reasons for timing advance - Yamaha ATV Forum
This is a discussion on reasons for timing advance within the Yamaha YFZ350 Banshee (1987-Present) forums, part of the Performance /Technical category; hi my banshee came with a pro design timing plate it was set on +4 what are the benefits from different timings? anything 'type of ...
Old 09-09-2003, 01:10 AM   #1
View jilted's Photo Gallery(0)
Default reasons for timing advance
hi
it was set on +4
anything 'type of riding' specific?
i am jilted
2004 Yamaha YFZ450
2000 Yamaha Banshee (sold)
jilted is offline   Reply With Quote
Old 09-09-2003, 03:09 AM   #2
View chocks's Photo Gallery(0)
what else is done on your motor??? Timing is usually set for a specific motor setup, I.E. compression ratio or type of fuel.
Men have two emotions: Hungry and horny. If you see him without an erection make him a sandwich.
chocks is offline   Reply With Quote
Old 09-09-2003, 08:52 AM   #3
the head was shaved very little
and the engine has mild porting
thats about it, except exhaust
i am jilted
2004 Yamaha YFZ450
Old 09-09-2003, 10:26 AM   #4
View bobby bo's Photo Gallery(0)
well timing advancing gives you about 2hp through the whole power band.. goes really well with a milled head..
03 kfx440, axis shocks, lt a-arms, few other things
bobby bo is offline   Reply With Quote
Old 09-09-2003, 04:45 PM   #5
View MasterBlaster03's Photo Gallery(0)
I was wondering this too I have heard that advancing the timing can actually hurt the engine?
2000 Banshee- CPI Inframes, Proflow wih K&N Filter, ITP rims, boost bottle, boyseen reeds.
MasterBlaster03 is offline   Reply With Quote
Old 09-09-2003, 04:57 PM   #6
i guess my inquiring mind wants to know like, on a scale, what timing would be good for what.
example:
+1 - good for blah
+2 - good for bleh
+3 - good for bloh
+4 - good for bluh
i just changed stators and it came with a timing place and i just put it back to stock timing because i have never actually seen how my banshee performs at stock timing.
i am jilted
2004 Yamaha YFZ450
Old 09-09-2003, 05:10 PM   #7
View Chrome112's Photo Gallery(0)
IMO its worth it
Chrome112 is offline   Reply With Quote
Old 09-09-2003, 05:12 PM   #8
well i gotta close everything back up and try it out this evening
i'll find out pretty quick if its noticeable or not i guess
i'll report back with my findings
i am jilted
2004 Yamaha YFZ450
Old 09-09-2003, 08:38 PM   #9
View Traxxastampede's Photo Gallery(0)
I haven't been here in forever, and I sold my ATV a little while ago but I figured I would chime in:
Timing is basically when the engine will get its fuel and let out it's exhaust (in your car it is done through a series of valves for instance) however it can lead to knock and detonation... so if you have low octane gas it is a bad idea, but high octane gas is a good idea. Timing is power, just make sure you don't have too much advance or you will be pushing things too hard and that leads to pain in the engine.
Traxxastampede is offline   Reply With Quote
Old 09-09-2003, 08:54 PM   #10
well i know what changing the timing physically does, just not what its benefits are.
the stroke is still exactly the same, as far as getting the fuel and letting out the exhaust.
what changing the timing actually does is alter when the spark plug fires within the stroke... (earlier or later)
i am jilted
2004 Yamaha YFZ450
Old 10-08-2003, 08:27 PM   #11
View Punisher's Photo Gallery(0)
I was just looking through some of the old posts and this one caught my eye.
Advancing your ignition timing gives the air/fuel mixture more time to burn. Since the heat is what causes the piston to move down and not the explosion, this means more of the fuel will be used up to heat the oxygen to push the piston down harder.
99 Blaster
-HDP carb rifle, The prop,
-Toomey B1
-Moto Tassinari Delta 2 Reeds
-Shredders in the rear
-2.5" Durablue rear wheel spacers
Punisher is offline   Reply With Quote
Old 10-08-2003, 09:12 PM   #12
View jakalwarrior's Photo Gallery(0)
I "think" it also makes you more likely to ping if you dont have enough octane and it makes a motor run hotter.
2 wheels: Y2k KX500 - 2002 YZ125 - 2012 ZX6R - 2002 VTX1800C - 1973 RD350
4 wheels: 2007 Raptor 700, 1994 Trailboss 250
jakalwarrior is offline   Reply With Quote
Old 10-08-2003, 11:51 PM   #13
View WyoDuner's Photo Gallery(0)
First +4 or +5 max is about as far as you want to go for a normal engine.
By advancing the timing you are igniting the air/fuel mixture a little sooner. How does this give more power? It takes time for fuel to burn so the spark always fires before the piston reaches TDC. In other words, the spark fires before the piston is finished with the compression stroke. What this does is gets the air/fuel mixture burning and close to maximum combustion pressure at just the right time. If it fires too late you lose power and if it fires too soon you get pre-ignition. In short, by advancing the timing you are just firing at a more optimal time than stock. The stock curve is a little conservative I guess.
2002 Banshee - CPI, Noss Head, etc...
1995 Warrior
WyoDuner's Dune Review Site and SAND DUNING Forums
WyoDuner is offline   Reply With Quote
Old 10-09-2003, 12:44 AM   #14
Dextreme's Avatar
View Dextreme's Photo Gallery(0)
I 2nd what WyoDuner said! When I advanced my timing to +4 to +5 and ran race fuel...it felt like 10 more HP, but I know it is only about 2HP.
SandLakeDuners.com
Short video of me
Dextreme is offline   Reply With Quote
Old 10-10-2003, 02:28 PM   #15
View 03kandkbanshee's Photo Gallery(0)
ok here is a very simple explanation
when at idle if advanced it will sound like its idling rougher / higher or like your giving it a little gas but your not
so it seems to get to power faster
make sense
03kandkbanshee is offline   Reply With Quote
banshee timing advance
banshee timing
yamaha banshee timing plate
yamaha banshee timing advance
advance timing yamaha banshee
what does advancing the timing on a banshee do
best timing for banshee
banshee advanced timing plate
how to chsnge timing banshee
how to change banshee timing plate
yamaha banshee toomey pipes timing advance
timing advance needed with cam and piston change? mondo128 Yamaha YFM660R Raptor (2001-2005) 13 05-30-2003 03:33 PM
Raptor Timing Advance Hi Velocity Raptor Yamaha YFM660R Raptor (2001-2005) 14 11-14-2002 08:11 PM
advance timing yamaha01us Yamaha YFZ350 Banshee (1987-Present) 3 10-23-2002 12:06 PM
CURTIS SPARKS TIMING ADVANCE mxraptor Yamaha YFM660R Raptor (2001-2005) 2 05-25-2002 09:46 PM
advance timing key darlingtonraptor Yamaha YFM660R Raptor (2001-2005) 3 12-31-2001 06:14 AM
