advance timing - Yamaha ATV Forum
advance timing
This is a discussion on advance timing within the Yamaha YFZ350 Banshee (1987-Present) forums, part of the Performance /Technical category; I was wondering what was the difference between advancing the timing +4 or +7? Dose the +7 just have more top end or do you ...
Old 10-22-2002, 10:54 PM   #1
View yamaha01us's Photo Gallery(0)
Default advance timing
I was wondering what was the difference between advancing the timing +4 or +7? Dose the +7 just have more top end or do you have to change something or what?
2001 Banshee, Toomey T5s, Uni airfilter, XCR Holeshots, Pure Sport Realtors, Renthal Handlebars, Cascade Headlight Covers, Toomey Super Cooler Radiator, Cool Head w/21cc domes,V-Force reeds
yamaha01us is offline   Reply With Quote
Old 10-22-2002, 11:22 PM   #2
screamin96's Avatar
You should only advance the timing to 7 degrees if you run your motor for short periods of time, like in drag racing. It will also run a lot hotter and actually start to hurt performance at 7 degrees. Use +4 for normal use.
Old 10-23-2002, 04:31 AM   #3
View meat's Photo Gallery(0)
advancing your timing more than +4 is not recommened unless you have a "built" banshee. And if you have a "built" banshee than your builder will recommend the timing advance for that particular motor.
Dan at Alloyspecialties CNC's adjustable timing plates that go up to +15 and said something I found pretty funny but pretty true. He said he gets asked by guys "what should I set my timing at". And his reply was "If you have to ask this question then you shouldnt be adjusting the timing at all". :cool:
Stay away from +7 unless your drag racing serioulsy, not just drag racing your buddies once in a while.
+4 is good enuf for most piped banshees any thing more can be catastrophic.
BTW I ride a modded banshee setup for MX and agg trail riding, and my engine builder recommened my timing set to only +2. Like screamin' said, more timing advance will produce more heat, and could cause detonation. More timing advance will make for a peakier powercurve, and +2 advance will produce nearly the same amount of HP as a +4 advance without the dreaded heat buildup and detonation troubles along with making the powerband more ridable for everyday trail riding and MX racing.
meat is offline   Reply With Quote
Old 10-23-2002, 12:06 PM   #4
View T5_BANSHEE's Photo Gallery(0)
you shouldnt run anything past +5 or 6 unless you are runnging alky. The alky needs more timing. Your timing alo depends on your porting. Most drag guys running alky run around +10, however if your bike is set up for it you could run +15 without a problem.
'01 BANSHEE, CPI Inframes, WB Boost bottle, Dual K&N filters, Trinity Stage IV Timing Plate, Nitrous Oxide(20hp jets)
Control is just an illusion of the mind.
T5_BANSHEE is offline   Reply With Quote
banshee timing advance
banshee advanced timing
yamaha banshee timing advance
banshee timing advance 8 degrees
how do you advance the timing on a quad
how to advance the timing on a yamaha j
yamaha banshee timing for drag
how do i set the timing on my banshee
stock banshee how much advance timing
what degree should an adjustable timing plate be on a 2002 banshee
banshee timing -1
can i advance banshee timing to assist starting issues
reasons for timing advance jilted Yamaha YFZ350 Banshee (1987-Present) 14 10-10-2003 02:28 PM
timing advance needed with cam and piston change? mondo128 Yamaha YFM660R Raptor (2001-2005) 13 05-30-2003 03:33 PM
Raptor Timing Advance Hi Velocity Raptor Yamaha YFM660R Raptor (2001-2005) 14 11-14-2002 08:11 PM
CURTIS SPARKS TIMING ADVANCE mxraptor Yamaha YFM660R Raptor (2001-2005) 2 05-25-2002 09:46 PM
advance timing key darlingtonraptor Yamaha YFM660R Raptor (2001-2005) 3 12-31-2001 06:14 AM
