2000 Blaster no spark ????
This is a discussion on 2000 Blaster no spark ???? within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; Hello my son traded 2 dirt bikes for a 2000 blaster that they said the clutch was stuck but after some short investigating of my ...
Old 02-11-2007, 09:17 AM   #1
View cayers68's Photo Gallery(0)
Default 2000 Blaster no spark ????
Hello my son traded 2 dirt bikes for a 2000 blaster that they said the clutch was stuck but after some short investigating of my own I found the engine seized piston skirt broke so much for the other kids honesty. well anyways we put new piston and rings and now it has no spark checked for sheered pin thats ok replaced coil with a new one. any help would be appreciated.
cayers68 is offline   Reply With Quote
Old 02-11-2007, 11:55 AM   #2
View trapp350's Photo Gallery(0)
Unplug all the TORS wires from the bike then see if it has spark. unplug the one from the top of the carb then there is a box under the hood of the blaster. Accually I think there is 3 boxes one is the ecu its the bigger black box leave that one alone one is a volage reg it has 12V or something like that on it is silver leave that one alone too. There is a small black box above ECU unplug that one. Then check your spark. It is hard to take resistance readings I have noticed they are never right anyways even on brand new componets. If you still dont have spark it could be a couple things coil,stator,ecu or wiring. I is ussally the tors though. Does the headlight come on faintly when you kick it over with the light switch on?
2007 raptor 700
1996 Banshee
1999 Blaster
1986 Honda 200x
trapp350 is offline   Reply With Quote
Old 11-22-2007, 11:15 PM   #3
View duramax03's Photo Gallery(0)
Also check to make sure the motor is securly mounted again. I know it sounds dumb but it happened to me when i did the rebuild. I forgot to tighten that bolt and it didn't have a good ground and there ya have it. I know it sounds stupid but sometimes we all over look the easy things:)
duramax03 is offline   Reply With Quote
Old 02-04-2008, 06:07 PM   #4
View speedfoxracing's Photo Gallery(0)
i have the same problem
my light does turn on when u kick it over so now wut else ?
speedfoxracing is offline   Reply With Quote
yamaha blaster no spark
2000 yamaha blaster no spark
blaster no spark
yamaha blaster has no spark
2003 yamaha blaster no spark
blaster no spark problems
1999 yamaha blaster no spark
no spark yamaha blaster
yamaha blaster lost spark
my blaster has no spark
2003 yamaha blaster has no headlight
no spark on a 1884 blaster
2000 Warrior Spark Arrester scott0417 Yamaha YFM350 Raptor/Warrior ('87-Present) 1 04-28-2007 11:51 PM
blaster 2000 blaster105 Yamaha YFS200 Blaster ('88-Present) 5 11-26-2003 01:18 PM
my 2000 blaster b!aster b0y Yamaha YFS200 Blaster ('88-Present) 4 03-11-2003 07:03 AM
