What type of motor oil to use? - Yamaha ATV Forum
This is a discussion on What type of motor oil to use? within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; ive searched and saw that alot of people liked castrol 10w 30. i dident see if it was full synthetic, semi synthetic, or gtx. which ...
Old 07-02-2005, 06:44 PM   #1
View MIKEMOKAS's Photo Gallery(0)
Default What type of motor oil to use?
which should i use?
full synthetic?
semi synthetic?
or gtx?
or you could recomend any other brands.
thanks
-mokas-
00 Yamaha Blaster 67.75mm Wiseco Pro-Lite
205.486519470619 cc's.. MUCH MORE..
86 suzuki LT80 PROJECT
84Suzuki LT-A50 sold 11/25/06 around 8:30am
96 Polaris Trail Boss 250 sold 7/07/05 2:54pm < you will be missed.
MIKEMOKAS is offline   Reply With Quote
Old 07-02-2005, 07:23 PM   #2
View Crazed's Photo Gallery(0)
Do you mean transmission oil? If you do, then don't use and synthetics, because that will probally cause clutch slippage.
Just use some gear oil, yamalube will work fine.
Oh, and if you meant pre-mix oil get some fully synethic Amsoil.
Broke
Crazed is offline   Reply With Quote
Old 07-02-2005, 07:24 PM   #3
View lilbear's Photo Gallery(0)
Yamalube 10w30
2003 Z400
PM me for Banshee Shocks
lilbear is offline   Reply With Quote
Old 07-02-2005, 09:27 PM   #4
im talking about tranny oil. will the gtx 10w 30 work good? i herd gear lube/ oil is bad for the clutch???
-mokas-
Old 07-03-2005, 03:02 AM   #5
View blasterboy86's Photo Gallery(0)
Quote: Originally Posted by MIKEMOKAS
im talking about tranny oil. will the gtx 10w 30 work good? I herd gear lube/ oil is bad for the clutch???
-mokas-
just dont get oil with friction modifiers. those are bad. right now im using belray gear saver 75w
12:97:24:99
blasterboy86 is offline   Reply With Quote
Old 07-03-2005, 10:09 AM   #6
View SheRides721's Photo Gallery(0)
-mokas-
BTW, anyone using yamalube, DONT .. i use klotz for my premix and it bruns great For non-mixers, go with bel-ray
04' MX Blaster
"The Beast with the Flaring Nostrils"
Vivas la 2 stokes
SheRides721 is offline   Reply With Quote
Old 07-03-2005, 11:30 AM   #7
this is what i want to use. i dosent say anything about friction modifiers on the back. on the back theres a circle and it says 10w 30 in the middle and around it it says energy conserving. <<is that bad???
i agree sam, yamalube leaves all kinds of remains on the top of your piston. mine was a mess. now i run castor 927 for premix.
thanks for your help
-mokas-
Old 07-03-2005, 11:32 AM   #8
I think thats bad.
2003 Z400
Old 07-03-2005, 12:41 PM   #9
View high_octane94's Photo Gallery(0)
this is what I want to use. I dosent say anything about friction modifiers on the back. on the back theres a circle and it says 10w 30 in the middle and around it it says energy conserving. <<is that bad???
I agree sam, yamalube leaves all kinds of remains on the top of your piston. mine was a mess. now I run castor 927 for premix.
-mokas-
that stuff worked fine for me just make sure you change it often...the best oil ive found is 75W90 gear oil
**1992 RED/BLUE BLASTER**
high_octane94 is offline   Reply With Quote
Old 07-03-2005, 03:06 PM   #10
you dident have any clutch problems with the gtx did you?
thanks
-mokas-
Old 07-03-2005, 04:59 PM   #11
View TwoStrokeRocket's Photo Gallery(0)
the best oil out there is synthetic and its called Amsoil 75w-90. it is so good it can be used again by filtering it through a coffee filter. its the best for trannies, i used it in mine. stuff retails for like $8 a quart. i have 8 quarts, im selling them for $5 a quart, PM me
'04 MX ready blaster, parting out!
http://www.bluetraxx.com/phpBB/viewt...=758658#758658
TwoStrokeRocket is offline   Reply With Quote
Old 07-03-2005, 10:17 PM   #12
thanks
-mokas-
no not at all it just doesnt shift quite as smooth as some 75W90 but it worked fine
Old 07-05-2005, 04:22 PM   #13
View factory effex's Photo Gallery(0)
How can Yamalube gear oil leave shit on your piston? He is asking about tranny oil, not premix oil. I ran Yamalube gear oil in my old blaster and it shifted so smooth and ran great all the time
~#145-Logan~
'00 Cr 125- Way too much to list now!
'97 Ford Ranger-Red Neons, Future-X Bedliner and Bed Rails
factory effex is offline   Reply With Quote
Old 07-09-2005, 12:37 AM   #14
i just bought some bel-ray 75w gear saver. its designed for 2-stroke motorcycle trannys. it says maxium gear protection, and improved clutch performance and shirting. will this be good to use?
-mokas-
Old 07-09-2005, 03:34 PM   #15
I just bought some bel-ray 75w gear saver. its designed for 2-stroke motorcycle trannys. it says maxium gear protection, and improved clutch performance and shirting. will this be good to use?
-mokas-
It should be.
2003 Z400
yamaha blaster oil
yamaha blaster oil type
best oil for yamaha blaster
what motor oil can i run in my 94 yamaha blaster
what kinda oil does 2002 blaster
what kind of oil does a yamaha blaster take
yamaha blaster engine oil
what kind of oil does a blasterr need
yamaha blaster oil capacity
what type of oil does a 2002 blaster take
what type of oil to use for 200 people
yfm200dx oil
oil type tim.medenwaldt Yamaha YFM350 Raptor/Warrior ('87-Present) 9 04-06-2007 01:04 AM
What type of oil? -LE-YFZ450 Yamaha YFZ450/450R (2004-Present) 25 07-27-2005 02:52 AM
What type of oil do you use... 04raptor04 Yamaha YFM660R Raptor (2001-2005) 25 12-10-2004 01:18 AM
oil and type do you use????? buelldude Yamaha YFM350 Raptor/Warrior ('87-Present) 27 06-23-2004 11:22 PM
