4Mil Crank kit - Yamaha ATV Forum
4Mil Crank kit
This is a discussion on 4Mil Crank kit within the Yamaha YFZ350 Banshee (1987-Present) forums, part of the Performance /Technical category; I just twisted my stock 02 crank and messed up the top end too darn needle bearing washed it out... so i'm lookin at a ...
Old 06-25-2008, 12:40 PM   #1
View banshee440's Photo Gallery(0)
unhappy 4Mil Crank kit
I just twisted my stock 02 crank and messed up the top end too darn needle bearing washed it out... so i'm lookin at a 4 mil crank kit.. what sould i look out for or what will i need to change over what i was runnin with the stock crank... I have stock carbs jetted for fmf fattys and v-force2 reeds i have a cool head with 21cc domes a K&n filter and my timeing is +4 advanced.. I'm goin to get stock bore juggs and run that 4mil stroker crank set up what do i need to know???? Thanks Matt
2002 Banshee, FMF Fatties Turbinecore 2 silencers,Noss Machine cool head with 21cc domes,K&N, V-Force 2 reeds, Wiseco's prolite top end piston kit, 9 paddle haulers and Fast trekker Rears
banshee440 is offline   Reply With Quote
Old 06-25-2008, 03:33 PM   #2
Dextreme's Avatar
View Dextreme's Photo Gallery(0)
A year ago, I was in the exact same situation that you were. (needle bearings on the rod let loose)
I bought a hot rod 4-mil crank from Cascade Innovations that included the important TZ bearing. I then had my mechanic bore my sleeves to the next size and installed some Wiesco 795 series pistons. He then custom cut dome blanks for my cool head to get the clearance and compression I wanted (185psi).
I ran this set up with stock carbs for a year and was happy. Then I bought some 28pwk's and I am even more happy.
SandLakeDuners.com
Short video of me
Dextreme is offline   Reply With Quote
Old 06-26-2008, 11:26 AM   #3
Thanks dextreme for the info where should i start jettin if i'm goin to use my stock carbs for now with these mods...The kit comes with a spacer plate for the crank do i still need my domes cut like you had??? i'm goin to run 21cc domes for pump gas... And what are the tz bearings this crank is a hot rods welded and it comes with everything i need to do the whole motor seals, gaskets, pistons everything...Thanks
Old 06-26-2008, 01:31 PM   #4
You need to run one or the other. The cut stroker domes or the cylinder spacer plate. I would highly recomend running the cut domes over the cylinder spacer plate. When you move the cylinders up and it advances the port timings. They opean sooner because you physicaly moved the cylinders up 2mm by putting the spacer plate inbetween the cylinders. A 4mill stroker crank will cause the piston to fall 2mm farther down in to the cylinder at bdc and it will pop up out of the cylinder 2mm at top dead center. So that is why you need to run cut domes or a spacer plate. To keep the pistons from hitting the head. With a stock stroke banshee when the pistons are at bottom dead center the piston stops at the bottom of the transfer ports. With a 4 mill stroker the piston stops 2mm below the transfer ports. 4 mill stroker and 2mm spacer plate the piston stops 4mm below the transfer ports. Not the best situation for performance.
The best option is to have the cylinders ported for running a 4mill stroker crank with cut domes. That will make your banshee an animal. Porting changes when ports opean up and how long they stay opean. You do this by changing the size and angles of the ports.
Porting a 2 stroke engine is like putting a Camshaft in a 4 stroke engine.
A TZ or Max Load Bearing is a heavy duity bearing.
You should talk to Jeff at FAST he has the cheapest parts around. Probably could save you a few bucks and you wont have to run that spacer plate. You cant order from his web site you have to call and talk to him.
www.farmandsandtoys.com
josh
Old 10-21-2012, 02:21 AM   #5
4millbanshee's Avatar
View 4millbanshee's Photo Gallery(0)
grin 4 mill banshee question
hey there have a quesyion about 4 mill kits. you seem to know what u are talking about. now i got a weisco 4 mil kit with the long rods. this kit require that u space the head for the 2 mills of the piston that comes out. therfore it requirs u 2 use the 795 series pistons. the have bigger ports i guess shorter and raised the wrist pin. ports line up perfect but iffy about that big gasket. does this sound right? i put it all together thinking its not going to run. 60 over and a pretty heavy port. sent head out and got trinity cut. replaced all studs and nuts put it together run it on 110 and this damn thing RIPS so suprising . can u explain this? got v force 3 trinity 2 into 1 with 41 mm kehin with k&n im runnimg a 70 thousands jet. 35 pilot no advance timing (stock) trinity stage 4 pipes
THANK YOU SO MUCH FOR THE HELP!
4millbanshee is offline   Reply With Quote
Old 10-21-2012, 04:30 PM   #6
View 2004lebanshee's Photo Gallery(0)
1. This thread is over 4 years old man.
2. Im not sure I follow. I would get your domes cut so that your dont have to run a spacer plate. They are gheto and the're another place for a possible air leak. Check your squish and compression before you run it. Do you even need race gas? Was it ported for the 4 Mill or was it ported for the stock crank? Ditch the 2 in 1 carb set up. Get 2 PWK 35's or 33's.
421 Ported Serval, PWK 35 carbs, WCR promod tranny, F.A.S.T. Clutch, Noss Head custom domes , VF3 Reeds, Nology Coil w/ Hotwires,Shearer Inframes, +4 Stellar Swingarm, Leger A Arms Elka's, Lots more.
2004lebanshee is offline   Reply With Quote
what is a 4 mil banshee
banshee 4 mil crank
banshee 4 mil build
banshee 4 mil
4 mil banshee
setup for a 4 mil yamaha banshee
how much dose it cost to put new berrings in a 4 mill crank for a banshee
4mil drag banshee stock carbs jetting
what is a 4mil banshee crank vs normal
banshee crank keeps breaking 4 mill
4 mill stock banshee
do you look up banshee cylinders
WTT 370 +4mil Banshee $6,600 Invested Located in Michigan HAULIN_A$$ ATVs for Sale 8 05-05-2013 11:48 PM
hot rods 4mil stroker crank ? badass400ex Yamaha YFM660R Raptor (2001-2005) 14 02-25-2007 02:06 PM
Crank Went Out warriorfreak911 Yamaha YFZ450/450R (2004-Present) 4 05-20-2005 12:41 PM
WR Crank or 470 on YFZ crank EX 80 Yamaha YFZ450/450R (2004-Present) 3 08-10-2004 11:30 PM
crank ????? JBanshee Yamaha YFZ350 Banshee (1987-Present) 4 03-16-2003 10:12 AM
