Overflow tubes leaking gas - Yamaha ATV Forum
This is a discussion on Overflow tubes leaking gas within the Yamaha YFZ350 Banshee (1987-Present) forums, part of the Performance /Technical category; My girlfriend's banshee recently started leaking gas out of both carbs. It is a '98 and the carb's have never been rebuilt. I put toomey's ...
Old 12-06-2004, 11:14 PM   #1
View cowboy's Photo Gallery(0)
Default Overflow tubes leaking gas
My girlfriend's banshee recently started leaking gas out of both carbs. It is a '98 and the carb's have never been rebuilt. I put toomey's on it a month ago, awesome pipes by the way, now the carbs both slowly drip fuel from the overflows. I did put in new needle, different mains, etc. so I had the carbs apart, however, everything went back together fine and it runs great.
The overflow screws are tight, and I'm debating between sticking floats and worn needle valves/seats. If I tap on the side of the carbs, the leaking usually stops, but will start again in 1/2 hour or so. I checked the needle valve assy and the conical rubber piece looked fine, but maybe I'm overlooking something else.
Please help and thanks.
04 YFZ 450
Pro Motion Twist Grip
Pro Design Dbl. Stage Filter/outerwear
Lid ON
Cam Mod
DMC Alien Full Exhaust
cowboy is offline   Reply With Quote
Old 12-06-2004, 11:17 PM   #2
Warrior's Avatar
View Warrior's Photo Gallery(0)
If tapping stops it my money's on sticking floats.
Cruz/Warrior
'04 CR250r
'09 YFZ450r
, Stolen
'09 KTM 505 SX
Warrior is offline   Reply With Quote
Old 12-07-2004, 05:27 PM   #3
View warrior-man's Photo Gallery(0)
Yep, my banshee did this and i jsut adjusted my floats and its fine now, every so often i'll se a little bit of gas on the floor but adjusting the floats fixed it.
2001 Raptor- 686, Pro Circuit pipe, L&A One way, nerfs, kendas, Alba flame graphics with powdercoat job to match, everything metal powdercoated
"Thats like stuffin D cup titties in an A cup bra, just let them puppies go" - Nolan
warrior-man is offline   Reply With Quote
Old 12-07-2004, 06:30 PM   #4
View JiM417's Photo Gallery(0)
Yep just fixed my friends blaster few weeks ago, it poured out the overflow right when you turned the gas on, messed with the floats and foudn the problem and fixed it
02 SX Banshee #17 B-
Powdercoated Frame - +2 Lonestars - YFZ450 Shocks - Durablue Axle - Billet SRP Dual Row Bearing Carrier - Wiseco - Pro Circuit.. a LOT more,
JiM417 is offline   Reply With Quote
Old 12-08-2004, 05:59 AM   #5
View SpeedFreakNjapan's Photo Gallery(0)
or dirt in the pilot
2005 YFZ 450 Nothing stock
RIDE it like you STOLE it and if yeah did steal it ride it faster
SpeedFreakNjapan is offline   Reply With Quote
Old 12-08-2004, 08:11 AM   #6
View ondeeeznuts's Photo Gallery(0)
My floats did this last week.
ondeeeznuts is offline   Reply With Quote
350 twin banshee why gas would b over flowing in cylinder
banshee carb leaking gas
2002 blaster leaking gas out overflow
overflow tube on ayahama 350
why carbs leak and banshee#gsc.tab
why is gas leaking out of the over flow hose on my quad
banshee float valve sticking
banshee carbs wont stop leaking
why does gas flow out of my overflow tube on my quad
i have dual carbs on my quad and they leak out the over flow
yamaha banshee carb leaking from venturi overflow
04 yamaha banshee leaking gas from overflow
tire tubes? tjriddle Tires & Wheels 3 10-26-2004 08:56 PM
Fuel dripping from vent tubes 660Raptor Yamaha YFM660R Raptor (2001-2005) 11 03-17-2004 12:42 PM
blaster is leaking gas out of carb overflow! trailboss Yamaha YFS200 Blaster ('88-Present) 11 10-25-2003 08:07 PM
tubes??? warrior90 Tires & Wheels 1 03-26-2002 06:30 PM
Tubes for tires??? warrior90 Yamaha YFM660R Raptor (2001-2005) 4 03-19-2002 04:20 PM
