If your YFZ turns over but won't start... - Yamaha ATV Forum
post #1 of 15 Old 02-17-2004, 02:14 PM Thread Starter
screamin96's Avatar
put more gas in the tank.
screamin96 is offline
post #2 of 15 Old 02-17-2004, 02:16 PM
uh can i assume a step by step video of the so called "gas pouring process" will follow???? ;)
Kenz Cycle Tech
www.kenzcycletech.com
480-962-1714
www.yfzunderground.com
edgerat is offline
post #3 of 15 Old 02-17-2004, 02:21 PM
Dextreme's Avatar
I wound suggest making this a sticky.
SandLakeDuners.com
Short video of me
Dextreme is offline
post #4 of 15 Old 02-17-2004, 02:25 PM
Re: If your YFZ turns over but won't start...
and if theres gas in the tank?
try turning the gas on dummy!!!
04 RAPTOR 660,blue/silver powermadd handgards,protaper atv high bend handlebars,kenda knarly rear tires, ALX racing nerfs
www.piczo.com/TWOLF-DESIGNS
blue 02 griz 4x4 with 4 bearcalws,blue le grizzly windshield
Thanks to highgear sports
T-WOLF is offline
post #5 of 15 Old 02-17-2004, 02:27 PM
Warrior King's Avatar
Send a message via MSN to Warrior King
Hahaahahaha
Need a dirt bike :(
Warrior King is offline
post #6 of 15 Old 02-17-2004, 03:59 PM Thread Starter
screamin96's Avatar
I found out that even though a YFZ appears to have gas in the tank, quite a bit of gas also, it will not reach the petcock.
And yes, a how-to video is on the way.
post #7 of 15 Old 02-17-2004, 06:09 PM
i cant wait this has baffled me for a while
04' YFZ 450 Blue/White
Cleveland, Ohio
Cam Mod
GYT-R 13:1 Piston
Curtis Sparks Full System
Trail Tech -4 Flywheel
Ron Woods Intake
X Factor Nerfs
Pro Design Kill Switch
Hiper Wheels w/ Black Rings
Kenda Klaw MXR
Kenda Klaw MXF
Billet Decomp Plug
YFZ930 is offline
post #8 of 15 Old 02-17-2004, 08:30 PM
We found that if a valve spacer comes loose, and sits in the space holder wrong you cant start it for beans.
We finally remembered BLUETRAXX and another guy had that problem, we checked the spacer and sure enough and an intake spacer slipped up sideways, and caused a slight pressure leak.
It will never start till you fix theat.
so if you did a piston change and it wont start, check the valve spacers, they move around WITHOUT removing the spacer covers.
just a tip.
The surest way to learn, is the hard way. And we're sure learning hard.
MOTTO: ) Don't Automatically Believe Everything You Read 2) Always "Explore The Opposite" 3) Never Fear Failure
4) When in Doubt, Go For It !! 5) Never Put Limits On Your Imagination 6) Spill the beans 7) Let the cats out of the bag. www.eskimo.com/~daddog/index.htm
daddogrider is offline
post #9 of 15 Old 02-17-2004, 08:37 PM
Has happened many times to me... get to the top of sand mountain and the damn thing starts to die WTF?
Go back to the trailer, check and yep - plenty of fuel in there. Filler up and walla... runs just fine.
Edit: It happened on K&T's dyno too. None of us could figure it out.
selector
"You disobey me. You puppies." Lord Humungus
Chief Develeloper: Sanford & Son Racing
Co-Developer: Plumber's Crack Drag Pipes.
selector is offline
post #10 of 15 Old 02-17-2004, 09:05 PM Thread Starter
screamin96's Avatar
Good, I don't feel so bad now. :D
Guess I'm used to the Banshee, where it is BONE DRY before it dies.
post #11 of 15 Old 02-17-2004, 09:08 PM
But it sure scares the hell out of ya for a minute don't it? What I do?
selector
selector is offline
post #12 of 15 Old 02-18-2004, 05:03 AM
Send a message via MSN to wildtxn
yeah, wait till you get somewhat dry and riding wheelies and the level falls past the petcock intake and all your running on is fuel in the float bowl. stops a wheelie pretty fast if not sending you vertically forwards.
YFZ450
*** Completely Maxxed Out***
wildtxn is offline
post #13 of 15 Old 02-18-2004, 03:11 PM
been there at 20 mph on the grizz had the front end up nice and WAM it dies ill tell u that braking is not to be fooled with it WILL put u over the bars!
T-WOLF is offline
post #14 of 15 Old 02-18-2004, 05:30 PM
Will it hurt anything to run with it on reserve from the get go? I'm racing in the Adelanto GP next week and wondering if I'll have enough fuel. Don't want it cutting out with 1/2 a tank left. So I figured why not just put it on reserve before I start. I'm guessing the "reserve" inlet is down lower than the "on" inlet - right? Is that the only difference?
- Scott
kramertech is offline
post #15 of 15 Old 02-18-2004, 05:53 PM Thread Starter
screamin96's Avatar
You can run it on reserve with no problem, you jsut won't know when you're getting low on fuel till it's too late. :)
HELP !!! having trouble sliding quad through turns truklvr2001 Motocross & Freestyle (MX, FMX) 23 12-18-2004 04:48 PM
My fan never turns on! 2fast4u Yamaha YFZ450/450R (2004-Present) 17 06-14-2004 01:14 PM
stock air screw turns? JasonRiharb660 Yamaha YFM660R Raptor (2001-2005) 6 09-02-2003 07:10 PM
What tires slide good in turns? Rapter Tires & Wheels 11 05-11-2003 02:39 PM
