Compression How Much - Yamaha ATV Forum
This is a discussion on Compression How Much within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; How much compression should the YFZ have om...
Old 02-10-2005, 09:35 PM   #1
View Old Man's Photo Gallery(0)
Default Compression How Much
om
2005 White/Red YFZ450
Dr. D full System
CP 12.5:1 Piston Kit
Hot Cams
GYT-R Jet Kit
Alba Pro Flow Kit
Zipty Fuel Mixture Screw
Airbox lid Removed
GYT-R Aluminum A-arm Skid Plates
GYT-R Sport Front Grab Bar
GYT-R Aluminum Engine/Frame Skid Plate
Old Man is offline   Reply With Quote
Old 02-11-2005, 04:13 AM   #2
View Aussiequadrider's Photo Gallery(0)
11.9:1
Geoff.
Yfz 470. Hot cams, Vortex cdi, Sparks, Peps, Power now, Lsr (axle, stem & lt arms), renthal, A/C pro peg nerfs & bumper, dampener. K/N, klaws, douglass beads, ASV levers, Jet4power. Tucker Swinger.
Pred 500
Pred 90
Suzuki lta 50
Aussiequadrider is offline   Reply With Quote
Old 02-11-2005, 04:43 AM   #3
View YELLOW400RIDER's Photo Gallery(0)
Quote: Originally Posted by Aussiequadrider
11.9:1
Geoff.
hes talking about "kicking compression" the compression (psi) the motor shows when doing a compression test. sorry i dont know the answer
former honda rider turned YFZ450 addict!!!!
YELLOW400RIDER is offline   Reply With Quote
Old 02-13-2005, 02:20 AM   #4
View patha's Photo Gallery(0)
Last I heard you cannot properly check the compression, because it has an auto-decompression which aids in starting. Best to do a leak down test, its better anyways since you can pinpoint any problems a little easier.
YFZ450
Full Yosmimura TRS Comp Series, K & N Pro Flow Kit, Ac Nerfs, Trailtech HIDs, Tag T2's, shockwears
patha is offline   Reply With Quote
yfz 450 compression test
how much compression does a yfz 450 have
how much compression should a yfz450 have
how much compression should a yfz 450 have
how to do a compression test on a yfz450
yfz 450 has 60 psi of compression
yfz 450 compression psi
how much compression should a 04 yfz 450 have
how much compression should an 1999 banshee engine have
60 psi compression on yfz450
how much compression should a ktm exc 450 have
11-1 compression ???? CRAPTOR Yamaha YFM660R Raptor (2001-2005) 2 03-05-2005 09:05 AM
150/120 compression NYC350CC Yamaha YFZ350 Banshee (1987-Present) 14 01-31-2005 03:24 PM
Compression Waz Up Yamaha YFZ350 Banshee (1987-Present) 6 12-14-2004 03:28 AM
compression patha Yamaha YFZ450/450R (2004-Present) 6 12-05-2004 02:32 AM
12.5:1 compression GlamisBound Yamaha YFZ450/450R (2004-Present) 2 04-13-2004 09:49 PM
