Very High Idle..Like..VERY High..Please HELP! - Yamaha ATV Forum
This is a discussion on Very High Idle..Like..VERY High..Please HELP! within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; Ok..here's the deal..We got a couple of blasters pretty cheap, so we've been building one out of the two..We have a jug that is bored ...
Old 01-06-2010, 06:08 PM   #1
View antos360's Photo Gallery(0)
unhappy Very High Idle..Like..VERY High..Please HELP!
Ok..here's the deal..We got a couple of blasters pretty cheap, so we've been building one out of the two..We have a jug that is bored .10 over, FMF Gold Series Fatty silencer, And a FMF pipe..TORS Removed..The carb has a 220 or 230 jet in it..blaster manual says that 220 is standard..so i think its a 220..First carb wasn't taken apart and cleaned, second one was..With both carbs the problem was the same..So here's the problem..Fire it up, and it revs high..sounds around 3,000 or so..Pilot air screw is turned out 1 1/2 on Carbs, and we attempted to adjust the idle..Nothing happened..Turn the air screw out..Nothing..it just wants to rev high..Sometimes it will hold the rev steady and sometimes it will progressively increase..Both carbs did the same thing..after we shut the motor off, and tried to kick it over..it backfired once, and then fired right back up..
Any Suggestions?
antos360 is offline   Reply With Quote
Old 01-06-2010, 06:35 PM   #2
Also..for the record..we are aware it should be jetted to compensate for being Bored over, and fitted with a pipe, but should it still be revving out like that? i would think it'd be starved for fuel, rather than having too much..
Another Note..Not sure what position the main jet needle is on..i imagine stock..which is 3rd down, if i read right
Old 01-07-2010, 06:22 AM   #3
View 2008wolverine's Photo Gallery(0)
Sounds more like an air leak check where carb mounts to boot to reed mount and also the bolts attaching reed block to motor, gaskets etc.also check that reeds are in good shape, just a thought
2008wolverine is offline   Reply With Quote
Old 01-09-2010, 01:59 PM   #4
so.... i put another gasket in between the reed cage and engine....my kit didnt come with 2 for that area...i have a parts wheeler i pulled one from...it deff seemed to effect how it was running...since doing so ..it now seems like it is flooding out ..and wont run for long...any suggestions ?....lol b4 it wouldnt stop...now it wont move
Old 01-09-2010, 11:07 PM   #5
Taking a shot in the dark ifit seems like it is flooding? make sure the float in the carb is moving freely< if 2 gaskets made that change you may have had an air leak which would cause it to be to lean(rev high) now it sounds to rich(maybe to much fuel) go to 1 good gasket check carb adjusment and make sure air cleaner is in good shape<i hope this helps
yamaha blaster high idle
atv idles too high
4 wheeler idles high in neutral
atv idling high
what would cause a 3 wheeler to idle high when started
quad idles high in neutral
1989 yamaha moto 4 200 idle adjustment
why does yamaha blaster start idling real high
atv high idle in neutral
4 wheeler idling high
06 blaster idle so high
engine revs when idle atv
high idle Shaun Yamaha YFM660R Raptor (2001-2005) 6 01-07-2009 12:26 AM
High Idle Jbud Yamaha YFM660R Raptor (2001-2005) 4 01-07-2005 12:06 AM
high idle 32blaster Yamaha YFS200 Blaster ('88-Present) 10 04-20-2004 03:25 AM
Why such a high idle? poping at WOT. YamahaForever Yamaha YFM350 Raptor/Warrior ('87-Present) 10 03-28-2004 04:25 PM
how high should it idle? DOM420247 Yamaha YFM660R Raptor (2001-2005) 4 08-05-2002 05:25 PM
