Howcome the YFZ450 is much faster than the 400ex? - Yamaha ATV Forum
This is a discussion on Howcome the YFZ450 is much faster than the 400ex? within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; I was thinking why the 450 is much faster than the honda 400 ex. It`s just a few cc`s more and a litlle bit lighter....
Old 12-24-2004, 06:08 PM   #1
View tudo808's Photo Gallery(0)
Default Howcome the YFZ450 is much faster than the 400ex?
Ride it like you stole it
tudo808 is offline   Reply With Quote
Old 12-24-2004, 07:08 PM   #2
View The J's Photo Gallery(0)
Lets see here: Why is the YFZ is faster than the 400ex?
1. The 400ex was designed how long ago?
2. YFZ has DOHC, EX has SOHC
3. The YFZ has extra 39cc
4. If I remember correctly the YFZ has a thinner piston skirt and a lighter piston all together.
5. Fourstroke technology has really increased in the time since the 400ex was released.
6. It's a Yamaha. Just Kidding
Over the past few years with the motorcycle and ATV industry steering away from two-strokes more R&D has been put into four-strokes allowing for larger numbers out of similar displacement engines. My uninformed $0.02 worth.
J
YFZ 450
The J is offline   Reply With Quote
Old 12-24-2004, 07:31 PM   #3
View Foxracin's Photo Gallery(0)
J
Pretty much sums it up right there.
02 XC Raptor
AtvNC.com
Foxracin is offline   Reply With Quote
Old 12-24-2004, 07:35 PM   #4
View creechfan's Photo Gallery(0)
you prety much summed it up!
....allso the YFZ motor revs higher, fasterer and harder because of the reasons above....makin' it move past the HAHAhonda JKJK....honda makes a great bike....
creechfan is offline   Reply With Quote
Old 12-24-2004, 07:58 PM   #5
Warrior's Avatar
View Warrior's Photo Gallery(0)
Isnt the 400 still just air/oil cooled?
Cruz/Warrior
'04 CR250r
'09 YFZ450r
, Stolen
'09 KTM 505 SX
Warrior is offline   Reply With Quote
Old 12-24-2004, 08:03 PM   #6
View NitrousGuy's Photo Gallery(0)
the fact that one is a sohc sesign, and the other is a dohc has nothing to do with being faster.
if anything, the dohc design has more of a paracitic loss because of the extra friction of the added camshaft .
The Original Michrider
Tug Hill Veteran '03, '04
NitrousGuy is offline   Reply With Quote
Old 12-24-2004, 08:33 PM   #7
View elliptic's Photo Gallery(0)
I dont know about that, isnt the 450r also sohc and I do believe its slower j/p
'04 YFZ 450 Red/White.
'03 KFX 400 Green.
elliptic is offline   Reply With Quote
Old 12-24-2004, 11:25 PM   #8
View ihaveobsessions's Photo Gallery(0)
yea the sohc dohc thing doesn't matter much. But the overall state of tune on the 400ex motor, which was taken from the xr400, which was taken from the xr350, is old. The xr350 came out in like 83 or something. The 400ex is a trail machine and the yfz is a race machine. the air vs water cooling thing is a factor although not a big one. A air cooled machine might be as fast as i liquid machine. The liquid keeps it at a consistent temp so the power is consistent.
ihaveobsessions is offline   Reply With Quote
Old 12-25-2004, 12:29 AM   #9
View John05raptor's Photo Gallery(0)
Yamaha > honda
John05raptor is offline   Reply With Quote
Old 12-25-2004, 12:39 AM   #10
View RPyfz450's Photo Gallery(0)
Yeah, I'm with you on this one. Older versus newer is a VERY lame explanation.
2004 YFZ450
RPyfz450 is offline   Reply With Quote
Old 12-25-2004, 04:59 AM   #11
View YFM350 RAPTOR's Photo Gallery(0)
J
Prolly get flamed but what is DOHC and SOHC?
['04 350 RaptoR]
YFM350 RAPTOR is offline   Reply With Quote
Old 12-25-2004, 08:05 AM   #12
View 450rydr's Photo Gallery(0)
Single Overhead Cam (SOHC)---Dual Overhead Cam(DOHC)
450rydr is offline   Reply With Quote
Old 12-25-2004, 09:43 AM   #13
View Rider 414's Photo Gallery(0)
I think alot of the 4 stroke technology is trickled down from high performance street bikes also. The big four have some insane 4 stroke motors in their sportbikes.
Its the state of tune that the 400 and 450 are designed for.
Rider 414 is offline   Reply With Quote
Old 12-25-2004, 10:11 AM   #14
View lantz's Photo Gallery(0)
i know nothing really, but i thought water cooled motors could be run far more efficiently (leaner) than same sized air-cooled motors...a more efficient, complete burn = more hp, yes??
also, separating the exhaust timing from the intake with the DOHC design allows for far mre flexibility, yes??...imagine doing the "cam mod" on a SOHC motor...rotating the cam once to the left/right would change the timing ov every valve, not just the intake or exhaust side....
Finally, materials strength and parts reliability has increased so much...imagine running a stock ex400 up to 11,000 rpm..and that's just the limiter...
my two cents....and it may be all it's worth
lantz is offline   Reply With Quote
Old 12-25-2004, 01:59 PM   #15
Older VS. Newer is a lame explanation?
I think it is a very reasonable explanation for more power being produced by the YFZ over the EX. The R&D put into small 4-stroke engines has acomplished a lot. The Yamaha engineers have engineered an engine that can withstand high RPM, severe abuse and be somewhat durable.
If you think about it the yz450f is better than the yz426f and so on. So with time things get better thats whats been happening all along. The 400ex was out and Yamaha one upped them with a faster lighter quad.
I don't quite understand you're argument of older vs. newer not being a valid explanation.
Merry Christmas
J
YFZ 450
Old 12-25-2004, 02:05 PM   #16
View lvracer36's Photo Gallery(0)
ccs dont mean sh1t, a piped yfz (450cc) will beat a piped DS (650cc), good ride on YFZ.
Venom powered YFZ
lvracer36 is offline   Reply With Quote
Old 12-25-2004, 03:35 PM   #17
View theblueYFZ's Photo Gallery(0)
also, the power to weight ratio is unbeliveable, the yfz doesnt evin wya more then 370 lbs.. the banshee wich is a 2 stroke and 2 strokes weigh less are 280 lbs.. dont get me wrong the honda is a great machine, tis reliable i ahd one but i also had about a grand or 2 into it.. pipes,416 kit etc.. the yfz is made spicificley for the trrack and is race ready out of the box it just needs nerfs and a teather kills switch, i prefer yamaha for obvious reaosns tho.. IMO the only good thing about honda is reliablity, but a piped 400 ex is a lot faster and snappyer then a stock one
01 rm250.. completely macked out for sale.. 1800 or b.r.o
theblueYFZ is offline   Reply With Quote
Old 12-25-2004, 05:43 PM   #18
View -LE-YFZ450's Photo Gallery(0)
DOHC- Duel over head cam, SOHC - Single overhead cam..
The YFZ has 5 valves, and 400ex 4 maybe?..
When in doubt, throttle out
Riding on -
2004 LE YFZ450
-Sparks
-hardstyle K&N airfilter kit
-Sparks needle 4th clip 175mj
'87 Bigbear 350, supertrap, K&N, DynoJet, warn winch, .040 over weisco, port/polished.
-LE-YFZ450 is offline   Reply With Quote
Old 12-25-2004, 06:35 PM   #19
yea the older vs newer pharse is true. I bet even if they tried back in the eighties when the ex's motor was designed, they couldn't have got near the power out of a 450cc fourstroke that the yfz is making now.
Old 12-26-2004, 03:07 AM   #20
I don't want to dwell too long on what's lame and what's not. I thought it was the most non descript explanation of the semi obvious.
2004 YFZ450
how much faster is 450r than 400ex
how to make yfz 450 faster by loosing
is a banshee faster than a 400ex
how much faster is a 450 then a 400ex
is yamaha the only 1 who makes a atv bigfer than a 450
is a kfx450 faster than a trx400
is a yamaha 450 bigger than a 90
400ex or 450 whats faster
whats faster a yfz 450 or 400 ex
how to mack a 2000 450 honda ex go faster
honda 400 ex is slow
whats faster a trx700 or 400ex
faster 400ex Wolverine21 Other Models/Brands 15 06-07-2003 07:29 PM
