Changing piston and rings before it blows? - Yamaha ATV Forum
This is a discussion on Changing piston and rings before it blows? within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; While my Blaster is still running great, I am pretty sure it has the original top end (5 years). I am thinking about putting a ...
Old 01-02-2004, 11:38 PM   #1
View Punisher's Photo Gallery(0)
Default Changing piston and rings before it blows?
While my Blaster is still running great, I am pretty sure it has the original top end (5 years). I am thinking about putting a new piston and rings in it before it blows out on a trail. Would it be worth it or is the normal wear on the cylinder walls significant enough for me to have to bore it out?
99 Blaster
-HDP carb rifle, The prop,
-Toomey B1
-Moto Tassinari Delta 2 Reeds
-Shredders in the rear
-2.5" Durablue rear wheel spacers
Punisher is offline   Reply With Quote
Old 01-02-2004, 11:40 PM   #2
View trailboss's Photo Gallery(0)
My MOTO: Dont fix it unless its broke
00'Blaster with Maier, FMF, boyseen, T-9s, klaws, K&N, etc.
98 Ram with jet, flowmaster, rancho, interco, rhino, and so much more
trailboss is offline   Reply With Quote
Old 01-02-2004, 11:42 PM   #3
What about always be prepared ?
I forgot to mention that I'm going to have the top end off anyways.
99 Blaster
-Toomey B1
Old 01-02-2004, 11:48 PM   #4
View alaskabanshee's Photo Gallery(0)
i think it depends on all you want to do i would have it redone anyways just to know its done and i wouldnt have to worry about it.
97 shee
v-force
boost bottle
+4 timing
8+ swing arm
18cc noss head
35mm carbs
PRO CIRCUIT PLATINUM PIPES AND SILENCERS
alaskabanshee is offline   Reply With Quote
Old 01-03-2004, 12:15 AM   #5
View banshee killer's Photo Gallery(0)
get it redone before ur piston drops a skirt and ruins the crank like mine did, lol actually just do it may not be time yet but its worth it just to kno ur ridin on a new topend and u can relyon it now
Parting 06 450ER
1992 Mustang Coupe-13 Sec
1998 Camaro Z28 1LE-12 Sec
CBR600-11 sec
banshee killer is offline   Reply With Quote
Old 01-03-2004, 12:35 AM   #6
View mxthunder's Photo Gallery(0)
yeah, my friends 96 dropped a skirt on the orignial top end, if you are going to have it apart anyways then go for it.
04 YFZ450 - WR crank, oil mod, CP 13:1 piston, Full Yosh TRS Ti pipe, hotcams intake, cam mod, YZ clutch mod, GYTR basket, FCI, 1" lowering peg nerfs, LSR axle, Pro tapers and Housier +1" stem, PRM desert grab bar, AC bumper, XCR tires and more 175M NCVQ #5 50p | 2010 YFZ450X - HMF Tuner, PRM bolt-ons, Aluminum airbox + K&N Filter
mxthunder is offline   Reply With Quote
Old 01-03-2004, 12:38 AM   #7
View yamablaster024's Photo Gallery(0)
that was m post above sorry lol,i kind of signed in the wrong sn,
97 mx blaster 30mm mikuni carb,
WSM aluminum piston,bored.50 over,
AC racing nerfs- grab bar,
FMF exhaust,
boyesen reeds/ spacer,
Trenga intake,
front end extended 4"
PD tether,
K+N Filter,lid-less
BAnshee front shocks
front 19" holeshtos
cut front and rear fenders,
alloy bars,
18" turf tamers on doug redlabels
yamablaster024 is offline   Reply With Quote
Old 01-03-2004, 08:05 PM   #8
View Yamadood's Photo Gallery(0)
I think if I were to consider putting in a new piston/ring assy I would go on and have it bored;that way you KNOW the cylinder is round and the clearances are correct.
1998 Yamaha Blaster;Wiseco & DG goodies..
1993 Yamaha Timberwolf.
1985 Honda ATC250ES.
1985 Yamaha Badger.
Yamadood is offline   Reply With Quote
Old 01-03-2004, 08:58 PM   #9
View tbone07's Photo Gallery(0)
I would run a compression check and then decide from there. My piston dropped its skirt . 96 blasty wit original piston. But it was runnin lean.
blaster sold - im a traitor and am getting a car
www.ohiomafiariders.com
tbone07 is offline   Reply With Quote
Old 01-04-2004, 01:50 PM   #10
View empty-wallet's Photo Gallery(0)
How are you all dropping skirts? i have been around alot of blasters and never had one do that? Idk i guess bad luck.
5 years on the topend DO IT. You are not even knowing the full potential of the little 2-stroke. With a new topend PUT IN CORRECT it will wake it up and run good. When i got my 00 we replaced the topend in 02 i believe it was. My uncle replaces the piston and rings in his kx250 every 20hrs...me its every yr unless it seizes.
and yes if the blaster was ridden a decent amount it will need to be bored. I would just go like .020 anyway with a good Wiseco Pro-lite piston
www.myspace.com/kylejandura
empty-wallet is offline   Reply With Quote
Old 01-04-2004, 02:43 PM   #11
View high_octane94's Photo Gallery(0)
my blaster is a 92 and it had its original piston up until now. It never blew or anything but the piston and rings were awefully scored
**1992 RED/BLUE BLASTER**
high_octane94 is offline   Reply With Quote
Old 01-04-2004, 11:52 PM   #12
Wow that's very impressive.
I'm thinking about just sending out my top end to HDP to get it PD#2'd and bored. And while I wait I'll get a Pro-lite piston.
Thanks for your input guys.
99 Blaster
-Toomey B1
Old 01-05-2004, 12:21 AM   #13
View Blastermaster58's Photo Gallery(0)
Go for it, 5 year old top end, its due ne time to blow or drop a skirt. Top ends are really easy, and cheap to do too. They only cost my like $80 max. But i reused the wristpin, so add the price of a wristpin to that. I say go for it. Its worth your time
Quadless.
But I have a car now! 95 Tsi AWD Talon
Blastermaster58 is offline   Reply With Quote
Old 01-05-2004, 06:05 PM   #14
just cause a topend is old does not mean it will drop a skirt. The rings will wear and you will have blow-by, and loose compression. Plus where are you getting your topend at...lol?
$80 max....i dont think so.
If you but all these parts FROM A DEALER the wiseco piston/ring set is around $80 alone...prob close to $90. Then head and base gaskets are around another $20. Then if you need is bored that is about another $65 (dealer cost here)
you are looking at close to 150-200 IF you do it your self and IF YOU BUY A NEW PISTON
Old 01-05-2004, 07:16 PM   #15
View icemancometh's Photo Gallery(0)
YA CHANGE IT, I DO BOTH OF MY QUADS ONCE A YEAR WEATHER IT NEEDS IT OR NOT, DEFITNLY HAVE IT BORED AND REPLACE THE PIN BEARING.ALSO GET THE PISTON KIT AND HAVE IT BOARD AT THE SAME PLACE THEY WILL MAKE SURE EVERTHING IS GOOD PLUS IT ONLY COST AROUND $40 FOR THE BORE DOWN HERE AT DUNERS ATV IN CHANLDER,AZ AND THE PISTON KIT ARE $10 OR SO HIGHER THAN THE MAGAZINE ADDS
PIECE OF MIND AND REALIBILTY
89 Banshee
96 Blaster
icemancometh is offline   Reply With Quote
Old 01-05-2004, 07:46 PM   #16
ya that will keep them runnin strong, not every year tho for a person on a budget lol
FMF exhaust,
Trenga intake,
PD tether,
K+N Filter,lid-less
front 19" holeshtos
alloy bars,
Old 01-05-2004, 09:13 PM   #17
View FBRacing80's Photo Gallery(0)
hey i would just go ahead and do it better safe than sorry my bike ran on stock bore for 15 years!!! but my blasty was mint whenever i bought it i also dropped the skirt 2 but it was from piston slap if you hear a knocking its time to get it freshened up piston slap will occur from the bore on the cylinder being 2 big (oval shape) and the piston moving back and forth actually "slapping" the piston skirt on the cylinder
04 YFZ in the process of rebuilding
FBRacing80 is offline   Reply With Quote
Old 01-06-2004, 03:06 PM   #18
I didnt get a wiseco, i got a yamaha piston. But u know wut i meant, its not that expensive just to replace the top end, under $100. I wasnt counting boirng either, just the piston, rings, etc. later-
Quadless.
Old 01-25-2004, 07:53 PM   #19
View Blasterfoo's Photo Gallery(0)
I know this is an old post but i have a question can i just replace my piston on stock bore?And have it work fine or not Because im on year 4 wit original top end i belive
2001 Red and black Blasty
I use Duct Tape to stop stuff from movin and WD40 to make things move.
Blasterfoo is offline   Reply With Quote
Old 01-25-2004, 07:59 PM   #20
yes, u can just hone the cylinder out, have a respectable dealer who has a honer do this and u can run stock bore size,
FMF exhaust,
Trenga intake,
PD tether,
K+N Filter,lid-less
front 19" holeshtos
alloy bars,
how much to replace oil rings on a 350 yamaha
how to replace piston on yamaha blaster
how much does it cost to change the rings in a 350 warrior
do i have to replace rings when pulling a blaster apart
is it good to do new pistons in an old fourwheeler
on 2001 blaster which way rings go
how often should i re ring my 250 blaster
when installing a piston on a 2003 yamaha blaster 200 should the piston move from side to side any
how to replace piston rings on a 97 timberwolf
replacing piston rings in a yamaha four wheeler you tube
how much time to redo a top end on a yamaha rhino
250 timberwolve piston clearance
Piston rings keep breaking!! jg24fans Yamaha YFS200 Blaster ('88-Present) 11 04-17-2005 09:01 PM
New rings or piston?? warriorqueen Yamaha YFM350 Raptor/Warrior ('87-Present) 16 10-08-2004 04:27 PM
rings for a j.e. piston jmoney Yamaha YFM660R Raptor (2001-2005) 0 03-13-2004 08:14 AM
stock piston rings .. shabeebah Yamaha YFZ350 Banshee (1987-Present) 1 05-25-2003 11:22 AM
