Vito's degree key install questions - Yamaha ATV Forum
This is a discussion on Vito's degree key install questions within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; is the vito's degree key hard to install? anyone have step by step instructions on how to do it? where exactly do you install it?...
Old 11-27-2003, 11:33 PM   #1
View Knight2040's Photo Gallery(0)
Default Vito's degree key install questions
Red&Black 2003 Yamaha Blaster - Adjustable LRD Pipe & Silencer,LRD Jet Kit,Graydon Proline GPCM Aluminum Nerf Bars,Vito's Reed Spacer,K&N Air Filter,Outerwear Prefilter,Boyesen Power Reeds,Pro Design Thether Kill Switch,14T Front Sprocket,Scott Comp II Grips,PRM Standard Grab Bar,Removed Airbox Lid*Coming Soon-20x11x9TurfTamers*
Knight2040 is offline   Reply With Quote
Old 11-28-2003, 12:00 AM   #2
View blasterboy86's Photo Gallery(0)
ask mini banshee. he just did one and knows how
12:97:24:99
blasterboy86 is offline   Reply With Quote
Old 11-28-2003, 09:17 PM   #3
View koby13's Photo Gallery(0)
is it worth it? can you notice the power difference??
86 250R
koby13 is offline   Reply With Quote
Old 11-28-2003, 09:41 PM   #4
View FBRacing80's Photo Gallery(0)
Its pretty simple. I dont know how much power you gain but I had my entire bottom end apart and put a new crank in and had to use the old key. All you do is take the magneto cover off, get a flywheel puller (i think its like $20) pull the fly wheel then just take like a chisle and tap the key outta the crank, i dont think you have to use any glue or anything when you put it back together just get in good and the mag should hold it in place.then just put everything backtogether. Just be carefull cause when my dad hit the puller(you screw the puller in ,left handed thread, then tighted the bar in the middle well you hit the bar in the middle after you tighten it up and it pops it out) well when he hit it it somehow bent the crank a little bit and i had to get a whole new crank. Just my 2 cents lemme know if it works.
Rusty
04 YFZ in the process of rebuilding
FBRacing80 is offline   Reply With Quote
Old 11-28-2003, 09:55 PM   #5
hey is taking the fly wheel hard? thats the only reason why i'm hesitating to buy the key, what are the chances of me screwin soemthin up?
Old 11-29-2003, 09:41 PM   #6
well if your working on your 2003 i wouldnt imagine it would be all that hard just get the tool and use it how its spost to be (screwed in left handed good then tighten the bar in the middle up and hit it with at hammer) i think the only reason my dad bent my crankshaft is because the bike is 15 years old tho (great shape ill post some pics if you want me 2) and water has got in there and kinda rusted it to the crank but sh!t happens lol i think youll be fine tho just one of them freak things that coincides with my luck
Old 11-29-2003, 11:04 PM   #7
View high_octane94's Photo Gallery(0)
post some pics
**1992 RED/BLUE BLASTER**
high_octane94 is offline   Reply With Quote
Old 11-29-2003, 11:30 PM   #8
hey i still havent mastered posting pics so heres a link to my website they aint the greatest and the mods are diff now. heres a list of them.....
http://www.geocities.com/fatboysracing03/RustysBlaster
Vito’s 240 Big Bore, Ported and Polished, Factory Crank Replacement, Boyesen Carbon Fiber Reeds, FMF Fatty Pipe, FMF Powercore II, WST Reed Spacer, Rear Douglas .190 Wheels, 20x10x8 Bandit Rear Tires, Trail Tech Computer, Pro Grip Grips, Kill Switch, Jetted Carb, K&N Air filter, Oil Injector Block Off, Sunstar Rear Sprocket 42 tooth, JT Front Sprocket 14 tooth, Shockwears, DG Baja Belly Skid, DG A-Arm Skids, Custom Polished Alum. Grill
Old 11-30-2003, 08:15 PM   #9
View Blastermaster58's Photo Gallery(0)
Thats an 88?!?!? That thing is in great shape, keep it that way, only thing i would buy is a graphics kit, and a seat cover, then it'll look real sweet. O btw, looks like ur handlebars are a little tweeked, are they?
Quadless.
But I have a car now! 95 Tsi AWD Talon
Blastermaster58 is offline   Reply With Quote
Old 11-30-2003, 08:31 PM   #10
yea its an 88 but its tore apart in pieces now we went ahead and repainted ever last thing and i went 240 big bore i couldnt complain 15 years old with stock bore and stock clutch (it was completely stock when i got it 2 years ago) the front bumper was and is practically flawless besides for a couple little bumps yea the handle bars are a little tweeked from the 1 and only (that i know of) time that its been rolled and that was this summer the left side is 1 inch lower than the right cant really tell when you ride it tho thanks even tho i figured you would be the last person to say something lol like i said i was just trying to share some info didnt mean any harm
Old 12-01-2003, 08:31 AM   #11
nicest 88 ive seen . great job
Old 12-01-2003, 03:22 PM   #12
yea, i know, but its a nicec blaster! Nicest blaster ive ever seen that's taht old!
Quadless.
Old 12-02-2003, 07:56 PM   #13
hey thanks guys ill try and get some pics of it at the moment its just frame a-arms steering stem handlebars and controls but my motor is ready to paint then put back together now that we got it ported and polished some more btw has anyone heard about running an aftermarket needle with the stock carb for the 240 kit i talked to vito and he said that i would take a chance of siezen it if i didnt get a aftermarket needle? thanks
Rusty
Old 12-02-2003, 08:34 PM   #14
I have no idea how taht would make u more vulnerable for seizing. Then again i dont know anything about the carb neeedle, so dont take my word for it
Quadless.
Old 12-03-2003, 03:49 PM   #15
beats me maybe he meant the carb siezen like the needle getting stuck or something who knows?
Old 12-03-2003, 05:49 PM   #16
View Mini Banshee's Photo Gallery(0)
They are a possible chance of shearing the key, but it's well worth it, only 25 bucks and 10 for the flywheel puller!
Old Toys
2k Toomey Blasty
01 Rappy. Trail Tech,686 Kit, w/ stage 2 cam, Keeble HD Valve spring
Custom Drag Banshee..sold..Ran 4.2 at 76MPH in 300 ft.
04' SE Toomey Banshee
New Toys
08 Kawa 650 Brute Force. SS Rims, 26" Super Grip Tires, LRD Slip-on, Warn Winch
97 Suzuki RM 80. FMF P&S
Mini Banshee is offline   Reply With Quote
Old 12-03-2003, 06:52 PM   #17
Location: Wintersville, OH......45 miles west of Pittsburgh, PA
View FBRacing76's Photo Gallery(0)
There ya go!
OhioMafiaRiders.com
FBRacing76 is offline   Reply With Quote
Old 12-03-2003, 08:22 PM   #18
that will look real sweet with the red frame. im not much for the black front bumper . Still very cool.
Old 12-04-2003, 01:56 PM   #19
Hey FB, what size of rear tires are those?
Old Toys
2k Toomey Blasty
New Toys
Old 12-04-2003, 07:48 PM   #20
they are 20 inch bandits i like the front bumper thats the ssame one that came on it in 88 and only got a couple of little dings so i just painted it and said forget it i know if i spend the money on a front bumper the first time i got riding ill smack a tree i have pics of it with more stuff put back on but my other buddy got the disk the pics are on post them tomorrow or so
vito's degree key
how to set vito's blaster timing key
banshee degree key install
banshee vitos degree key
4 degree offset flywheel key warrior
installation instructions vitos timing key banshee
vitos key yamaha warrior
vitos key yamaha raptor 350
vitoes degree key install
yamaha banshee degree key install
vitos degree key offset front.or.back?
how to set vito's blaster timing key#gsc.tab
Vito's Degree Key crazy-blasterd Yamaha YFZ350 Banshee (1987-Present) 6 01-16-2004 08:37 PM
--- Vito's Degree Key --- Warrior03 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 04-23-2003 01:11 PM
Degree key install - flywheel puller sanpaper Yamaha YFZ350 Banshee (1987-Present) 6 01-31-2003 04:34 PM
vito's degree key louisianablaster Yamaha YFZ350 Banshee (1987-Present) 2 03-19-2002 08:39 PM
reed spacer or vito's degree key Blasterkid13 Yamaha YFZ350 Banshee (1987-Present) 1 02-27-2002 04:44 PM
