chain/sprocket help????? - Yamaha ATV Forum
This is a discussion on chain/sprocket help????? within the Yamaha YFM700R Raptor (2006-Present) forums, part of the Performance /Technical category; Im having a tough time deciding on a new chain/sprocket combo, I wanna add some teeth in the back for a little more top end ...
Go Back   Yamaha ATV Forum > Performance /Technical > Yamaha YFM700R Raptor (2006-Present)
Old 04-06-2008, 06:58 PM   #1
View 1quik700's Photo Gallery(0)
Default chain/sprocket help?????
Im having a tough time deciding on a new chain/sprocket combo, I wanna add some teeth in the back for a little more top end speed but id like to stay as close to stock as possible, any help would be greatly appreciated thanks!
2006 raptor 700
houser racing +1 steering stem/anti-vibe bar mount
tag t2 bars
asv levers
itp baja wheels black
maxxis razr2 tire
dobeck tfi controller
full fmf factory 4.1 system
velocity intake
dura-blue x-33 race axle
Houser + 2 a arms
1quik700 is offline   Reply With Quote
Old 04-06-2008, 07:18 PM   #2
View bberck's Photo Gallery(0)
Alot of us have just went with a 15 tooth on the front (rear same as stock)with good results.
2006 Raptor 700r
bberck is offline   Reply With Quote
Old 04-07-2008, 02:09 AM   #3
how many teeth does the stock rear sprocket have?
2006 raptor 700
tag t2 bars
asv levers
maxxis razr2 tire
velocity intake
Houser + 2 a arms
Old 04-07-2008, 12:05 PM   #4
petedog9's Avatar
View petedog9's Photo Gallery(0)
Your stock gearing is 14/38. The 15T is a popular mod and works great on a stock or 3mod raptor... Its alot easier to swap front sprockets, then rears.... Your gearing really depends on what terrain you are riding. I ride dunes but will often switch gearing depending on what dune location I am riding at. Also tire size will come into play when deciding upon gearing...
I have 14/15/16 up fronts and 36/37/38/39 reaprs so I can try endless combos...
Check out this chart for geraing ratios:
http://nvmyz28.com/quads/700R_Gearing.htm
'06 RF Raptor 700 Ltd Ed. LTE / PCIII / K&N /RF built 11:1 / Web stg. 3 / springs / P&P / Elkas / Flexx bars/ Rox risers / lots of bling
'04 raptor red / white full Yoshi pipe GYTR jet kit 160/165 K&n with outerwear (wifes ride)
petedog9 is offline   Reply With Quote
Old 04-07-2008, 12:34 PM   #5
My stock chain is starting to get some rust on it...I was told that when changind the sprockets, its best to do both and the chain all at the same time, i was looking at the sidewinder package, anything better then that?
2006 raptor 700
tag t2 bars
asv levers
maxxis razr2 tire
velocity intake
Houser + 2 a arms
Old 04-07-2008, 04:41 PM   #6
petedog9's Avatar
Sidewinders are great, just very expensive. It is a good idea to do the chain with the sprockets so they can wear together equally....
Old 04-07-2008, 07:42 PM   #7
whats a good deal...renthal?
2006 raptor 700
tag t2 bars
asv levers
maxxis razr2 tire
velocity intake
Houser + 2 a arms
Old 04-07-2008, 11:43 PM   #8
petedog9's Avatar
I like the quality or Renthal personally. I tend to order them myself when given a choice.
Old 04-08-2008, 12:21 AM   #9
motorhead's Avatar
View motorhead's Photo Gallery(6)
The best chain I have ever used is the RK GB520GXW. Its Gold and is the XW ring. It is rated for 1000cc's and the tensile strength is 8800 lbs. I have had mine now for 6 years on my built 660. Its never stretched.
Trailtech flywheel
Trinity stage IV Exhaust
motorhead is offline   Reply With Quote
Old 04-08-2008, 12:28 PM   #10
petedog9's Avatar
Good info right there. I'll have to check out the RKs next time around. I've always passed them by for the Renthals just due to name recognition and I have never heard of anyone running them...
Old 04-08-2008, 08:11 PM   #11
I think ive decided on the ti II sprockets from sidewinder,paired up with the smart chain, although the prices are a bit steep you cant beat a lifetime warranty, thanks for all the help!!
2006 raptor 700
tag t2 bars
asv levers
maxxis razr2 tire
velocity intake
Houser + 2 a arms
raptor 700 stock sprocket size
raptor 700 stock gearing
raptor 250 sprocket ratio
raptor 700 stock front sprocket size
raptor 700 front sprocket size
2014 700 raptor chain length
2007 raptor 700 gytr gearing
2006 raptor 700 sprocket size
2008 raptor 250 sprocket choices
raptor 700 fastest sprocket
2007 yamaha raptor 700 stock sprocket size
2008 700 raptor stock sprockets
new sprocket/chain 1quik700 Yamaha YFM700R Raptor (2006-Present) 2 12-31-2007 07:41 PM
new sprocket/chain 1quik700 Yamaha YFM700R Raptor (2006-Present) 0 05-24-2007 08:40 PM
Chain/Sprocket ? Chris4x4gill2 Yamaha YFM660R Raptor (2001-2005) 8 05-23-2005 11:58 AM
Need Sprocket and Chain Rappy77 Yamaha YFM660R Raptor (2001-2005) 6 05-23-2004 02:30 AM
Chain and sprocket? Yamaha YFM660R Raptor (2001-2005) 1 07-15-2002 11:15 PM
