atf or oil in case banshee
This is a discussion on atf or oil in case banshee within the Yamaha YFZ350 Banshee (1987-Present) forums, part of the Performance /Technical category; hey guys wich is best for the shee atf fluidor oil .. i been runnig atf in mine i have a 406 vitto ported piped ...
Go Back   Yamaha ATV Forum - BlueTraxx.com > Performance /Technical > Yamaha YFZ350 Banshee (1987-Present)
Old 06-30-2009, 11:38 PM   #1
View greenskin77's Photo Gallery(0)
Default atf or oil in case banshee
hey guys wich is best for the shee atf fluidor oil .. i been runnig atf in mine i have a 406 vitto ported piped etc.
the other thing is my clutch is grabbing into gear while i do not release the handle.
it does this only when i am facing up a littil hill and am in gear holding the clutch handel in while revving it it will slowly bounce and then all of the sudden it will take off still having the lever in . anyideas.
greenskin77 is offline   Reply With Quote
Old 07-01-2009, 10:09 AM   #2
JTRAPTOR660's Avatar
View JTRAPTOR660's Photo Gallery(0)
Might need a pancake bearing installed. mine did that and come to find out my bearing was welded to the push rod. also i run type F in my drag bike.
You are only as fast as your bike/wife will allow you to be
2000 powdercoated blue shee
68mm pistons/396cc
trued/welded crank
hinson clutch kit
cut domes
35mm airstrikers
+8 swinger
complete Finally
JTRAPTOR660 is offline   Reply With Quote
Old 07-01-2009, 11:49 AM   #3
Default k
u lost me.. pancake bearing what is that? and push rod do you mean the bolt on the out side in the center of the cluch basket that adjust the clutch tension or do u mean the connecting rod on the crank wich i cant see having to do anything with the clutches.
thanks
Old 07-05-2009, 09:41 AM   #4
View tedd1's Photo Gallery(0)
Pancake Bearing.....replaces the stock clutch adjuster
tedd1 is offline   Reply With Quote
Old 07-06-2009, 10:47 AM   #5
tedd hit it on the head.
clutch adjuster/actuater
the bearing and adjuster tend to weld each other together due to heat. i guess its real common on banshees with a lil more hp then normal. if you know what you are doing with the motor then its a cheap fix if not you will have to pay labor charges on getting it done. but the bearing is only like 30.00 bucks.
68mm pistons/396cc
trued/welded crank
hinson clutch kit
cut domes
35mm airstrikers
+8 swinger
complete Finally
Old 07-06-2009, 10:48 PM   #6
Default k
i didnt even no they made such a thing.. but does it work ? did any of you guys use one or no of anyone that did.
but ifit works i am going to get one and i no how to put it in i just had it apart the other day checking stuff to see if clutches were stuck but all was ok .. so if this works then i will be getting it
Old 07-07-2009, 06:38 PM   #7
I just recently had one put in mine cause mine welded itself together. If this is your problem then this will fix it. are the bearing and adjuster stuck together?
68mm pistons/396cc
trued/welded crank
hinson clutch kit
cut domes
35mm airstrikers
+8 swinger
complete Finally
Old 07-07-2009, 09:51 PM   #8
Default k
well i didnt even chck that i didt even no about this untill now. if i rember i pulled the littil center bolt out and the bearing around it was still on it i didnt even try to take it off i say it was stuck if it was free it would have fell out when it hit the floor i ll have to ripp it aprt once again to make sure
Old 07-09-2009, 12:01 AM   #9
If the bearing and the rod(IE adjuster) are stuck together then they welded themselves due to heat. a pancake bearing or another adjuster set will do the trick.
68mm pistons/396cc
trued/welded crank
hinson clutch kit
cut domes
35mm airstrikers
+8 swinger
complete Finally
Old 07-09-2009, 04:23 PM   #10
View GrMeyer's Photo Gallery(0) Send a message via AIM to GrMeyer
does the grabbing go away after the bike it warmed up? if that is the case then they are warped clutch disks. But other then they just try to adj the clutch. My .02 on the fluid is I use Type F ATF. I have pulled my motor twice already from last year for mods and the trans looks like new. you will have to change the ATF fluild more but I like it better then any other oil in there. after all it is a trans. And ATF was made for a trans.
98 Shee w/+2+1BurgardArms w/YFZ 450 shocks.+4 Gforce axle.G-TravisRacingDuneport.Bored.50.FMF Fattys.Stock crabs w/Pods.Noss head w/20cc.Boysen Reeds. 05 660 Rapor w/Alba+2+1Arms w/Elka Dunes.+6LoneStar Axle.K&N No Lid. Trail Tech HID's, 14T. DMC Alien Dual Exhaust.P&P Head w/S&S Valves. Stage2 Hot Cam. 11.1 Wiseco piston. Steering stabilizer.
GrMeyer is offline   Reply With Quote
Old 07-19-2009, 02:08 PM   #11
Banshee Roost's Avatar
View Banshee Roost's Photo Gallery(0)
thumbs up
I really like the Honda HP trans oil. Really good stuff!
03 Black & Red Banshee - Pro Circuit Platinum Pipes,304 Silencers,Twin Air Power Flow Foam Filter Kit,ADA head 19cc domes,Carbon Tech top end reeds,Trinity Intake's,GYT-R Ignition,Kenda Gnarly tires,Fluidyne radiator,Engine Ice,Pro Design Impellar,PIAA light kit,DG Casesaver.
Banshee Roost is offline   Reply With Quote
Old 09-29-2009, 05:53 PM   #12
View 04rangerboy's Photo Gallery(0)
a guy at a local racing shop uses 1 Qt atf type f and 1qt sae 30 and it has seen some excellant results not sure why he use this combo but he said it works amazing
08' yfz 450 Velocity intake,k&n filter, jetted, no baffle, ceramic coated head pipe,9 paddle haulers.cascade gas cap,
01' shee k&ns, fattys, 8" swingarm, shaved head, wiseco power pistons, mild port, and some other power adders I dont tell about...
04rangerboy is offline   Reply With Quote
Bookmarks
banshee case jons99shee Yamaha YFZ350 Banshee (1987-Present) 4 05-08-2003 10:52 AM
lower case for banshee Smile_UAE Yamaha YFZ350 Banshee (1987-Present) 4 09-27-2002 06:54 PM
whats the hottest a banshee case gets???? nastyshee Yamaha YFZ350 Banshee (1987-Present) 1 08-01-2002 03:10 AM
Expense and time needed to fix hole in Banshee case? caz Yamaha YFZ350 Banshee (1987-Present) 2 07-26-2002 01:26 PM
How much oil does a banshee case hold a99wolverine Yamaha YFZ350 Banshee (1987-Present) 8 12-19-2001 02:02 PM
