Bleeding Brakes - Yamaha ATV Forum
post #1 of 5 Old 11-12-2006, 09:02 PM Thread Starter
Bleeding Brakes
I took apart the front end of my 01 banshee. Everything is back together the right way. I can't get the front brakes to work. i pump them what seems like a 1000 times, hold the lever in, and bleed both sides. i've done this for hours. I've tried opening every fitting on the lines to. Now when i open the bleeders, a steady stream comes out both sides. No Air.
Do i have a bad master front cylinder? They worked fine before i took them apart.
1antalbanshee is offline
post #2 of 5 Old 11-12-2006, 09:09 PM
screamin96's Avatar
Welcome to BT.
You might have a bad master cylinder. Are you doing one side at a time? Can you see any bubbles coming to the top of the master cylinder when you pump it?
screamin96 is offline
post #3 of 5 Old 11-13-2006, 12:23 AM
Warrior's Avatar
Send a message via AIM to Warrior Send a message via MSN to Warrior Send a message via Yahoo to Warrior
Go to ORiley's and buy a brake bleeder. Best money you'll ever spend. Leaving the bleeders cracked overnight will help gravity bleed also, I've had that work from time to time.
Cruz/Warrior
'04 CR250r
'09 YFZ450r
, Stolen
'09 KTM 505 SX
Warrior is offline
post #4 of 5 Old 11-13-2006, 04:17 PM Thread Starter
Yeah i'm seeing bubbles in the resevoir when i pump and also when i shake it. I was doing both at the same time for the most part. Pump, and then bleed both. Then when it seemed like one was done, i concentrated on the other only.
I thought about getting a bleeder. How much are they? And is it worth it?
post #5 of 5 Old 11-13-2006, 04:34 PM
screamin96's Avatar
They work good, and are about $30-$40. Here's one on eBay:
http://cgi.ebay.com/ebaymotors/Mityv...49153039QQrdZ1
bleeding brakes velocity-raptor Yamaha YFM660R Raptor (2001-2005) 8 07-05-2005 08:24 PM
Bleeding brakes Cvillecoldblood Yamaha YFS200 Blaster ('88-Present) 6 02-28-2005 02:43 PM
Bleeding brakes ondeeeznuts Yamaha YFZ350 Banshee (1987-Present) 14 08-23-2004 11:00 AM
Bleeding Brakes TTracinman68 Yamaha YFS200 Blaster ('88-Present) 6 11-09-2003 07:22 PM
