it wont quit overheating
This is a discussion on it wont quit overheating within the Yamaha YFZ350 Banshee (1987-Present) forums, part of the Performance /Technical category; My friend has a 96 banshee. its been bored to about to 415cc or 420cc. It keeps overheating and blowing the head gasket and blowing ...
Old 07-31-2004, 05:43 PM   #1
View txrap03's Photo Gallery(0)
Default it wont quit overheating
My friend has a 96 banshee. its been bored to about to 415cc or 420cc. It keeps overheating and blowing the head gasket and blowing water out the overflow hose. he put a new head gasket and some engine ice coolant in it but it still keeps overheating. it gets so hot it will make that engine ice start boiling in about 10 minutes(just cruising around). any idea about why its getting this hot or how to fix it?
2003 Yamaha Raptor
Renthal bars, pro design kill switch, sparks x-6, gytr filter system w/k&n filter, k&n jet kit, ITP Holeshots on hiper rims, rpm dominator axle, steel braided brake lines, shaved front fenders, YFZ shocks
1999 CR250 *FOR SALE*
Pro taper bar, fmf pipes and silencer, all black plastic(ufo), ceet gripper seat cover
txrap03 is offline   Reply With Quote
Old 07-31-2004, 10:59 PM   #2
tOj
View tOj's Photo Gallery(0)
got coolant in it?
Built Banshee
• 2001 Frame • 96 Motor • LSR2.1/Elka/Durablue2.2/Quicksand2.5/8• ITP Baja/Kenda Klaw •
tOj is offline   Reply With Quote
Old 07-31-2004, 11:21 PM   #3
Dextreme's Avatar
View Dextreme's Photo Gallery(0)
It could be your waterpump impeller. A good way to test is if you engine is hot and your radiator is cold.
SandLakeDuners.com
Short video of me
Dextreme is offline   Reply With Quote
Old 07-31-2004, 11:44 PM   #4
yea it has plenty of coolant. we took the head gasket off the other day and it had blown it. we put a new one on but we think it blew it again. I dont think its the water impellar because after it would spew some coolant we would tried to take off the radiator cap but it was too hot.
2003 Yamaha Raptor
Old 08-01-2004, 06:43 PM   #5
today he started it up and drove around a little bit and he said the radiator was hot so i dont think its the water impellar. do banshee's have thermostat's?
2003 Yamaha Raptor
Old 08-01-2004, 07:02 PM   #6
View lilsherm89's Photo Gallery(0)
nope.
FOR SALE--1989 Red/Black Banshee--FOR SALE!!!!
T5s-K&N-new plastics-billet and more!!!
lilsherm89 is offline   Reply With Quote
Old 08-05-2004, 04:18 PM   #7
I have no idea what it could be then. He might just take the radiator off and take it to the radiator shop. hopefully that will fix it
2003 Yamaha Raptor
Old 08-05-2004, 04:50 PM   #8
Dextreme's Avatar
Is he running the stock black plastic radiator grill or does he have one of the aftermarket metal ones? Some of the metal ones I think block too much airflow to the radiator...just something to consider.
SandLakeDuners.com
Short video of me
Old 08-06-2004, 03:51 AM   #9
View 96warrior's Photo Gallery(0)
I think if you install an aftermarket water impellar (pro design ect) it will cure it. That is already a sign of it failing, the stock radiator is more then capable of handiling the chore. It may be getting coolant, but I bet the impellar is almost hosed. Don't let it go too long.
banshee and warrior, both with stuff done to them.
http://tellico.off-road.com/wwwthrea...6758-oc15_002.
96warrior is offline   Reply With Quote
Old 08-06-2004, 05:58 PM   #10
he has the stock radiator grill on it. how much does a water impellar cost? where could he find one? are there any other ways to check to make sure thats it? cause that would suck if thats not the problem.
2003 Yamaha Raptor
Old 08-06-2004, 07:09 PM   #11
View beatmiester's Photo Gallery(0)
LOOK ON EBAY I JUST GOT 1 FOR 40.00 AND WATER PUMP KIT (GASKET,BEARING SEAL) FOR 20.00
AND BUY A SIDE COVER GASKET AND YOUR ALL SET
beatmiester is offline   Reply With Quote
Old 08-06-2004, 08:24 PM   #12
I don't know if noss makes an impellar. But they are an improvement none the less. And should be added anyways. www.rockymountainatv.com sells the pro design. But I'd check with
Bob first.
PM bansheebc
banshee overheating
yamaha banshee overheating
660 raptor overheating
banshee thermostat
4 mil stroker banshee overheating
yamaha rhino overheating
banshhe blowing radiator hose
yamaha blaster overheating
yamaha rhino keeps overheating
yamaha rhino over heating
banshee shaverd head overheating
why does yamaha banshee keep blowing head gaskets
Raptor quit running TW62T Yamaha YFM660R Raptor (2001-2005) 2 12-21-2006 09:41 PM
Why did it quit? mxthunder Yamaha YFS200 Blaster ('88-Present) 0 04-05-2003 08:00 PM
ok ill quit YamBlast01 Yamaha YFM660R Raptor (2001-2005) 0 11-25-2001 06:13 PM
