turn left and it bogs?
This is a discussion on turn left and it bogs? within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; I am new to this. I have an 02 blaster i bought it two years ago and ever since i bought it when i turn ...
Go Back   Yamaha ATV Forum - BlueTraxx.com > Performance /Technical > Yamaha YFS200 Blaster ('88-Present)
Old 03-12-2010, 10:25 AM   #1
View trailrider08's Photo Gallery(0)
Default turn left and it bogs?
I am new to this. I have an 02 blaster i bought it two years ago and ever since i bought it when i turn to the left it seems to bog down i have check if i am pinching any lines or wires and it doesn't seem to be. What could the problem be or what else should i look at?
trailrider08 is offline   Reply With Quote
Old 03-12-2010, 02:14 PM   #2
leveldrummer's Avatar
check that the bars arent pulling any wires tight, sounds like its pulling some connection or a cable or soemthing...
Old 03-14-2010, 01:35 PM   #3
thanks i am going to check that today. I rebuilt it a year ago and i had all the plastic off and i checked all that. do you think that the electircal on the top of the carb could be the problem i was going to order the stuff to get rid of that. do you think it is worth it?
Old 03-14-2010, 06:22 PM   #4
im not familiar with the blaster, or what ever kit your talking about to remove the electrics...
but i do know, if your turning your bars to one side, and something is happening. its probably because something is either a) being pulled tight from the bars, or b) getting pinched in something when you turn the bars...
its the only options that make sense, if it is something else, then its a freak situation.
Old 03-14-2010, 10:13 PM   #5
warriorx's Avatar
View warriorx's Photo Gallery(0) Send a message via MSN to warriorx
I think he is talking about the tors eliminator fit and yes it is worth it to get rid of the tors.
99 Warrior/Cobra Pipe/Jetted/Renthal/Port &Polished/HotCams Stage 1
warriorx is offline   Reply With Quote
Old 03-15-2010, 09:22 PM   #6
View 04rangerboy's Photo Gallery(0)
How much gas is in the bike? could it be low enough that when you turn and the gas goes away from the pickup that it hesitates?
08' yfz 450 Velocity intake,k&n filter, DMC Afterburner silencer, ceramic coated head pipe,9 paddle haulers.cascade gas cap,
01' shee k&ns, fattys, 8" swingarm, redline built motor, pro design Cool head, 22cc domes,drag port port Pink race cut plastics (wifes bike)
04rangerboy is offline   Reply With Quote
Old 03-30-2010, 10:30 PM   #7
TERBOboy's Avatar
View TERBOboy's Photo Gallery(0)
Are you sure its "bogging" and not simply easing off on the throttle ? Sounds like your throttle cable is not secure ( carb side ) and backing off on the throttle a bit . ( Left turn - slows down - right turn , might speed up or take a while to back down - sometimes both will happen , sometimes just one)
TERBOboy is offline   Reply With Quote
Bike bogs!!! What can it be?!?! pereirajr1 Yamaha YFZ450/450R (2004-Present) 5 08-02-2010 10:06 PM
bogs on landing axle Yamaha YFZ450/450R (2004-Present) 1 01-27-2004 12:04 AM
shee runs, idles and all but it bogs a little before i can r banshee962000 Yamaha YFZ350 Banshee (1987-Present) 6 02-18-2002 12:48 PM
