Compression Test question - Yamaha ATV Forum
This is a discussion on Compression Test question within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; i got my bike all apart and want to do a compression test on it. i know the compression ratio is 11.9:1 but thats not ...
Old 02-08-2005, 02:19 AM   #1
View sparky80's Photo Gallery(0)
Default Compression Test question
i got my bike all apart and want to do a compression test on it. i know the compression ratio is 11.9:1 but thats not what im looking for. when you stick a compression tester, whats the PSI supposed to be? ive looked all over the place and can't seem to come up with it anywhere. anybody know the specs for this? im guessing its gotta be at least 150 PSI, if not a lot more. i've yet to stick my tester on there... id like to know what it is first beforehand. thanks!
Phil. 2:10-11
2005 YFZ 450 (sold)
2004 Yamaha YZF R6... not stock!
VERY FAST!!
2000 Yamaha YZF R6 trackbike... fun fun!!
sparky80 is offline   Reply With Quote
Old 02-08-2005, 10:15 AM   #2
View Thumper 660R's Photo Gallery(0)
The problem with the YFZ is that it has an auto decompression release to lessen the strain on the starter. This device gives you inaccurate readings when using a Pressure tester because the engine rotation is slow. When the engine speeds up the auto decompression is disabled.
What you need to do is either
1. Disable the auto-decompression
or
2. Perform a leak down test.
I would like to know the details of both if someone has them. I have only heard people mention these two things not talk about them in detail. Any one else have some insight on this issue?
2004 YFZ450 White / Red
HMF Cherry Red Full Exhaust
Cam Mod
AC Nerfs
Holeshot XCR's
PD Kill switch
Full PRM Skids
AC Front Bumper
Denton Steering Stabilizer
PRM Grab Bar
Pro Design Kill Switch
Extended Thumb Throttle
SOLD
2002 Black and White Raptor
FMF Power Core IV
Shredders on douglas beadlocks
EHS Air lid cover
+4 lonestar axle
Thumper 660R is offline   Reply With Quote
Old 02-08-2005, 06:19 PM   #3
blwettstein's Avatar
View blwettstein's Photo Gallery(0)
i done it on my old honda and it had 100 psi.me brothers 450r had around 120 i believe.so i wouldn't hink it would be anymore thatn that
blwettstein is offline   Reply With Quote
Old 02-08-2005, 09:05 PM   #4
View nickklufas's Photo Gallery(0)
...thats a honda...and we all know that blue is faster...
Golden YFZ #13 D-34 Racing!
Powder coating stuff for what it costs me if anybody is interested! Shoot me a PM!!!
nickklufas is offline   Reply With Quote
Old 02-09-2005, 10:17 AM   #5
I dont know about the hondas but I do know that you cannot get an accurate reading with a compression tester on a YFZ without disabling the decompression release or performing a leakdown.
Cam Mod
AC Nerfs
Holeshot XCR's
PD Kill switch
Full PRM Skids
AC Front Bumper
PRM Grab Bar
SOLD
FMF Power Core IV
EHS Air lid cover
+4 lonestar axle
Old 02-09-2005, 10:05 PM   #6
View bluenova's Photo Gallery(0)
On my bike I ran a compression test before the cam mod and got 140 psi and then after I did the cam mod and the decompressor is retimed with the cam the cranking compression dropped to 90 psi. If you have a yz dirtbike cam with the taller decompression pin the numbers will be lower.
2004 blue yfz, Dr D exhaust, Hot Cams, Ron Woods intake w/airbox, 15T sprocket, Klaws
1300ft, 172main, NCVQ 3rd, 45pilot, 2turns, 35 leak jet
bluenova is offline   Reply With Quote
Old 02-10-2005, 12:25 PM   #7
True, but you get so much leakage from the decompression pin you are not getting a true reading of the compression from the rings. If your rings are shot you are still going to get about the same reading on a compression tester because the leakage from the decompression release is the path of least resistance.
Only way to truely tell is to perform a leakdown. This is why the shop manual or the owners manual does not state a number for a compression tester. Ask any reputable shop and they will tell you the same thing.
Honestly, if you disable the decompression pin you would probably be reading around 190psi im guessing.
Here is a halfway article on this
http://www.ppbb.com/scgi-bin/boards/...ames;read=6923
Cam Mod
AC Nerfs
Holeshot XCR's
PD Kill switch
Full PRM Skids
AC Front Bumper
PRM Grab Bar
SOLD
FMF Power Core IV
EHS Air lid cover
+4 lonestar axle
Old 02-10-2005, 05:55 PM   #8
thats what i was using is a snap-on leak detector
yfz 450 compression test
yfz 450 compression
yfz450 compression
yfz compression test
2004 yfz 450 compression test
ltr 450 compression test
yfz450r compression test
yamaha yfz 450 compression
2004 yamaha yfz 450 compression
yfz 450 compression psi
yamaha raptor 660 compression test reading
how much compression is my yfz450 06 suppost to have
compression test question need help asap yamahalover11 Yamaha YFS200 Blaster ('88-Present) 5 09-06-2005 12:01 PM
compression test rswrookie Yamaha YFM660R Raptor (2001-2005) 5 03-29-2005 09:23 PM
Compression Test canadianbanshee Yamaha YFZ350 Banshee (1987-Present) 10 03-22-2004 09:13 PM
Compression test DREWS SHEE Yamaha YFM660R Raptor (2001-2005) 3 08-10-2003 05:49 PM
Compression test Warrior Yamaha YFZ350 Banshee (1987-Present) 5 02-11-2003 10:05 AM
