2002 Yamaha Blaster, rear disc brake (cable) - Yamaha ATV Forum
This is a discussion on 2002 Yamaha Blaster, rear disc brake (cable) within the Yamaha YFS200 Blaster ('88-Present) forums, part of the Performance /Technical category; Has anyone had there rear disc brake (cable controlled) on a 2002 Blaster lock up on them? Over the weekend I had to take the ...
Old 10-15-2003, 03:29 PM   #1
eman40000's Avatar
View eman40000's Photo Gallery(0)
Default 2002 Yamaha Blaster, rear disc brake (cable)
lock up on them? Over the weekend I had to take the rear brake caliper off so it was still ride able, I didn't want to take part the caliper part out in the middle of the desert so I just removed the caliper from the disc. I loosenedup the adjusting on the cable and did not work. I checked parking brake and it was not engaged.Any ideas how to unlock the caliper?
eman40000 is offline   Reply With Quote
Old 10-15-2003, 04:01 PM   #2
View Tease405's Photo Gallery(0)
Wow... riding hard huh?
I am not an expert on Blaster brakes, but one thing for sure to do is check the linkage on the caliper and make sure there is not dirt, rocks, etc. stuck in there causing it to clamp up. Also, check the brake lock and make sure it did not get stuck engaged. :cool:
2002 YZ250 Little of this, little of that
2003 Raptor Enough to make me happy
Looking for an 2005 Raptor Parking Brake System. PM me if you got one (only looking for Raptor and only 2005)
http://www.bluetraxx.com/phpBB/viewtopic.php?t=68122
A wise man once said "Maybe it was you, maybe it was the bike, either way, you lost."
Tease405 is offline   Reply With Quote
Old 10-15-2003, 04:23 PM   #3
View blasterboy86's Photo Gallery(0)
i had the same thing happen to me i had to zip tie it to the frame so i could ride.
i think i just explained this somewhere, anyways.....
1. the rear blaster brake is supposed to be self adjusting, so with everyrything connected like it should be go pump the brake pedal like 50 times, it might adjust for you (if you cant get it back on the disk then just do it like that)
2. if that didnt work take apart the caliper and re-grease everything. there is a white gear type thing and adjusters. play around with it until you have a setting that looks like it will work. try that out.
12:97:24:99
blasterboy86 is offline   Reply With Quote
Old 10-18-2003, 04:11 PM   #4
View yamablaster024's Photo Gallery(0)
this happened to me, u have to take the three allen screws out on the caliper, then u have to mess with the white dial so it is not touching the cover, it may pop off in which you may have to loosen the cable up to put it back on,if the screws go on real tight then you still have to play with it, the screws should go on easily
97 mx blaster 30mm mikuni carb,
WSM aluminum piston,bored.50 over,
AC racing nerfs- grab bar,
FMF exhaust,
boyesen reeds/ spacer,
Trenga intake,
front end extended 4"
PD tether,
K+N Filter,lid-less
BAnshee front shocks
front 19" holeshtos
cut front and rear fenders,
alloy bars,
18" turf tamers on doug redlabels
yamablaster024 is offline   Reply With Quote
2002 yamaha blaster rear brake caliper
yamaha blaster rear brake adjustment
how to adjust rear brake on 95 yamaha blaster
how to fix disc brake guard for tw200
how to tighten brakes on 2002 blaster four wbeeler
how do you adjust back breaks on a yamaha blaster
how to adjust rear brake cable on a yamaha blaster
rear brakes stuck and brake brake guards melted on yamaha grizzly
2002 blaster rear brake
2002blasterrearbrakecaliper
adjust rear brakes blaster yamaha
2005 blaster come stock with rear hydro disc set2crash67 Yamaha YFS200 Blaster ('88-Present) 18 06-19-2004 07:22 PM
disc brake conversion 86 quad r Yamaha YFS200 Blaster ('88-Present) 12 02-24-2004 06:09 PM
will a baanshee motor fit on a 2002 Yamaha blaster?? bigblueracing Yamaha YFS200 Blaster ('88-Present) 13 08-22-2003 12:44 AM
Extended rear brake cable...where to buy? 1fatcat Yamaha YFS200 Blaster ('88-Present) 7 06-06-2003 10:03 AM
