Adjust timing on my banshee - Yamaha ATV Forum
post #1 of 5 Old 10-02-2002, 12:31 AM Thread Starter
Recently I've noticed a clicking noise coming from my engine when it's running. A friend of mine who seems to know what he's talking about suggested I adjust my time, apparently it's "off." I have only two questions. What is my timing, and how do I adjust it?
-feti
feti is offline
post #2 of 5 Old 10-02-2002, 10:36 AM
Your friend is mistaken. The only thing that relates to timing that I can think of that would make a ticking noise is the pickup coil. If it got bent, it could contact the flywheel as it spins around. I don't think it would even run if that happened though.
Can you describe the ticking noise in more detail?
BTW, the timing cannot be adjusted it is fixed. It can be changed with a different flywheel key or adjustable timing plate but the stock Banshee has no means of adjustment.
2002 Banshee - CPI, Noss Head, etc...
1995 Warrior
WyoDuner's Dune Review Site and SAND DUNING Forums
WyoDuner is offline
post #3 of 5 Old 10-02-2002, 11:30 AM Thread Starter
When my engine is revved I can hear a clicking noise coming from the front of my engine. And I've also noticed lately, that if I put it in gear on a hill, the gear won't keep it from rolling backwards. It's as if it's almost not in gear. I can easly push it backwards when it's in first gear.
Maybe I'm mistaken from what I heard him say. He did work on a warrior my friend owns. He unscrewed something from the left-front side of the engine and was adjusting the pistons to that. Something with a line and a T or F on it? He had a gapper or something that looked like one, and was adjusting "I think" gaps in there. Something about the piston being off. Maybe he has his terminology wrong, but whatever he did improved the performance on my friends warrior. I think he was telling me I need to do the same thing to my banshee.
-feti
feti is offline
post #4 of 5 Old 10-02-2002, 10:29 PM
Your buddy was adjusting the valves on the warrior. No valves on da Banshee.
Could something outside the engine be rattling on your banshee that would make you think its coming from inside the engine? Does it tick all the time or only when your moving ?
meat is offline
post #5 of 5 Old 10-03-2002, 09:54 PM Thread Starter
Nothing that I know of. The only ticking sound other than one I can't locate, is my kick starter. It's a very distinguishing should coming from the engine. I guess I'll find out what's wrong, when it goes wrong.
-feti
feti is offline
What do you use to adjust your chain with? sd Yamaha YFM700R Raptor (2006-Present) 5 10-04-2007 09:35 PM
Banshee Pro Flow w/ K&N, Adj. Timing Plate, and Reed Spa 03LimitedEditionRaptor Parts for Sale 1 07-09-2007 09:20 PM
How do I adjust a KFX chain??? RAPTOR74 Other Models/Brands 6 02-03-2004 05:44 PM
Raise Compression, and Adjust timing Slightly Sttupid Yamaha YFZ350 Banshee (1987-Present) 4 06-18-2003 12:42 AM
pro design timing advancer for banshee jilted Yamaha YFZ350 Banshee (1987-Present) 6 06-26-2002 01:09 PM
