hooking up mini hallogen lights? - Yamaha ATV Forum
post #1 of 9 Old 01-17-2004, 07:37 PM Thread Starter
Send a message via AIM to blaster105
i have a pair of 12 v blue bright fog lights and i am going to put them on the part between the front fenders. The wiring for them is each light has a ground loop wire and a white positive that has a male end that plugs into a single wire that would then go to the main light power.Both light plug go into that one wire. I am currently do not have a headlight on it so can i jus wire it into that wiring. How would i go about doing this.
blasterboy has them i think has the same kind i do. here a pic from blasterboy i found this is exactly what i want to do to mine.
http://www.imagestation.com/picture/...a/fada6415.jpg
blaster105 is offline
post #2 of 9 Old 01-17-2004, 08:38 PM
Send a message via AIM to RxRaptor02
yeah you can wire the fog lights into the stock headlight plug.
the next question you should look at is: can the stator run the two lights without any problems
----Michrider----
----Hatfield/Mccoy veteran '05----
-----Tug Hill veteran '03 '04------
raptor, lakota, KDX200
RxRaptor02 is offline
post #3 of 9 Old 01-17-2004, 08:46 PM Thread Starter
i have no clue. How would i go bout wire=ing it to the stock light plug. here is a low beam and high. All i have coming from the fog lights is 1 wire now where would that plug to if there are like 3 or so wires for the stock light.
post #4 of 9 Old 01-17-2004, 10:14 PM
The blaster lightbulb has both a high and low beam filament inside it. One of the wires is the ground, and the other two wires for the stock headlight are each used to power the high and low beam. You'll probably want to hook the lights up to the high beam wire.
Before you hook them up, you might want to look on the fog lights to see how much power they need. I think the max power the stock stator on a blaster can safely put out is around 60 watts. Personally I'd take the stock light over those anyday.
1999 Yamaha Wolverine
-K&N Filter with jet kit
"Do you play the game, or does the game play you???"
edge is offline
post #5 of 9 Old 01-17-2004, 10:41 PM
Send a message via AIM to blasterboy86 Send a message via MSN to blasterboy86 Send a message via Yahoo to blasterboy86
they work good
i hooked mine in through the high beam switch
in that picture, the ugly green wire has a coupler that 1 wire from each light hooks into and then the green wire is converted into just one so you can hook it into the high beam switch. the other wires from the light goes to ground.
12:97:24:99
blasterboy86 is offline
post #6 of 9 Old 01-18-2004, 06:53 AM Thread Starter
ya but which wire is the high beam there is a low and high plug and another male end right?
post #7 of 9 Old 01-18-2004, 01:37 PM
Send a message via AIM to cbrf41999
I forget which wire is which, but I wired it for one of my driving lights aimed lower, on the low beam side, and then the other was aimed upwards. When on high beam they both would be on. Mine were 25 watts each, they worked adequate to get me home. I didnt leave at night, but could get home at night on familiar trails.
Check www.sportbikesforum.com for streetbike info.
cbrf41999 is offline
post #8 of 9 Old 01-18-2004, 02:54 PM
i think i have another picture that shows the wires. i would go take one but my camera is broken and my blaster isnt here. ill try and find it
EDIT********************************************** *******
you would be surprised how many people ask for the same thing, i made this a while ago
shit, now that i look at it again it doesnt show the high beam wires.......i think it was a green one though
12:97:24:99
post #9 of 9 Old 01-21-2004, 06:30 PM
Send a message via AIM to quadmaniac04
i deffinetly think mini fog lights work much better, my buddy took a spill on his Raptor and smashed the lights so we put on blue fogs, it looks awesome, and they are really bright
quadmaniac04 is offline
Hooking up additional Lights... mall0y Yamaha YFZ350 Banshee (1987-Present) 7 08-27-2004 06:48 PM
Blaster's with mini halogen lights?? 250exrider Yamaha YFS200 Blaster ('88-Present) 6 07-31-2003 02:33 AM
