How much oil does the 450 hold? - Yamaha ATV Forum
This is a discussion on How much oil does the 450 hold? within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; Doing an oil change on a 07 450. How much oil does it hold if I drain the oil and change the filter?...
Old 01-15-2008, 06:50 PM   #1
View jt911's Photo Gallery(0)
Default How much oil does the 450 hold?
jt911 is offline   Reply With Quote
Old 01-15-2008, 07:24 PM   #2
HighProCam's Avatar
View HighProCam's Photo Gallery(0)
I say 1/3 of a quart in the motor and 1 and 2/3 quart in the oil tank,
but the rocket scientist in here will correct me.
Don't worry about it, spill a little on the ground and you'll be fine :)
Project Smoke Every 450 on the Dunes- Fully Modded Blaster with a 465cc 2stroke
Daily Duner- Mid Modded YFZ450
Wa. Woods- Outlaw 525 IRS
Last edited by HighProCam; 01-15-2008 at 07:26 PM. Reason: added "oil" so no dummes put it in the "gas" tank
HighProCam is offline   Reply With Quote
Old 01-15-2008, 07:27 PM   #3
So its 2 quarts total? Don't have the owners manual handy and I can't remember from last time.
Old 01-15-2008, 07:34 PM   #4
View yam_raptor_02's Photo Gallery(0)
I think its like 1.96 QTs. I usually just do what Highpro does. around half in the crankcase and 1 1/2 in the tank.
06 Banshee SE
06 Raptor 700
07 YFZ450 SE
yam_raptor_02 is offline   Reply With Quote
Old 01-18-2008, 11:49 AM   #5
View 93pile's Photo Gallery(0)
its like 6 or 8 ounces in the crank, then a quart in the tank, run it and then top the oil tank off, it takes like 1.7 quarts. otherwise just look right in manual
Go big or go Home
2004 YFZ 450
20" Maxxis Razr
FMF Powercore 4
93pile is offline   Reply With Quote
Old 02-13-2008, 09:16 PM   #6
View Z440's Photo Gallery(0)
10 oz (300ml) in the case. The rest of the 1.85Q in the tank.
'05 YFZ450
'03 KLX400
Z440 is offline   Reply With Quote
Old 02-13-2008, 10:08 PM   #7
View Blstr88's Photo Gallery(0)
Whats the difference if you put a little too much in the crank and not enough in the oil tank or vica verse wont it just level itself out once it runs for a while anyway?
2011 F6 Snopro - its green and moves best on snow.
Blstr88 is offline   Reply With Quote
Old 02-13-2008, 11:20 PM   #8
Most of the oil ends up in the case when it sits. Just following specs so that adequate oil is in there after a change for startup.
'05 YFZ450
'03 KLX400
yfz 450 oil capacity
yamaha yfz 450 oil capacity
2006 yfz 450 atv how much oil
2015 yfz450r oil capacity
2008 yamaha rhino 450 oil capacity
2008 yamaha yfz 450 oil capacity
how many quarts of oil does a yfz450 take
2004 yfz 450 oil capacity
2008 yfz 450 oil capasity
05 yfz 450 how much oil for oil change
2007 rhino 450 how much oil does it take
Will she hold together.... Mike8500 Yamaha YFM660R Raptor (2001-2005) 6 04-23-2007 08:40 PM
Will JTM hold up harley_sr Yamaha YFM660R Raptor (2001-2005) 16 12-13-2003 12:07 PM
