Electric start won't work. Any Ideas? - Yamaha ATV Forum
This is a discussion on Electric start won't work. Any Ideas? within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; When I push the electric start button on my Raptor, all I hear is a clicking sound coming from behind the battery. When I pull ...
Old 09-24-2002, 08:23 PM   #1
View tonka's Photo Gallery(0)
Default Electric start won't work. Any Ideas?
When I push the electric start button on my Raptor, all I hear is a clicking sound coming from behind the battery. When I pull it behind the truck, it starts right up. I hooked jumper cables up to the battery and all I get is the same sound. The yellow fuses look good to. Any ideas on whats wrong? Any help is greatly appreciated.
2001 686 Raptor, DMC Alien, 12:1 JE Piston, WebCam Grind# 736/737, Port and Polish, K&N Filter, K&N Stage 2 Jet Kit, Air Box Mods, DG Nerf Bars, DG Front Bumper, PRM Skid Plates, Chrome Radiator Guard
tonka is offline   Reply With Quote
Old 09-24-2002, 08:29 PM   #2
View Holstein660R's Photo Gallery(0)
Check the battery connections first, if they are tight, then I would check out the starter relay.
Jerrard/Holstein660R
2001 Raptor with a few things :)
Holstein660R is offline   Reply With Quote
Old 09-24-2002, 08:29 PM   #3
View OCR's Photo Gallery(0)
Sounds like you fried a cpl of cells in the battery... if you did, even jumping it w jumper cables wont get you a direct current.
Vet B AMA National Harescramble Series
Vet B NECC
09 Sponsors: Can Am, ASV Inventions, Fox Suspension, Engine Ice, ITP Tires, DP Brakes, Regina Chains, Smith Optics, Oneal MX Clothing, Powermadd, SixSixOne, Tag Metals
OCR is offline   Reply With Quote
Old 09-24-2002, 09:14 PM   #4
View CANUCKWARRIOR's Photo Gallery(0)
im having the exact same problem with my warrior
my battery is fine my fuse is fine i just push the button and hear "click"
so all i do now is use the button to make pull starting it easier
(cheap aren't I?)lol
89 yamaha warrior
SOLD
Wanted: cheap older bigbear 350,
87 Ford Tempo L Bone stock only 37,000Km
86 honda trx250 - For Sale
tank/atv
CANUCKWARRIOR is offline   Reply With Quote
Old 09-24-2002, 11:15 PM   #5
Guest
Posts: n/a
View 's Photo Gallery()
Sometimes the push button on the bars will turn green on the inside and will not get a good connection. Take it all apart and clean it. Or it could be a loose wire on your starter relay. I have had many Warriors and have had to clean two starter buttons.
Old 09-25-2002, 01:04 AM   #6
View rickman's Photo Gallery(0)
As Goochy says, I just recently ran into that problem ,so I pulled the switch apart and cleaned it .I havent had a prob. since
And a friend is also having a problem with his.... And I might have another answer in a couple days BUT...he is a lazy ass
and WE'LL NEVER know what the problem with his is.........
Because he'll just keep bitchin then all of a sudden it will start,!
then he says F**K it and rides it.
So do the chekin or cleaning of terminals and switches and good luck,You'll find it .
rickman is offline   Reply With Quote
Old 09-25-2002, 12:10 PM   #7
View mondo128's Photo Gallery(0)
Default same prob
I have the same prob with my raptor, couldnt figure it out, but took seat off and found the connection going to starter was a little loose b/c there was no slack for it and it kept tugging off. gave it more slack and then zip tied it so it would stay on.
www.theslicknick.com
There once was a man from nantucket...
mondo128 is offline   Reply With Quote
Old 09-25-2002, 06:33 PM   #8
View WarriorMaster's Photo Gallery(0)
hmmmm, the same thing happened to me, but on my
1981 Honda CB750K. I tryed charging the battery and buying new fueses, but I cant find the weak connection?
Well good luck
2001 Blue Yamaha Warrior - Baja swing arm skid plate - Baja Full Chassis skid plate -22x11x9 6-ply Maxxis Razr's Rear Tires - White Bro's E-Series with 9 Disc's - James Lucky Parking Break Kit - Pro Flow
WarriorMaster is offline   Reply With Quote
Old 09-25-2002, 07:58 PM   #9
View stacker's Photo Gallery(0)
try checking the connections and charge the battery
that might work.
later
stacks
96 Warrior,Ti springs,Hi Comp Piston,FMF Megamax II,PowerBomb Headpipe,Uni Filter,Holeshots Front & Rear,Douglas .190's all around,Answer Bars,Works Tripple Rates Up Front,Custom Seat Cover & Graphics,DG Push Bar,DG Nerfs, NEW CUSTOM PLASTIC(maier)
stacker is offline   Reply With Quote
Old 09-25-2002, 08:48 PM   #10
View quick_660r's Photo Gallery(0)
I've had that problem three times. Twice it was the starter relay. (the little black thing the positive battery wire goes into)
Try cleaning your switch, if that doesn't work, the starter relay is prolly bad.
2001 Raptor
quick_660r is offline   Reply With Quote
Old 09-26-2002, 07:37 PM   #11
View badercarma's Photo Gallery(0)
The “clicking” sound you hear is the solenoid turning on to give the starter power. I would put a test light on the starter and see if the power is getting all the way there. If it isn’t I would try it on the side of the connection on the solenoid that goes to the starter, if that has power your problem is probable the wire going to the starter.
And if the starter is getting power but it doesn’t turn over at all and the neutral light doesn’t dim when the start button is pressed in then its probable your starter that’s bad. You can try tapping on it with a hammer or you can take it to bike place or something and they can rebuild it.
Hope this helps.
`95 honda 400cc 4x4
`06 tw200
`86 bw200
Loud pipes close trails.
badercarma is offline   Reply With Quote
Old 09-27-2002, 02:24 AM   #12
View popo35's Photo Gallery(0)
Install a kick start. No more problems just your right thigh will be just a little bigger kicking over 660 ponies.
Be Safe !
popo35 is offline   Reply With Quote
Old 09-27-2002, 07:38 PM   #13
I used a test light on the relay box and everything is getting power except for the big black wire. I'm pretty sure that's the wire that goes to the starter. I'm testing it at the connection right at the box, so I know its not the wire. I'm guessing the relay is bad.
raptor 660 starter solenoid same a big bear
1997 yamaha kodiak 400 wont jump start
99 big bear wont start by push button
how come my yammha 1990 big bear 350 4 wheeler makes a clicking sound when i try to use the electric strategy
quad electric start not working
raptor 660 wont pull start
why will the stater button work on my yamaha fz1
kodiak just clicks wont start
1997 yamaha 90 atv wont start
atv if electric starter doesnt work
05 ttr125 electric start does not even click
starting 250, bruin from solenoid
Replacement for Electric Start 03raptor660 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 03-18-2005 12:59 AM
Electric start isnt so electric anymore?! WBWarrior Yamaha YFM350 Raptor/Warrior ('87-Present) 11 07-28-2004 09:36 PM
problems with gas leak and electric start.. BLASTED Yamaha YFM350 Raptor/Warrior ('87-Present) 4 02-05-2004 10:10 PM
Keep electric start with a kicker? EX 80 Yamaha YFZ450/450R (2004-Present) 0 10-15-2003 07:18 PM
