09-25-2004, 07:55 AM
OIL TO GAS RATIO (RETARDED QUESTION)
Sorry to waste your time on this one but im VERY new to shee's and was wondering what the oil to gas ratio. my goal is to mix it 5 gallons at a time. thanks a lot guys
09-25-2004, 08:05 AM
ok for 32:1 ratio it is 4 ounce per gallon so it would be 4ounces times number of gallons. so 4x5 equals 20 ounces of oil.
09-25-2004, 11:39 AM
32:1 is a little rich,I would go 40:1
~#145-Logan~
'00 Cr 125- Way too much to list now!
'97 Ford Ranger-Red Neons, Future-X Bedliner and Bed Rails
09-25-2004, 11:56 AM
32:1 and 40:1 are what most people mix at depending on what kind of oil they run.
09-25-2004, 02:26 PM
32:1 or 40:1 is fine. Typically I make the recommendation that if you banshee motor has stock porting 40:1 is fine. When you get your engine ported, I would switch to 32:1. But there are alot of peeps out there running 40:1 on ported motors....so it really comes down to preference.
I am also a fan of full synthetic or castor based oils to protect the crank bearings.
09-25-2004, 07:42 PM
go down to your local cycle shop and get yourself a measure rite cup. has all the gas to oil ratios in increments for 1 gal, 2.5 gal so on... makes life real easy and use good 2 stroke oil like maxima castor 927 from the same shop.
09-27-2004, 11:33 AM
Most likely you will run 40:1 because it's really easy. If you want all the conversion and math behind it, let me know, I can bore you to death with it, but in a nutshell:
32:1 means 20 ounces in 5 gallons, or 16 ounces in 4 gallons.
40:1 is 16 ounces of oil in 5 gallons. This is really easy because pre-mix oil is often sold in 16 oz. bottles, so you don't even need to measure. Just pour one bottle into 5 gallons of gas.
09-30-2004, 07:38 PM
i mix HP2 with 110 race fuel at 32:1
98 Shee
ProTaper fat bars & billet mount
Pro Grips
Billet Nacs throttle cover
Alba clutch cover
FMF Fatty's
Pro Design filter and mount
Pro Design Cool Head 20cc domes
V-Force Reeds
Stage II porting
DuraBlue Axle
Douglas Wheels
DG bumper & grab bar
http://www.geocities.com/wicked98shee/pix
10-05-2004, 07:21 AM
the guy I bought my shee from told me to run it 50:1  I thought that was lean but it someked ok and sure ran strong.... should I change it?
2000 300ex - trade for nice blaster
99 project XC banshee
1996 KTM360exc - for sale
10-06-2004, 01:45 PM
#10
Depends on the oil... I run about 50:1 in my shee and my RM250 but I use Power Plus. Power Plus is designed to run at 50:1. Actually, I usually pour just a tiny bit more oil in to run a hair richer.
castor 927 mix ratio, castor 927 ratio, mix radio for yamaha banshee 2001 for 5 gallond, how many ounces per gallon for 50 1#gsc.tab, banshee 5 gallon mix ratio, what fuel to us for a 1997 banshee, castor 927 32:1 mix ratio, 1997 yamaha banshee mixture, how many oz of castor 927 do i add to 5 gal of gas, how many oz. of castor oil to gasoline ratio one gal., how to mix 32:1 with 5 gallons, castor 927 mix ratio for banshee
