02-11-2004, 06:25 PM
blaster oil injector block off
can anyone whos done this mod tell me exactly how they did it....i mean the custom block off job....not the one they bought...i'd buy the block off but i'm 15 and savin every penny i got for a yfz....i'm doin it cuz my oil injector quit and now i'm rebuildin the motor....but i need to have it done this weekend so i can go ridin...thats when my motor gets done
04 Blue Sparks YFZ
AMA district 3 Quad Novice #103
02-11-2004, 06:28 PM
on the kick-starter side of the engine take the cover offand inside there will be a white gear take that out and put everything back together the way it was now u have to close the hole that the oil line goes in the crab and thats it and then remove the tank and stuff and ur allset
2004 blaster for sale
2001 cr 125
02-11-2004, 06:41 PM
it'll still work...just leave that lil drive shaft in there right?
04 Blue Sparks YFZ
02-11-2004, 06:43 PM
yea leave everything in exept the white gear
2001 cr 125
02-11-2004, 06:45 PM
aight...thanx
04 Blue Sparks YFZ
02-12-2004, 12:40 AM
yes.
drain oil.
remove clutch cover.
remove white gear an washer and E clip on back of clutch cover.
remove lines from pump.
fill hole in top of clutch cover with silicone or goop.
plug the inlet to the carb. (i left about 1/2" of tubing and filled it with goop and super glue)
remove oil tank and bracket.
re-fill tranny with oil.
drain ALL of the gas in your tank.
premix or die :)
12:97:24:99
02-12-2004, 06:05 AM
thanx guys....this helped me out ALOT
04 Blue Sparks YFZ
02-12-2004, 03:31 PM
oh dont forget you need a new clutch cover gasket when you put it back together
12:97:24:99
02-12-2004, 04:39 PM
no only if you rip it it need a new gasket
2001 cr 125
02-12-2004, 04:51 PM
#10
no you should put a new one either way.
12:97:24:99
02-12-2004, 05:00 PM
#11
we should see how he made out and if can go riding
2001 cr 125
02-12-2004, 06:36 PM
#12
I think you mean the oil pump cover. The clutch cover is on the left side of the engine.
99 Blaster
-HDP carb rifle, The prop,
-Toomey B1
-Moto Tassinari Delta 2 Reeds
-Shredders in the rear
-2.5" Durablue rear wheel spacers
02-12-2004, 06:42 PM
#13
I always reuse gaskets. I usually just put a dab of silcone around it and stick it back on, unless it is ripped.
Old Enough to Know Better but Still Young Enough not to Care.
02-12-2004, 08:06 PM
#14
No, i mean the clutch cover, you need to remove it to get the white gear off. i would know because i did it. the clutch cover is on the right side of the engine. left is the stator. it is always BEST to use a new gasket. better safe than sorry. wouldnt you feel stupid of you seized up in the middle of a ride because your gasket leaked all of the oil out?
12:97:24:99
02-12-2004, 08:31 PM
#15
i've got a new gasket right here that i'm using anyways
04 Blue Sparks YFZ
02-12-2004, 08:33 PM
#16
Yea your right. When you said clutch cover it through me off. I thought you were talking about the oil pump cover (I always forget that there is two covers on the right side).
99 Blaster
-Toomey B1
02-13-2004, 07:17 PM
#17
You won't sieze if the oil leaks out--it's a two stroke, remember?
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Roost Boost
Answer bars
OMF swingarm skid
Three Wheelin' Since '84
02-13-2004, 07:44 PM
#18
l
l
hes right
2001 cr 125
02-13-2004, 08:14 PM
#19
The tranny could lock up if all the oil ran out and all the parts got too hot. Maybe that is what he ment.
blaster oil block off, how to take out oil injector on 2004 blaster, 99 blaster oil, yamaha blaster oil block off, where is the oil injector on a 04 blaster, 2004 blaster oil injection where is it, what side is the clutch on a 2004 blaster, how to remove blaster oil pump, how to tell if oil injection is working on a 2004 blaster, how to remove the oil injector from a yfs200, injector oil 2004 blaster, removing oil injection on a 2004 blaster, how to delete.ghe oil injector.on 2001 yamaha blaster, oil pump delete blaster, blaster oil injector block off mod
