and have to feather throttle a little to get it past a bog coming of idol. other then that it runs fine Would rejetting take care of that or something else?
Old 06-28-2010, 07:16 PM   #11
Bowtie's Avatar
Read this thread
The Bog, the Zip Tie / O-Ring Mod and You
09 YFZR SE
05' YFZ 450 - Gone
00' Banshee - Gone
yfz 450 throttle position sensor
yfz 450 backfire
yfz 450 wont start
yfz450 wont start just backfires
07 yfz 450 starting problems
yfz 450 backfire and wont idle
05 yfz 450 backfiring problems
yfz450 backfiring
06 yfz wont start backfiring thru exhaust
2007 wr450 backfires and will not start
2007 yamaha yfz 450 wont start backfires thru exhaust
2008 yfz 450 how to bypass tps
yfz wont start only backfires Mikes04yfz Yamaha YFZ450/450R (2004-Present) 12 08-04-2010 10:12 PM
2007 YFZ450 $3,200 73Raptor ATVs for Sale 2 02-16-2009 04:07 PM
2007 SE YFZ450... less than 20 hrs KandK_Z-400 ATVs for Sale 2 09-08-2007 11:12 PM
HELP grr wont start backfires hard and nothin help pleaseee ironraptor04 Yamaha YFM660R Raptor (2001-2005) 3 10-06-2006 06:43 AM
won't start / backfires--update, IT'S ALIVE! Voodoo Yamaha YFZ450/450R (2004-Present) 7 02-07-2005 03:39 AM
