How do I replace oneway bearing and and gear - Yamaha ATV Forum
post #1 of 5 Old 11-01-2002, 06:41 PM Thread Starter
I purchased a one way bearing and gear from north county yammah (back of dirt wheels) for 105 and 51
and I chose to over night it for 30 instead o ground shipping for 9 $. I also got 2 gaskets for 10 $.
I removed about 10 bolts around casing and the small casing at the top of larger casing. I also removed plugs with flat head.
I started to wedge the a flathead between casing and man did that oil start pouring out
How do I unplug the oil and what else am I suppost to do now?
Please help I cant do it without yall.
thanks
CT exahust full tip, proflow, rejeted
Houser +3 A-arms , Elka long travel suspension
renthal raptor bend
catchup is offline
post #2 of 5 Old 11-03-2002, 07:32 AM
a little tip, turn the bike on it's side, and work on it, you won't have oil pouring out, plus it makes it real easy to work on. once the cover is off, you will see the big nut holding the flywheel on, take that off install the puller, and pull off the flywheel, the entire one-way assy will come off with it. loosen the six bolts that hold that assy to the fly wheel, re-place with the new one, tighten the six bolts, use locktight on them, and torque them to the proper specs do not guess at it. then just put it all back together.
wisco 11:1, 696/697 webcam, webcam spring kit w/titanium retainers, sparks X6 exhaust, hinson basket, sparks clutch, , 02' tranny update, port work, lonestar +3 a-arms, elkas, rpm dominator axle, some ims goodies
sinner660 is offline
post #3 of 5 Old 11-03-2002, 08:31 AM Thread Starter
what is the proper torque specs
how do I make shure its right
lock tight is a grease?
I can get it where?
thanks so much for your help.
renthal raptor bend
catchup is offline
post #4 of 5 Old 11-03-2002, 10:09 AM
Loc-tite is not a grease. It's a thread locking compound that you put on the threads to ensure that they don't back out on you due to vibration.
You can find it at AutoZone, or any other auto parts store for about $5.
P.S. If you use the RED Loc-tite, don't use much. Just a drop, or you'll never be able to change this stuff out again without breaking & stripping bolts. I recommend the BLUE Loc-tite.
SOLD:
86 Intruder
87 KX80
95 Katana 600
96 GSX-R 750
98 VTR1000
97 900RR Traded for Raptor
2001 Black/White Raptor 660
DG bars, GYT-R swingarm skid plate,
no parking brake, -1 up front, black hubs
N4cer is offline
post #5 of 5 Old 11-03-2002, 01:30 PM
Do Not use red Loctite on external bolts!!
Red is permanent & may require heat to remove.
Blue is the standard for most needs.
Most auto parts places will have a chart for aplications.
Make sure you shut off the gas & drain the carbs before putting it on it's side!!
Sand draggin dune runnin 02 blue Raptor
Sparks Stainless X6
My Web Site
My Image Station album
The Compound
THEMOOSE is offline
one way bearing; 52teeths gear??? RaptoR2k2 Yamaha YFM660R Raptor (2001-2005) 5 11-19-2004 10:02 AM
Counter Wheel Gear Bearing issue... ucfwarrior Yamaha YFM350 Raptor/Warrior ('87-Present) 3 10-02-2004 07:45 AM
lonestar bearing carrier and bearing velocity-raptor Yamaha YFM660R Raptor (2001-2005) 5 09-17-2004 12:35 AM
Need to replace coolant, Help! Warrior03 Yamaha YFZ350 Banshee (1987-Present) 7 07-26-2004 10:01 AM
