Crank Bearing replacement - Yamaha ATV Forum
post #1 of 12 Old 04-30-2004, 10:00 PM Thread Starter
Send a message via AIM to Pjw350
Well im puttin new crank bearings in the cases and I froze the bearing and put the case half in the oven for a little bit but still even after that I couldnt get the bearing to slide all the way in. Anyone have any tips on replacing them for a blaster.
05 YFZ450 White/Blue
96' Banshee-Red Fullbores, Janssen Racing Mx-tech A-Arms, swingarm and stem, Patriot Racing porting, works, shocks,x-33 axle,
04' Dodge Ram QuadCab 4x4
01' Grizzly
90' YZ250
Pjw350 is offline
post #2 of 12 Old 04-30-2004, 10:21 PM
Send a message via AIM to tbone07
Crannk Bearings
i just put crank bearing in my blaster. Me and mxthunder took a heat lamp and put it over the place where the bearing was going to go in. Meanwhile we had the bearings in the freezer. The bearings will not just slide in. You might have to use a rubber mallet and a socket extension to pound it in. DO NOT POUND ON THE INNER RING OF THE BEARING! This will ruin it. Pound on the outside ring only. Give it a little time and finesse and it should go in. Even though it says not to in the manual a mechanis said that i could use a burnsomatic torch to heat it up. Dont heat it up too much or you can warp the case half. do all of this and you should get the bearing in easily.
blaster sold - im a traitor and am getting a car
www.ohiomafiariders.com
tbone07 is offline
post #3 of 12 Old 05-01-2004, 09:49 AM
Do NOT pound the bearing at all, you will either break the case or distort the case where the bearing sits, take the case halves to either a machine shop, car dealer, or cycle shop that has a press, even if you have to pay a couple bucks, its worth it to have them installed right, if they are not true in the case to one another, the crank will be put on a bind and ruin the bearings in a matter of minutes upon start up, again, DO NOT pound the bearings in what so ever, use a PRESS, bad, bad advice
hollywooddirt is offline
post #4 of 12 Old 05-01-2004, 11:23 AM
Send a message via AIM to blaster105
i dont wanna start another thread but when i took my crank out the bearing was stuck on the crank, how might i take it off.
blaster105 is offline
post #5 of 12 Old 05-01-2004, 02:48 PM
Send a message via MSN to high_octane94
use a puller
**1992 RED/BLUE BLASTER**
high_octane94 is offline
post #6 of 12 Old 05-01-2004, 04:13 PM
I was told what to do by a yamaha mechanic so you cant say that its bad advice. My bearings were perfect when i was done with them. Just use caution and dont hit it too hard
tbone07 is offline
post #7 of 12 Old 05-01-2004, 09:36 PM Thread Starter
I tried again today and froze the bearing and baked the cases for a few minutes then i took a torch and heated up the case and the bearing slid right in with a little tapping from a rubber mallet. Thanks tbone for your help
01' Grizzly
90' YZ250
Pjw350 is offline
post #8 of 12 Old 05-02-2004, 07:14 AM
A yamaha mechanic told you that, shame on him, that IS bad advice, he should know better than that.
You also need a bearing puller to get the bearing off the shaft, its a half moon type puller the you tighten the nuts on 2 threaded shaft and it squeezes the jaws of the puller together and lifts the bearing from the shaft, harbor frieght has them for about 20.00, good tool to have.
post #9 of 12 Old 05-02-2004, 10:02 AM
Send a message via AIM to mxthunder
I have been changing all kinds of crank bearings like that by changing the temperature, and using a drift to pound on the outer/inner race, depending on what your putting the bearing on/into. It will not do any damage to the bearing if you know what you are doing, and you do it properly.
04 YFZ450 - WR crank, oil mod, CP 13:1 piston, Full Yosh TRS Ti pipe, hotcams intake, cam mod, YZ clutch mod, GYTR basket, FCI, 1" lowering peg nerfs, LSR axle, Pro tapers and Housier +1" stem, PRM desert grab bar, AC bumper, XCR tires and more 175M NCVQ #5 50p | 2010 YFZ450X - HMF Tuner, PRM bolt-ons, Aluminum airbox + K&N Filter
mxthunder is offline
post #10 of 12 Old 05-02-2004, 11:49 AM
Preach on
tbone07 is offline
post #11 of 12 Old 05-02-2004, 12:06 PM
the key word there was PROPERLY, you know 95% of blaster owners are kids and pounding a bearing in means exactly that, POUNDING, that's the point I'm trying to make, is that isn't real good advice to give a teenager, I have seen many a broken cases from kids pounding in bearings, screw drivers used to hold clutch baskets, screws stripped and so on, I'll stick to using the old hydralic press for removing and installing bearings
post #12 of 12 Old 05-02-2004, 01:31 PM
i tried holding my clutch basket with a screwdriver once...and i broke it of course...but i learnt my lesson
Motor Tear Down - Bearing Replacement 02NY660R Yamaha YFM660R Raptor (2001-2005) 9 08-05-2015 11:49 PM
one way bearing replacement catchup Yamaha YFM660R Raptor (2001-2005) 6 10-30-2012 09:55 AM
Please help. Carrier bearing replacement ? BL54FD Yamaha YFM350 Raptor/Warrior ('87-Present) 3 05-07-2005 11:55 PM
Help! Shock bearing replacement jumpingjack Yamaha YFM350 Raptor/Warrior ('87-Present) 0 04-20-2004 09:47 AM
Upper Shock Bearing Replacement GETBENTFREERIDERS Yamaha YFZ350 Banshee (1987-Present) 0 04-11-2004 04:35 PM
