methanol? - Yamaha ATV Forum
post #1 of 14 Old 08-27-2007, 03:59 PM Thread Starter
methanol?
Other than needing the obvious of chrome molly rings, and a few titanium parts up in the head, are there any major mods that need to be done to run methane? or has anyone done this??
Go big or go Home
2004 YFZ 450
20" Maxxis Razr
FMF Powercore 4
93pile is offline
post #2 of 14 Old 08-27-2007, 05:47 PM
Send a message via AIM to UBETRUN
Do you mean methanol (alky), nitromethane, or methane (fart gas)?
"I don't play well with others, it seems others have a problem with losing!"
UBETRUN is offline
post #3 of 14 Old 08-27-2007, 06:45 PM Thread Starter
Methanol, sorry
Go big or go Home
2004 YFZ 450
20" Maxxis Razr
FMF Powercore 4
93pile is offline
post #4 of 14 Old 08-28-2007, 11:22 AM
Originally Posted by 93pile
Methanol, sorry
If you have epoxy porting in your head, you need to coat it and cross your fingers. Your carbs and petcock have to be upgraded to run alky, it takes about 1.5x as much fuel as gas. You'll want to decrease your spark plug gap to .020-.022 for better burn but other than changing your oil and running gas through the carbs at the end of the day to purge them, no other changes needed.
UBETRUN is offline
post #5 of 14 Old 08-28-2007, 02:51 PM Thread Starter
Is it worth it? or don't you get enough power to make it worthwhile?
Go big or go Home
2004 YFZ 450
20" Maxxis Razr
FMF Powercore 4
93pile is offline
post #6 of 14 Old 08-28-2007, 07:05 PM
It is absolutely worth it, the motor runs cooler and makes more power, especially on the bottom end of the rpm range.
UBETRUN is offline
post #7 of 14 Old 08-28-2007, 07:14 PM
JJONES660's Avatar
UBETRON...HAVE you messed with E85 at all yet?
yamaha for life
JJONES660 is offline
post #8 of 14 Old 08-29-2007, 07:07 AM
No I haven't.
UBETRUN is offline
post #9 of 14 Old 08-29-2007, 11:21 AM Thread Starter
So, is there a place to buy a kit? or do you have to get all the parts sepertally? and what all is needed, even if your head isn't ceramic coated?
Go big or go Home
2004 YFZ 450
20" Maxxis Razr
FMF Powercore 4
93pile is offline
post #10 of 14 Old 08-29-2007, 07:03 PM
I don't know anything about converting a YFZ carb but know there are kits available for FCR carbs. Call Kenz Cycle Tech and ask him about converting the YFZ's FCR, he has a lot of YFZs on alky. If the YFZ's FCR carb is like the Raptor 39mm FCRs, it should be around $100 for the parts to convert one carb.
To increase fuel flow, replace the stock petcock with a Pingle, they are available directly from Pingle and many of the site sponsors are dealers for them. An upgraded petcock is around $100.
Once you convert your carb and upgrade your petcock, it's just a matter of remembering to purge the carb and change the oil at the end of the day. You don't need any special motor work or ceramic coatings.
UBETRUN is offline
post #11 of 14 Old 08-29-2007, 10:45 PM Thread Starter
sweet, now where can you get methanol?
Go big or go Home
2004 YFZ 450
20" Maxxis Razr
FMF Powercore 4
93pile is offline
post #12 of 14 Old 09-09-2007, 08:46 PM
lowbaby is offline
post #13 of 14 Old 09-09-2007, 08:50 PM
I was asking this same question on another fourm. what about ethanol or some of the oxygenated fuels?
lowbaby is offline
post #14 of 14 Old 09-09-2007, 09:50 PM
Originally Posted by UBETRUN
Methanol, sorry
I'll second that.. I had JB weld in my custom manifold and the alky turned it into JB jello. The only thing I'd like to add I think you are a bit low on the amount of alky needed.... I run alky and need 2.5 times as much to run right, not 1.5.
MetalAlien is offline
need help with a 686 0n methanol with35mm fcr's jetting redarrestor Yamaha YFM660R Raptor (2001-2005) 0 01-30-2004 07:01 AM
Methanol Conversion Kit, FCR Carb bluedogrider Yamaha YFZ450/450R (2004-Present) 23 01-28-2004 10:56 PM
Jetting for Methanol - still a mystery. velocity111 Yamaha YFZ450/450R (2004-Present) 21 01-20-2004 03:38 PM
Methanol or Ethanol jets daddogrider Yamaha YFZ450/450R (2004-Present) 0 01-05-2004 12:51 PM
