Throttle Override System (T.O.R.S.) ???????
This is a discussion on Throttle Override System (T.O.R.S.) ??????? within the Yamaha YFZ450/450R (2004-Present) forums, part of the Performance /Technical category; I've been contemplating moving to a twist throttle however I'm not able to get a straight answer from Motion Pro or Alba on the methodology ...
Old 09-02-2003, 05:03 PM   #1
View FAST1's Photo Gallery(0)
Default Throttle Override System (T.O.R.S.) ???????
I've been contemplating moving to a twist throttle however I'm not able to get a straight answer from Motion Pro or Alba on the methodology used to override the TORS system on the YFZ. The thumber has this hooked into the mechanism and the aftermarket Motion Pro twists don't have anything electircal to them.
FROM THE MANUAL:
This model is equipped with a throttle override system as a safety device that operates according ot the positions of the throttle switch and carburetor switch and stops the flow of electricity from the C.D.I. unit to the ignition coil to stop the engine if the carburetor or throttle cable malfunctions during operation.
A- Normally, both the throttle switch and carburetor switch are open when the throttle lever is free and closed when the throttle lever is free.
B- If either the throttle switch or the carburetor switch is closed due to a malfunction, the throttle override system operates to stop the engine.
So my question is for those of you that have converted to a twist throttle.
How have you compensated for this mechanism? and what electrically parts are necessary to move from a thumber to a twist???
Help!
04 YFZ 450
GYT-R +1" A-Arms & rear DMI 1" billet spacers GYT-R Swing Arm Skid, Engine Skid, Front Bumper, K&N Filter,EHS Racing Lid, YZ Needle, Trail-Tech X bars and Clamp/Computer, Spider Grips / Wired- 22 guage, Motion Pro Twist Throttle, Jardine full exhaust
FAST1 is offline   Reply With Quote
Old 09-02-2003, 05:38 PM   #2
View edgerat's Photo Gallery(0)
i just soldered the two together coming into the thumber. Works great.
Kenz Cycle Tech
www.kenzcycletech.com
480-962-1714
www.yfzunderground.com
edgerat is offline   Reply With Quote
Old 09-02-2003, 05:59 PM   #3
View Bluetraxx_member's Photo Gallery(0)
disconnect the the plugs that he wires from the tors on the carb connects into the harnes and then make a complete circuit by connecting the two wires from the harness. There are more sano ways of doing it but it is hard to explain.
full blown '02 Mx banshee
---'03 tughill veteran with the scars to prove it---
---'04 tughill veteran this time with no scars ----
Bluetraxx_member is offline   Reply With Quote
Old 09-02-2003, 06:14 PM   #4
are you using the 01 YZ Twist thorttle? what degree rotation is it ?
the motion pro CR for the YFZ calculates to about a 70 degree twist.
04 YFZ 450
Old 09-02-2003, 06:15 PM   #5
I am using an 03 YZ throttle. I dont know what degree it rotates but 70 sounds about right. I hate the 1/4 turns that is why I got this one.
Isaac
Kenz Cycle Tech
480-962-1714
Old 09-02-2003, 06:16 PM   #6
what about the circuit on the carb? did you solder those also?
04 YFZ 450
banshee throttle override system
throttle override system yamaha
yamaha throttle override system
yamaha banshee throttle override system
tors throttle override system
yamaha tors system
banshee tors override
throttle override system banshee
how do you over ride the t.o.r.s. system on 2007 yamaha apex
yfz 450 tors
yfz450 throttle override system
Raptor Duneable override tran's 344PV Yamaha YFM660R Raptor (2001-2005) 16 07-30-2007 08:14 PM
override trans SCHOLLE Yamaha YFM700R Raptor (2006-Present) 1 06-27-2007 02:31 AM
660 Throttle What other quads use the same Throttle. banshee raptor010101 Yamaha YFM660R Raptor (2001-2005) 8 01-13-2007 04:09 PM
Override? blueblast02 Yamaha YFZ350 Banshee (1987-Present) 12 07-15-2003 05:24 PM
