Removing TORS and kill switch on blaster... HELP? - Yamaha ATV Forum
post #1 of 6 Old 12-11-2001, 06:16 AM Thread Starter
Send a message via AIM to KRUM5150
Hi I was curious to see what the best way to remove the TORS is. I am rewiring my project blaster and would like to remove the TORS and the stock bar mounted light/kill switch. I will be adding a momentary contact kill switch from a YZ bike instead. From the looks of my wiring diagram I should be able to simply disconnect the black and the black/white wires from the CDI, trash the TORS box and switches, and route my new kill switch to those two wires (black,black/white)? Help? Can anyone tell me if this will work or not?
Thanks
KRUM5150 is offline
post #2 of 6 Old 12-11-2001, 12:19 PM
It will if you have the correct throttle cable. When you take off tors, u need a cable that goes from thumb throttle to carb. I have one if you need it.
88 Blaster, Vitos 240cc Big bore, 34mm Kehin PJ Carb, K&N filter, Chrome FMF Fatty, PowerCore2 Silencer, Vitos Degree Key,Barnett Series K Kevlar Clutch, Motion Pro Twist Throttle, Custom Cut fenders, Custom Blue metallic with white frame,21/7/10 Fast Tre
88FastBlast240 is offline
post #3 of 6 Old 12-11-2001, 04:51 PM Thread Starter
What do you mean by
"you need a cable that goes from thumb throttle to carb"
Are you refering to a throttle cable or do you mean a wire? I will be using a warrior thumb throttle, so I the throttle switch will be gone, should I also run a warrior throttle cable?
KRUM5150 is offline
post #4 of 6 Old 12-11-2001, 10:18 PM Thread Starter
Any other ideas?
KRUM5150 is offline
post #5 of 6 Old 10-28-2010, 09:16 PM
OK, I got you covered. I just put a kill switch on my blaster, becuase my wires were the way you are wanting to set your quad up like. Just unplug the four wires from your key switch, two of those wires will need to be connected and the other two stay unconnected unless you want to kill the motor (hook your YZ switch) it will only work one way so try the different combos.
I just took off my TORS so I got you covered there as well. You will need a new throttle cable becuase it needs to be a little longer and the connecting metal ball at the end of the cable is different. It will look like the part of the cable coming out of your TORS and it needs to be able to connect with the jetting needle. I just got a new throttle kit that by-passed the TORS (it had the twist throttle and cables) for about $25(thumb throttles were about $50). Then you have te get an idle kit, because your TORS has an idle and your carb doesn't. It is pretty simple you need a drill press and to be able to tap the hole for your idle screw. Took me about 30 minutes to put the idle on. Hope that helps. MotionPro has an idle screw kit for a Blaster that cost about $25.
diddy25 is offline
post #6 of 6 Old 01-13-2011, 09:46 AM
You can disconnect the tors wiring and box without getting a new cable but to take it off the carb as well you will
YBMcCall1202 is offline
Gunnar Kill Switch (An NO Switch) FurBallz Yamaha YFZ450/450R (2004-Present) 2 06-05-2004 09:08 AM
Removing start/lights/kill button...help! WarriorRacer#13 Yamaha YFM350 Raptor/Warrior ('87-Present) 1 03-02-2004 07:23 PM
Help with Kill Switch specialblend07 Yamaha YFZ350 Banshee (1987-Present) 1 07-01-2003 10:15 PM
No Key or Run Switch on Banshee Just Kill Switch??? FMF_Banshee Yamaha YFZ350 Banshee (1987-Present) 6 08-05-2002 08:57 PM
Removing the TORS 347cc X 2 Yamaha YFZ350 Banshee (1987-Present) 3 12-20-2001 07:39 AM
