high idle - Yamaha ATV Forum
high idle
This is a discussion on high idle within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; Hey whats up the idle on my blaster is fine when i start it and it's in nutrel, but when i ride it for a ...
Old 03-27-2004, 03:28 PM   #1
View 32blaster's Photo Gallery(0)
Default high idle
Hey whats up the idle on my blaster is fine when i start it and it's in nutrel, but when i ride it for a little bit the idle is always high, any ideas????
thanks
32blaster is offline   Reply With Quote
Old 03-27-2004, 06:52 PM   #2
View yammerhammer92's Photo Gallery(0)
It could be sucking air from somewhere. Mine did that to and I found the carb cap was loose because of the TORS. It could be alot of other things too.
Old Enough to Know Better but Still Young Enough not to Care.
yammerhammer92 is offline   Reply With Quote
Old 03-27-2004, 08:31 PM   #3
View Raptorride69's Photo Gallery(0)
Maybe you just have to turn down your idle a little bit, once you warm them up, the idle a little higher, you'll just have a harder time when its still cold...
White&Red WHY EF ZEE
Raptorride69 is offline   Reply With Quote
Old 03-28-2004, 07:58 AM   #4
View blaster105's Photo Gallery(0)
yeah it does it with mine the idel is fine and when up to full operating temp it seems to get a tad hight so i just lowered mine. Also make sure the throttle cable is not being pulled up at the bars when your turn
blaster105 is offline   Reply With Quote
Old 03-29-2004, 02:50 AM   #5
View HellaBlaster88's Photo Gallery(0)
First try adjusting your idle at the TORS, if that doesn't fix it, spray some wd 40 around the reed and head gaskets. If the engine revs up when you do that, you got an air leak. If not one of those 2 gaskets, it's the base gasket. I had that same problem with mine before.
1999 Full Blown MX Ready Blaster-couple mods
HellaBlaster88 is offline   Reply With Quote
Old 04-01-2004, 01:25 AM   #6
View fortune46x's Photo Gallery(0)
your either sucking in air as everyone has been saying or you may even be dealing with a gummed up throttle cable - do the wd 40 test - spray it around your carb boots, around your intake, and around your base gasket. if it rev's then youve found your problem, I dont think its your tors because if it were the tors it would always be a high idle, your throttle may just be sticking slightly or your sucking in air somewhere
fortune46x is offline   Reply With Quote
Old 04-05-2004, 01:27 PM   #7
View QUADSandDUBS's Photo Gallery(0)
NewB here could someone please tell me what TORS means
QUADSandDUBS is offline   Reply With Quote
Old 04-05-2004, 01:32 PM   #8
View trailboss's Photo Gallery(0)
the thing on the top of your carb, i belive it stands for throttle override system..
00'Blaster with Maier, FMF, boyseen, T-9s, klaws, K&N, etc.
98 Ram with jet, flowmaster, rancho, interco, rhino, and so much more
trailboss is offline   Reply With Quote
Old 04-05-2004, 05:08 PM   #9
View high_octane94's Photo Gallery(0)
if your throttle sticks the tors kills the engine i would just unplug it its a useless safety feature
**1992 RED/BLUE BLASTER**
high_octane94 is offline   Reply With Quote
Old 04-10-2004, 01:03 AM   #10
View fastb's Photo Gallery(0)
Mine did the same thing and it was becausse it rumbled and turned up by its self. Duck tap works grate.
I have a 250 blasster with wheel spacers, fmf power core 11, fatty pipe, renthal handel bars, hand guards, maxxis tires, douglas wheels, +2 inch swingarm, steel brake lines, kn air filter, pre charger, air vents in air boxs, nerfs, costum lights and light casing that mounts on my frame, alumimum foot guards, white fenders, blue frame, trenga racing stiker kit.
fastb is offline   Reply With Quote
Old 04-20-2004, 03:25 AM   #11
View topstoy's Photo Gallery(0)
Ours started doing that and found the lower cylinder gasket was leaking. After pulling cylinder found the gasket had sucked in a piece. This was like brand new. I put a new gasket on it and works great.
topstoy is offline   Reply With Quote
blaster high idle
yamaha blaster high idle problem
yamaha atv idle high in neutral
yamaha 250 idle high after warmup
blaster idles high after riding
do a 250 yamaha blaster idle high
blaster idles high after warm
yamaha blaster idles high after riding
atv high idle after warm
350 yamaha warrior high idle after warm up
blaster idle high
why does the idle get higher on my atv as it warms up
high idle Shaun Yamaha YFM660R Raptor (2001-2005) 6 01-07-2009 12:26 AM
raptor idle too high...? OneCar60Mexicans Yamaha YFM660R Raptor (2001-2005) 1 03-20-2005 04:04 PM
High Idle Jbud Yamaha YFM660R Raptor (2001-2005) 4 01-07-2005 12:06 AM
Why such a high idle? poping at WOT. YamahaForever Yamaha YFM350 Raptor/Warrior ('87-Present) 10 03-28-2004 04:25 PM
how high should it idle? DOM420247 Yamaha YFM660R Raptor (2001-2005) 4 08-05-2002 05:25 PM
