banshee carb. leak - Yamaha ATV Forum
banshee carb. leak
This is a discussion on banshee carb. leak within the Yamaha YFZ350 Banshee (1987-Present) forums, part of the Performance /Technical category; anyone ever had a problem with the float bowls on there banshee keep leaking?(out the over flow line)The floats are not stuck,and the drain screws ...
Old 02-07-2003, 09:29 AM   #1
View rickman's Photo Gallery(0)
Default banshee carb. leak
anyone ever had a problem with the float bowls on there banshee keep leaking?(out the over flow line)The floats are not stuck,and the drain screws in the bowl are tight,we even tried different bowls.and sometime they leak and sometime they dont.
`03 Raptor jetkit,white Bros.,K&N filter/Proflow,HotCam
rickman is offline   Reply With Quote
Old 02-07-2003, 10:52 AM   #2
View Banshee2001's Photo Gallery(0)
You need to check the float level. Here is how you do that.
Hold the carb with the throttle bore vertical and the float hinge at the top so that the floats can swing freely. Swing the floats with your finger to verify they are free and operating properly. Now, just rotate the carb towards the upside-down position only until the floats just sit down on the float needle valve. Any more rotation will cause the weight of the floats to push down on the spring loaded float needle valve and you will get an erroneous reading. The proper angle is about a 45 degree angle from vertical.
At this point with either a metric measuring scale or the tail end of a pair of calipers (or other such accurate measuring device) measure the distance from the float bowl gasket surface -- WITHOUT THE GASKET-- to the top of the float itself. This measurement should be 21mm exactly on both floats. If you get some other reading just bend or tweak the float arms until you get this setting. Just don't bend them sideways so that they may interfere with the float bowl itself. Check for clearance when you are finished. When you are satisfied they are perfect, replace the float bowl gasket and float bowl.
2001 Banshee with FMF SST,
K&N air filter with a Pro
Flow Adapter plater, Renthal
Bars, +4 Degree Key, Cool Head
w/22cc Domes
Banshee2001 is offline   Reply With Quote
Old 02-07-2003, 01:20 PM   #3
View Bluetraxx_member's Photo Gallery(0)
i had the problem when i was putting pipes on my shee
it ended up being a glogged seat for the needle. My idea you need to take the carbs off and get come carb cleaner and spray them really good inside and out and then blow air through it to clear anything else out and then it should be fine.
full blown '02 Mx banshee
---'03 tughill veteran with the scars to prove it---
---'04 tughill veteran this time with no scars ----
Bluetraxx_member is offline   Reply With Quote
Old 02-08-2003, 06:49 AM   #4
I adjusted the floats and it dont leak !
but It seamed like I had to adjust them quite a bit.
I tryed to adjust them before but I never had the right adjustment. thanks alot.
Old 02-08-2003, 01:16 PM   #5
View Bubba Z's Photo Gallery(0)
Thats funny you mentioned that Bluetraxx_member.I had the exact same problem when I put my pipes on.I think when I flipped the carbs on their sides,some crap that was in the bottom of the bowls backflowed into the needle/seat.I checked the float level twice before I decided to drain the fuel bowls and blow some compressed air into the fuel inlets on the carbs.Cleared the problem right up.
Bubba Z is offline   Reply With Quote
how to set banshee floats
how to set floats 2001 banshee
banshee float height
why does my yamaha banshee carburetor leaking
banshee float valve
how do i adjust the float in my yamaha banshee carb
06 banshee floats for sale
banchee float height
yamaha banshee how can i tell if i have the float bowls are on the correct carb
carb leaking gas out air filter banshee
banshee carb leaking oil
putting in flot on 4wheeler yamaha banchee
Banshee won't run after carb rebuild. banshee_2001 Yamaha YFZ350 Banshee (1987-Present) 5 07-26-2008 04:51 AM
Banshee carb beef!!! tavo1765 Yamaha YFZ350 Banshee (1987-Present) 3 12-21-2006 03:01 AM
Banshee 2 in 1 carb.. Trickedout2Stroke Yamaha YFZ350 Banshee (1987-Present) 2 11-14-2003 12:44 AM
banshee broken...oil leak???? lilsherm89 Yamaha YFZ350 Banshee (1987-Present) 6 06-04-2003 10:30 PM
Banshee Carb problem... Holstein660R Yamaha YFZ350 Banshee (1987-Present) 6 01-09-2002 03:44 AM
