Clutch adjustment? - Yamaha ATV Forum
post #1 of 4 Old 07-17-2009, 03:04 PM Thread Starter
Clutch adjustment?
I just put a new barnett clutch in my 04 YFZ,now my clutch lever is half slack before it gets tension. What can I adjust to fix this? Can the arm on the motor be adjusted? Thanks
Currently: 08 yfz 450
Previous quads:
04 yfz 450
04 raptor 660
blastermaster88 is offline
post #2 of 4 Old 07-17-2009, 03:37 PM
leveldrummer's Avatar
you can take the arm off, and move it over a few teeth, but i would try to take the slack out on your cables first. adjust each end out, and there is even an extra adjustment in the middle of the cable to lengthen it a little bit...
leveldrummer is offline
post #3 of 4 Old 07-17-2009, 04:04 PM
Bowtie's Avatar
Like Level said, try to adjust it out in the cable. If that doesn't work, then put it back to the way it was, and then turn the rod so that it is touching the pressure plate, then back it off one tooth, and then fine tune it with the cable adjustments.
09 YFZR SE
05' YFZ 450 - Gone
00' Banshee - Gone
07'/06' YFZ 450 - Gone
Bowtie is offline
post #4 of 4 Old 07-17-2009, 11:00 PM Thread Starter
Thanks guys,I didnt see you could adjust the cable in the middle. I lengthened that and it tightened right up!
Previous quads:
04 yfz 450
04 raptor 660
clutch adjustment gomer Yamaha YFZ350 Banshee (1987-Present) 2 02-24-2004 11:09 PM
clutch adjustment 03 raptor Yamaha YFM660R Raptor (2001-2005) 4 01-16-2004 04:38 PM
Clutch Adjustment? TrailBreaker70 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 12-23-2003 07:11 PM
Clutch Adjustment? jakalwarrior Yamaha YFM350 Raptor/Warrior ('87-Present) 4 01-03-2003 11:06 PM
clutch adjustment wade the k Yamaha YFM660R Raptor (2001-2005) 6 02-14-2002 10:23 AM
