timing help - Yamaha ATV Forum
timing help
This is a discussion on timing help within the Yamaha YFM700R Raptor (2006-Present) forums, part of the Performance /Technical category; Wondering if anyone can shed some insight on setting the correct timing. I know this sounds stupid but I want to make sure that I ...
Go Back   Yamaha ATV Forum > Performance /Technical > Yamaha YFM700R Raptor (2006-Present)
Old 10-09-2007, 07:21 PM   #1
View stegman700r's Photo Gallery(0)
Default timing help
Wondering if anyone can shed some insight on setting the correct timing. I know this sounds stupid but I want to make sure that I set the timing correct. I lost my owners manual. Please let me know because I have lost HP on a piston and dual install and can't figure it out. Thanks.
06' 700 Raptor. 11:1 wiseco, barker dual, velocity intake, dobeck efi, stage 1 hotcam, subframe polished, other add-ons.
stegman700r is offline   Reply With Quote
Old 10-10-2007, 02:18 PM   #2
Alaska700's Avatar
View Alaska700's Photo Gallery(0)
To make sure the timing is correct, remove the Cam cover, exposing the cam wheel and chain.
Also remove the plug, that is below it, this one faces up, and shows the flywheel when removed
Rotate the engine until you see a small T, through the small hole.
When the T is centered on the mark. The Cam shaft wheel should have a little timing mark on it. This should be straight up. This is also Top Dead Center for the piston.
I remember this from doing the valve adjustment, but I dont remember what everything is called, though.
I hope this helps for ya
2006 700, AC bumper, Proarmor Nerf/Skid plates, K&N Intake, LSR axle, Two Bros Slip on, PCIII, 22x12.5 ITPs, Trail tech Comp, more
04 Dodge 1500 Off Road Ed. 5.7
03 Suzuki SV 650
Alaska700 is offline   Reply With Quote
Old 10-10-2007, 08:18 PM   #3
Thanks. I wanted to make sure. That is what I did. I just wanted to make sure that the mark on the cam gear was to be straight up. Still trying to figure out where my power is going. Thanks again
raptor 700 timing marks
how to set timing on raptor 700
raptor 700 cam timing marks
raptor700 hotcams timming
how to set the timing on a raptor 700
how to time raptor 700
raptor 700 timing
2006 raptor 700 timing marks
setting the time of a yamaha raptor 700cc 2006
timing for yamaha quad 2006
06 yamaha raptor 700 setting timing
06 yamaha raptor 700 timing marks
cant get my timing right bubba4257 Yamaha YFZ450/450R (2004-Present) 1 10-19-2006 12:52 PM
timing mod ronniesraptor Yamaha YFM660R Raptor (2001-2005) 3 01-19-2005 03:41 PM
Cam Timing? Blksnshn Yamaha YFM660R Raptor (2001-2005) 3 05-03-2003 03:50 AM
Cam Timing? Blksnshn Yamaha YFM660R Raptor (2001-2005) 2 04-09-2003 05:07 PM
