Only "reverse" after rebuild
This is a discussion on Only "reverse" after rebuild within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; My freinds dad rebuilt his Blaster... When put into gear you accelerate backwards only... Needless to say we were all a little shocked... Any idea ...
Old 04-04-2005, 04:43 PM   #1
View Sportraxboy1010's Photo Gallery(0)
Default Only "reverse" after rebuild
My freinds dad rebuilt his Blaster... When put into gear you accelerate backwards only... Needless to say we were all a little shocked... Any idea whats causing this problem?
Thanks :cool:
2004 Honda 450r
Sportraxboy1010 is offline   Reply With Quote
Old 04-04-2005, 06:00 PM   #2
View p8nt's Photo Gallery(0)
woah... i never heard of anything like that happenin before... post if u ever find out what was wrong
blaster- uni, pb, maxxis, tusk, dg
p8nt is offline   Reply With Quote
Old 04-04-2005, 06:05 PM   #3
View Flattrack's Photo Gallery(0)
LOL its all in the Ignition tell him to double check all the components (Stator, Lose pickup in the fly wheele, Ect.)... It is the motor running back wards. So some thing is way out of wack...
E-mail MichaelsMotorSports @winning.com
How fast do you want to go?
Flattrack is offline   Reply With Quote
Old 04-04-2005, 07:09 PM   #4
View Bansheeboy14's Photo Gallery(0)
I actually saw a letter in skirtwheels (did I just say that? Hehe.) where a guy had a tecate with the same exact problem.
Bansheeboy14 is offline   Reply With Quote
Old 04-04-2005, 07:16 PM   #5
View DREWS SHEE's Photo Gallery(0)
I heard somewhere that 2-stroke motors can run backwards. Try to push start it (in the right direction) and see if that fixes it.
2001 Orange Raptor
2002 motor
DREWS SHEE is offline   Reply With Quote
Old 04-04-2005, 07:40 PM   #6
View empty-wallet's Photo Gallery(0)
I would not advise really trying to pop start it, in this case it may mess things up. If the motor tried to run backwards, and you try pop starting it, making it run the right way couldn't it bend a rod or something worse from the jolt of the motor quickly changing direction??
Wait, so the bike starts and runs, but when you shift to 1st, what does it do???
You can get some motors to run backwards which is not very good. My tecate was off a little, but it wouldnt fire. What happened to mine is that the stator was too far, causing spark before it should and the kick starter whould shoot back and literally give your foot a bruise on the bottom. A 210psi motor kicking back HURTS LIKE HELL.
Im lost as to how you guys actually got it to run backwards and keep it running.
www.myspace.com/kylejandura
empty-wallet is offline   Reply With Quote
Old 04-04-2005, 08:02 PM   #7
View 400exracer24's Photo Gallery(0)
are you sure your facing the right way? You face the end with the two metal bars sticking out
1999 400ex with over 6g invested
4-stroke quad
400exracer24 is offline   Reply With Quote
Old 04-04-2005, 09:32 PM   #8
Old 04-04-2005, 10:14 PM   #9
View Mustangarrett's Photo Gallery(0)
Correct me if Im wrong, but I believe that some older quads had the ability to actualy run in reverse... in order to achieve the desired reverse direction, instead of have a reverse gear. Pretty cool, unfortunantly that doesnt help your problem at all.
Mustangarrett is offline   Reply With Quote
Old 04-04-2005, 10:17 PM   #10
View Klaw's Photo Gallery(0)
Your timing must be reallly off!
00'Blaster
05 Yfz
98'Ram
Lifted, locked, Geared, and so much more!
Klaw is offline   Reply With Quote
Old 04-05-2005, 12:35 AM   #11
View daputz's Photo Gallery(0)
thats what I am thinking
Double check the stator.
2 strokes can and will run opposite direction if the timing is 180 off........different engine's have used this in the past to get reverse.
2003 blaster with engine built by
HWD, suspension by PHRAGELROX
"84" rz350 for the street
daputz is offline   Reply With Quote
Old 04-05-2005, 05:37 AM   #12
Yea, I believe thats the problem...
Thanks for the help, allthough I thought keeping it like that would make a one of a kind Blaster...
2004 Honda 450r
Old 04-09-2005, 08:57 PM   #13
View cookie_monster's Photo Gallery(0)
I had a TRX250R ('84 air cooled) that would run backwards. I found out the hard way....trying to climb a hill, killed it, and let it roll backwards a bit before I let the clutch out (no brakes) to slow it down. It started right up. The rotor key had been sheared I guess...never did run right. I got it home (backwards) and it needed crank bearings anyway, so in the process, I pulled the rotor...and yep, sheared key. New key, crank bearings/seals and it ran like never before...and I sold it not long after. That thing was a death trap!
"it is better to appear ignorant than to open your mouth and remove all doubt"
-Mark Twain
cookie_monster is offline   Reply With Quote
Old 04-10-2005, 09:16 PM   #14
View bluescreamer02's Photo Gallery(0)
i had the same problem with my blaster after rebiulding the topend ive ask 4 differnt dealers they didnt know what , for some reason i figured it was the timing key, got a new one put it in and there ya go problem fixed
87 265 MXER
bluescreamer02 is offline   Reply With Quote
Old 04-11-2005, 12:01 AM   #15
Warrior's Avatar
View Warrior's Photo Gallery(0)
Timing issue I'm sure. Old Detroit diesels would run backwards, we had a tank truck that always got parked far from the building for when it actually did start backward...
Cruz/Warrior
'04 CR250r
'09 YFZ450r
, Stolen
'09 KTM 505 SX
Warrior is offline   Reply With Quote
Old 04-11-2005, 09:39 PM   #16
View Flyin5's Photo Gallery(0)
yeah... like everyone has said its your timing. its actually quite usefull that 2-strokes can run backwards. in many snowmobiles they use that instead of adding the wieght for a reverse gear.
)))Revulsion Industries(((
Flyin5 is offline   Reply With Quote
banshee running backwards
yamaha blaster reverse
yamaha 200 blaster runs backwards
why would a blaster engine run backwards
rebuilt engine for blaster and now it only goes in reverse
why would my yamaha blaster have reverse
does a yamaha blaster have reverse
banshee engine running backwards?
yamaha blaster only has reverse
banshee running in reverse
blaster goes in reverse
why is my yamaha blaster going in reverse
