high rev problem - Yamaha ATV Forum
post #1 of 11 Old 08-26-2005, 12:37 PM Thread Starter
high rev problem
When de engine is semi cold it revs fine.
But when the engine heats up it starts to sputter around 3/4 throttle.
Went in al directions with the jetting.
So I am thinking electrical.
Someone said ignition, is this possible?
Could it be the rectifier, witch is gone because the last time I checked it fried the headlights in 2 seconds.
I run without the lights.
Have a CBR battery.
Light switch on or off, no diff.
Any help would be appreciated.
Thanx..
ronnieb is offline
post #2 of 11 Old 08-26-2005, 01:20 PM
Send a message via AIM to ex_rider Send a message via MSN to ex_rider Send a message via Yahoo to ex_rider
i am having the same problem at full throttle it almost feels like a rev limitor but you can tell it is not so i took the carb off and looked at the jets changed my piolet from the 42 to a 45 and now threw the hole throttle its running terrible and it seems like it wants to die throwing flames sputtering you name it this quad is not running right and i cant figure it out
"paint" "somebody gonna get hurt really bad, somebody"
ex_rider is offline
post #3 of 11 Old 08-26-2005, 02:50 PM
Send a message via AIM to mxthunder
Could be the tps or the rectifier messing up
04 YFZ450 - WR crank, oil mod, CP 13:1 piston, Full Yosh TRS Ti pipe, hotcams intake, cam mod, YZ clutch mod, GYTR basket, FCI, 1" lowering peg nerfs, LSR axle, Pro tapers and Housier +1" stem, PRM desert grab bar, AC bumper, XCR tires and more 175M NCVQ #5 50p | 2010 YFZ450X - HMF Tuner, PRM bolt-ons, Aluminum airbox + K&N Filter
mxthunder is offline
post #4 of 11 Old 08-26-2005, 04:12 PM Thread Starter
TPS is disconnected
ronnieb is offline
post #5 of 11 Old 08-26-2005, 05:18 PM
this may sound like a stupid ? but i just bought a yfz but what is a tps
ex_rider is offline
post #6 of 11 Old 08-27-2005, 03:22 AM Thread Starter
Could it be the stator?
ronnieb is offline
post #7 of 11 Old 08-27-2005, 05:41 AM
Originally Posted by ex_rider
this may sound like a stupid ? but I just bought a yfz but what is a tps
TPS is a throttle position sensor.
Charlie Don't Like Trikes
maggiesboy is offline
post #8 of 11 Old 08-27-2005, 10:44 AM
Re: high rev problem
Could it be the rectifier, which is gone because the last time I checked it fried the headlights in 2 seconds.
Have a CBR battery.
thanks..
Its either something electrical or rich jetting. How far did you lean the main. An engine will richen up as it goes from cold to hot. Better atomizing of fuel. Thats why you need to choke the motor when its cold. The motor also typically richens up as the RPM's get in the upper ranges. Less of a load on the motor means that it needs less fuel.
jt911 is offline
post #9 of 11 Old 08-27-2005, 01:43 PM Thread Starter
went from 172 to 185 on the main in steps of 3
48 to 52 on the pilot
yz needle clip 3 to 6
fuel screw 1/2 to 31/2 turns
cammod,drd slip-on,aftermarket intake(ronwoods style),twinair filter, no lid
so I am thinking electrical.
Alternator or stator, or something else?
Alternator is dead but I don't use the lights, but can this be the problem for the stuttering.
If there are more than 3 wires I am lost with the electrical stuff.
so help me out please.
ronnieb is offline
post #10 of 11 Old 08-27-2005, 07:04 PM
i have the same problem, you have to put the headlights back on, its a stator problem. Talk to Bob at Magnolia tractor and he will hook u up with a rectifier kit for 50 bucks. I race mx and i still have my headlights on because of this problem
YFZ450, Pro Taper SE, X-factor nerf bars, pro design kill switch, uni air box vents, LSR DC-4 a-arms,RPM dominatorII axle, PEP ZPS shocks,20in mx holeshots up front, 18in kenda klaws on the rear. Baffle out. Custom Gloss black rims.
RippinRaptor55x is offline
post #11 of 11 Old 08-27-2005, 09:30 PM
Originally Posted by RippinRaptor55x
I have the same problem, you have to put the headlights back on, its a stator problem. Talk to Bob at Magnolia tractor and he will hook you up with a rectifier kit for 50 bucks. I race mx and I still have my headlights on because of this problem
You mean resistor kit don't you?
jshtex is offline
01 Warrior starting problem/dying when warm problem. Pokey Yamaha YFM350 Raptor/Warrior ('87-Present) 15 02-23-2013 05:51 PM
Problem high rpm MarcMad Yamaha YFM350 Raptor/Warrior ('87-Present) 8 11-13-2007 01:42 PM
Exhaust: Does High Power Always Cause High Decibels? Oregon Raptor 700 Yamaha YFM700R Raptor (2006-Present) 20 01-16-2007 06:52 PM
Jetting problem, high idle Knight2040 Yamaha YFS200 Blaster ('88-Present) 11 12-02-2003 07:49 PM
