Transmission Oil Level - Yamaha ATV Forum
This is a discussion on Transmission Oil Level within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; I stripped the threads on the transmission oil casing, as some of you might already know. Well my dad and I went riding around town ...
Old 04-19-2004, 12:49 AM   #1
View punk_rocker128's Photo Gallery(0)
Default Transmission Oil Level
I stripped the threads on the transmission oil casing, as some of you might already know. Well my dad and I went riding around town for an hour looking at all the auto aprts stores for 12mm Heli Coil. None of them had it. We finally went to a store that had a 12x1.75mm oversized bolt that cut its own threads. After draining the oil and putting the bolt back in, we read th manual for awhile. It told us to put 0.69 Quarts of oil into the machine (or inbetween the marks on the glass window). So we put 2 cups in, then about a fingernails length under the cup mark for 3 cups. It seemed like enough oil. I rode around for 5 minutes then came back and let it sit overnight. The next day, I looked and the whole screen was filled with oil. I dont want to drail some out, because I know we put the right amount in. But I'm not sure if I should. Do you guys go by the marks on the window, or do you just measure it out, put it in, and call it good?
'04 Blaster with blue hubs, smith grips, removed air box and toomey b1 kit.
'98 Honda Foreman
caught under wheels roll, i take that leash im bleeding me. cant stop to save my soul, i take the leash thats bleeding me.
punk_rocker128 is offline   Reply With Quote
Old 04-19-2004, 03:21 PM   #2
View high_octane94's Photo Gallery(0)
i just measure it put it in and im good to go. i dont usually check the window
**1992 RED/BLUE BLASTER**
high_octane94 is offline   Reply With Quote
Old 04-19-2004, 04:54 PM   #3
Blasterboy86 told me that he just pours a quart into his and he's been doing that for 2 years with no problems.
'98 Honda Foreman
Old 04-19-2004, 05:31 PM   #4
View blasterboy86's Photo Gallery(0)
i put a little less than a liter in.
12:97:24:99
blasterboy86 is offline   Reply With Quote
Old 04-19-2004, 05:41 PM   #5
View TTracin574's Photo Gallery(0)
i use between a half and 3/4....its about perfect.....cuz 0.50 is half.....0.75 is 3/4, and it calls for 0.69.....tehehehehe
02' Nac's/PB Blaster
To many mods to list
Set up for TT
05' sponsor: Project Blaster
TTracin574 is offline   Reply With Quote
Old 04-19-2004, 09:42 PM   #6
View 99LRDblaster's Photo Gallery(0)
the clymer says refill it to 700ml if the cover came off and then ride it and let it warm up and shut it off and let it sit for couple minutes and then check the fill window.
99 HOLLYWOOD DIRT BUILT BLASTER~Port Design #3~stock carb rifled and bored to 30mm~head prop rechambering and milled, Trenga/LRD exhaust~Boyesen Pro Series Reeds~+3 extended swingarm~Douglas rears~Nac's seat cover~Outerwears airbox cover~AC Racing bumper~14/40 gearing~ported intake boot~O/I blockoff
www.hollywooddirtproductions.com
99LRDblaster is offline   Reply With Quote
yamaha blaster transmission oil capacity
how much transmission goes in yfs 200
yamaha blaster crankcase oil capacity
how much gear oil does a yamaha blaster take
how much oil does a 2000 blaster take
yamaha blaster oil capacity
2004 raptor 350 transmission fluid
how much gear oil goes in yamaha blaster
check bolt on 2003 blaster
2003 yamaha blaster transmission oil quantity
what tranny fluid for yamaha blaster
how much oil gos in a yamaha banshee crankcase
oil level 2strokeduner Yamaha YFS200 Blaster ('88-Present) 3 03-04-2004 06:13 PM
Oil level bigmackloud Yamaha YFM350 Raptor/Warrior ('87-Present) 8 08-29-2003 09:05 AM
Oil level Raptor660rman Yamaha YFM660R Raptor (2001-2005) 4 07-29-2003 07:34 PM
Sea Level Jetting torombolo Yamaha YFZ350 Banshee (1987-Present) 3 04-22-2003 06:04 PM
Low Oil Level? RaptorDude Yamaha YFM660R Raptor (2001-2005) 5 12-03-2001 06:39 PM
