How to adjust chain on 07 Yfz450???
This is a discussion on How to adjust chain on 07 Yfz450??? within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; Hi Guys, just bought a 07 YFZ450, and wanted to know- how do you adjust the chain slack... loosen the the (4) bolts and then ...
Old 06-02-2008, 12:38 AM   #1
View Heckler05's Photo Gallery(0)
Default How to adjust chain on 07 Yfz450???
Hi Guys,
loosen the the (4) bolts and then what is next..... (any pictures)
tried the search- no luck on 07 models
Heckler05 is offline   Reply With Quote
Old 06-02-2008, 11:26 AM   #2
Hefe's Avatar
View Hefe's Photo Gallery(0)
stick a punch or some sort of screwdriver type thing in that hole on the left side of the carrier (when facing the rear) and roll the bike, the chain sprocket will adjust the accentric (sp) in the carrier, and tighten or loosen the chain
~Hefe~
Hefe is offline   Reply With Quote
Old 06-23-2008, 12:06 PM   #3
View jumpingjack's Photo Gallery(0)
From the "YFZ450 Owners Manual":
Stock airbox w/EHS lid, Stock pipe with baffle, 45 pilot, stock needle #4, 165 Main, zip-ty Fuel screw 2 turns out, Quasi-Moto decomp plug
jumpingjack is offline   Reply With Quote
Old 06-30-2008, 08:53 PM   #4
JayDawg's Avatar
View JayDawg's Photo Gallery(0)
How do you adjust the chain on an 05' YFZ with the other rear swingarm?
2005 YFZ 450
2007 YFZ 450 SE
www.quadsforchrist.net
JayDawg is offline   Reply With Quote
Old 07-02-2008, 10:56 AM   #5
Hefe's Avatar
what "other" swingarm Jay?
the stock 05?
~Hefe~
Old 07-02-2008, 11:55 AM   #6
JayDawg's Avatar
Yes, the stock 05' swingarm. I said other because it is a different swingarm from the 06''s and on.
2005 YFZ 450
2007 YFZ 450 SE
Old 07-02-2008, 12:14 PM   #7
Hefe's Avatar
loosen the 2 big bolts that go thru the carrier, and turn the little ones till the chain tightens up, the 04-05 were pretty easy to figgure out.. just stare at it for a minute... super easy!
~Hefe~
Old 07-03-2008, 12:09 AM   #8
JayDawg's Avatar
Cool thanks Hefe! I read somewhere you had to match up some marks but I didn't see any and that is why I was a little confused!
2005 YFZ 450
2007 YFZ 450 SE
Old 07-03-2008, 09:45 AM   #9
Hefe's Avatar
the marks are there for you to keep your axle straight
~Hefe~
Old 07-03-2008, 12:00 PM   #10
JayDawg's Avatar
Where are they at? I don't see any marks on mine.
2005 YFZ 450
2007 YFZ 450 SE
Old 07-10-2008, 11:50 PM   #11
leveldrummer's Avatar
they are right on top of the swingarm, next to the sprocket and brake caliper, looks like a little arrow, and a few lines, if you just count the turns on the screws that tighten your chain, and turn each one equally, you should be fine.
Old 07-15-2008, 02:51 PM   #12
JayDawg's Avatar
Thanks for the reply, I just found them. I will probably adjust my chain in the next day or two. Do you need the YFZ jacked up where the wheels are not touching the ground when you do this or is it okay to adjust the chain with the wheels on the ground?
2005 YFZ 450
2007 YFZ 450 SE
Old 07-16-2008, 12:40 PM   #13
its ok to adjust with them on the ground, but do it sooner rather than putting it off, a loose chain can cause some serious money if it snaps or binds, one of the simplest things to check and maintain, and most people wont. if it break, you can easily bust up your left case, end up costing a TON of money to fix, and it only takes 10 minutes tops to adjust and oil. and replace it when its worn, you dont want to break a chain!
Old 07-16-2008, 01:40 PM   #14
JayDawg's Avatar
Stupid question but how do you know when your chain is worn out? The chain on my YFZ is the stock one from when I bought it new almost 4 years ago. The YFZ has maybe 30 hours on it.
2005 YFZ 450
2007 YFZ 450 SE
Old 07-16-2008, 02:16 PM   #15
i usually look for signs of wear around the pins where it slides on the sprockets, the outer edge of mine gets worn pretty good where it slides down my skid plate too, if it seems rusted,there are o rings in between each link too, make sure those look good and not all cut to hell.
Old 07-24-2008, 02:59 PM   #16
JayDawg's Avatar
Hey all, I am tightening my chain right now but am having nothing but problems. I loosened the two bigger bolts and then began turning the two smaller bolts. All it does is screw all the way to the bigger bolts and that is it. Nothing adjusts. What am I doing wrong?
2005 YFZ 450
2007 YFZ 450 SE
Old 07-24-2008, 03:58 PM   #17
JayDawg's Avatar
Nevermind, I got it done. I didn't see the 17mm bolt that I had to loosen that was behind the brake caliper. Once I loosened it, it was a piece of cake to do. I don't know why a lot of people said it was a difficult job to do? That 17mm bolt was a pain in the butt though. That thing was on there freakin tight! I tightened it down as tight as I could it return but man I was amazed at how tight it was on there from the factory. I had to use a cheater bar in my ratchet to loosen it.
2005 YFZ 450
2007 YFZ 450 SE
yfz450 chain adjustment
how to tighten a chain on a yfz450
how to tighten chain on yfz450
how to tighten chain on 2008 yfz 450
yfz chain adjustment
how to tighten a chain on a yamaha yfz 450
yfz450 chain
yfz450 tighten chain
how to tighten yfz 450 chain
tighten chain yfz450
how to adjust chain on 2008 yfz 450
yamaha yfz450 chain adjustment
What do you use to adjust your chain with? sd Yamaha YFM700R Raptor (2006-Present) 5 10-04-2007 09:35 PM
What do you adjust your chain to? 69hahaha Yamaha YFM660R Raptor (2001-2005) 4 10-16-2006 11:33 PM
Why cant I adjust my chain gt2894me Yamaha YFM660R Raptor (2001-2005) 6 03-01-2005 09:39 AM
How do I adjust a KFX chain??? RAPTOR74 Other Models/Brands 6 02-03-2004 05:44 PM
