06-05-2009, 01:04 PM
Starter doesnt seem to be cranking the engine fast enough?
I have a 04 yfz450. My problem is that the starter doesn’t seem to be turning the engine fast enough to start.
Its a new battery (that tested good), a new starter, the valves are shimmed to .125-.150 on the intake and .203 on the exhaust, the connections are clean and secure without any short or drain on the battery.
My main concern right now is either the auto decompression system or possible a bad new starter.
The decomp seems to be working properly. However, once there is pressure on the decomp pin, it is difficult to move the arm that’s on the sprocket. Once I put enough pressure on the arm, it gives off a "click" sound and will move freely. When there isn’t any pressure on the pin (like if the cam was removed) the whole decomp system will move freely. Is this normal?
Any other possible thoughts? I’m out of ideas on what to check next...
06-05-2009, 03:35 PM
have you spun the motor manually? does it spin over easily, are you sure the starter isnt spinning fast enough? maybe the whole motor isnt spinning easily.
does it run at all? just not spinning fast?
06-05-2009, 04:35 PM
Yeah, it actually runs like a raped ape once I get it going but it just wont start under its own power... I have hand cranked the motor (when I was shimming the valves) and it moves without much force.
06-05-2009, 04:54 PM
sounds like a bad starter then.
09 YFZR SE
05' YFZ 450 - Gone
00' Banshee - Gone
07'/06' YFZ 450 - Gone
06-05-2009, 05:04 PM
Has anybody had any experience with a PowerSonic battery? The guy at the batter store told me that the PT7B-4 is the one I need. I just looked at the specs and the manual says I need a 6.5 amp battery and the one I bought is a 6 amp. Is that enough of a difference to make it not start?
06-05-2009, 06:28 PM
I would have a hard time thinking that .5 amps would make a noticeable difference in cranking, you could try exchanging it or borrowing a buddies and seeing if it changes the cranking speed.
09 YFZR SE
05' YFZ 450 - Gone
00' Banshee - Gone
06-05-2009, 07:30 PM
there is a CBR battery that a lot of guys use, its a little high amps, you have to cut the divider out that holds the owners manual on your plastics, the battery is just a tiny bit bigger, but its supposed to be a much better battery, i could find out exactly which one if your interested in it.
06-06-2009, 09:59 AM
Yeah, absolutely! Thanks for all of your guys help! Still not sure what the problem is but I'll get it sooner or later.
Can somebody with a yfz450 please check to see how much the voltage drops on their battery once they try to start the quad?
The multimeter reads 12.8v when the battery is fully charged. Once I press the start button the voltage drops down to the high 9's or low 10's. The first crank of the engine really sounds labored but ove the initial crank is done the volts go back to the 11's and it sounds pretty much normal. When the battery isnt fully charged (12.5v) the voltage drops down into the mid 7's.
Does this seem correct? I cant figure out why it would drop so much...
06-06-2009, 10:59 AM
Sounds like a weak cell in the battery or a bad starter putting a heavy drain on the battery. I just tested mine, and while cranking, mine only drops to 11.3 to 11.5 volts. Also double check all your ground wires and make sure they are making good connections.
09 YFZR SE
05' YFZ 450 - Gone
00' Banshee - Gone
06-06-2009, 11:45 AM
#10
Thanks a lot! I'm leaning towards the battery right now... Ill try to swap it out with my friends raptor to see if that will start it.
Thanks again!
06-12-2009, 12:27 AM
#11
Believe its for a Raptor 350 or CBR 600 I installed one in my 07 450. Used a knife and a hand held propane torch to keep the knife hot to cut out the extra plastic. Pretty easy job.
I wanted the extra amps because I installed a Rekluse Pro Autoclutch and there is no push starting if your battery goes bad. Had this happen at Glamis at night with stock battery. Had to be towed by a Bombardier 650. Man that was a wild and fun ride though!
starter not spinning fast enough and battery wires getting hot on chey 350, high compression yf450 won't start with decompression pin open, hard to turnover yfz wont start, yfz 450 turns over slow, 125cc atv turning over slowly, starter not cranking fast enough, starter doesnt sin fast enough to start engine, starter motor wont turn engine fast enough, starter amps on yfz450, yamah atv slow turning engine, high compression yfz won't turn over, yfz spinning slowly
